Go Back   SmokStak > SmokStak® Support and Information > Web Server News
Web Server News Various information and older news about the SmokStak™ web server and its functioning.
Web Server News
Server Maintenance - Hard Drive Change
this thread has 2 replies and has been viewed 693 times
Old 11-10-2012, 11:15:31 PM
Harry's Avatar
Images: 316
Default Server Maintenance - Hard Drive Change
The RAID 10 Alarm went off so the techs will be swapping out one of our four hard drives tonight (11/11/12) between 1 and 4 AM Central Time.
-- Harry
Old 11-11-2012, 12:11:37 PM
Harry's Avatar
Images: 316
Default Re: Server Maintenance Tonight - Hard Drive Change
Employee Response - 2012-Nov-11 01:32 (GMT-0600) [Update 7]
Hello,
We will be starting your scheduled maintenance shortly. Please be aware that the server may become inaccessible once the maintenance begins. If you have any questions or concerns, please do not hesitate to update this ticket. This ticket will be updated again when the maintenance has been completed and the server is back online.
Thank you,
Paul J. SBT
Employee Response - 2012-Nov-11 01:57 (GMT-0600) [Update 8]
At this time the drive has been replaced, the array is rebuilding and the server is back online and responding to network requests.
We will continue to monitor the rebuild until its completion.
Please note that we have found out that the RAID card firmware is currently out of date. Unfortunately due to the array rebuilding, we cannot update the firmware until the rebuild is complete and the array is optimal.
You can update the firmware yourself once the RAID rebuild is complete using the instructions in the link below. (Please note that this will require more downtime)
If you would like for us to update the firmware for you, please let us know if you would like for us to update the firmware immediately after the rebuild is complete or if you would like for us to update it in another scheduled maintenance window.
Thank you,
Employee Response - 2012-Nov-11 04:07 (GMT-0600) [Update 9]
At this time the rebuild is only at 31%. We will check back on it in a few hours and provide you with an update.
Walt R.
SBT Shift Lead
Employee Response - 2012-Nov-11 08:24 (GMT-0600) [Update 10]
At this time the rebuild is only at 89%. We will check back on it in a few hours and provide you with an update.
Thank you,
Justin S. SBT
Employee Response - 2012-Nov-11 10:34 (GMT-0600) [Update 11]
The array has completed the rebuild and is now optimal. As mentioned previously, the RAID card firmware is out of date. The scheduled maintenance window has ended due to the time of the rebuild. If you would like to schedule a new window for the firmware update, or if you would like us to perform this immediately, please let us know. Also, you can update the firmware yourself using the instructions in the link below.
Please let us know how you would like to proceed.
Thank you,
Justin S. SBT
Old 11-12-2012, 09:08:31 AM
Harry's Avatar
Images: 316
Default Re: Server Maintenance - Hard Drive Change
I gave them the OK as of last night...
Employee Response - 2012-Nov-12 01:23 (GMT-0600) [Update 14]
Hello,
Thank you,
Paul J. SBT
Employee Response - 2012-Nov-12 01:45 (GMT-0600) [Update 15]
Hello,
At this time the firmware has been upgraded and the server is back online and responding to network requests. If you have any questions, concerns or need further assistance please do not hesitate to let us know.
Thank you,
Paul J. SBT
The Following 5 Users Say Thank You to Harry For This Post:
onan raw water impeller hard to change sluggo Onan Generators 0 06-18-2012 08:35:28 PM
Computer Backup to External Hard Drive Jim Tremble Computer, Camera and ISP Problems 8 09-29-2011 11:38:53 AM
Backup Your Hard Drive - This means you! Harry Computer, Camera and ISP Problems 30 01-05-2011 03:13:58 PM
Trying out new hard drive Paul Hokanson Antique Engine Archives 1 01-17-2004 02:14:33 AM
