Where to find 10-20 Titan Parts?
this thread has 68 replies and has been viewed 17713 times
Old 05-28-2012, 04:06:46 PM
Default Re: Where to find 10-20 Titan Parts?
^ That stuff works as well as anything and probably stays clear longer than anything else too.
If you DON'T have the feed cover with the frame you can get the all clear cover from Dave Preuhs.......
The Following 3 Users Say Thank You to Craig A For This Post:
Old 05-30-2012, 05:47:00 PM
SproutW's Avatar
SproutW SproutW is offline
For those of you interested. I'm in the process of having front wheel bearings being made at a local shop in the next few weeks Should be around $100 to $120 per bearing. Send me a PM if you would like some, and I'll get it added to the order. Thanks.
The Following 2 Users Say Thank You to SproutW For This Post:
  #23
Old 06-11-2012, 11:28:21 AM
SproutW's Avatar
Just made up some "Brake Band Shank Bolt Washer" part number 1758TM for the Titan 10-20 project of mine. Had a few extras made if anyone is interested. See the classified ads for further information or contact me, thanks.
The Following 5 Users Say Thank You to SproutW For This Post:
  #24
Old 06-12-2012, 03:28:05 PM
Roger Byrne's Avatar
Roger Byrne Roger Byrne is offline
As SproutW mentioned on another thread, Starbolt (a sponsor here on STAK) carries some 10-20 Titan parts too. They have valves, valve springs, valve keepers and piston rings. They also carry the early style spark plug wire and clips.
Preserving Mechanical History for Future Generations since 1965
The Following 3 Users Say Thank You to Roger Byrne For This Post:
  #25
Old 10-16-2012, 01:13:52 PM
jimmy ayre jimmy ayre is offline
Hi Joe, I,m looking for guide bands for a 1920 Titan .Also my tractor is missing the serial number tag . Do know anything about Titan governors ? Having trouble getting my tractor to idle down .
Jimmy
Old 11-25-2012, 09:19:22 AM
FredandCy FredandCy is offline
Well, cold weather finally set-in here in PA so it's time to get back to those inside projects. We have a late Titan 1922? We are looking for a few vital pieces. We need a late mode, long Piston 10 1/2" long, copper head gasket, and the ends for the water tank. Joe, any luck you could help me with the head gasket and water tank parts??
Any leads on a piston would be appreciated. I'm pretty much dead in the water without it!!!! Thanks
Attached are some current pics from yesterday. I have some before pics that I'll also post but I'll need to get my 14 y.o. son the reformat them for me.
ID:	150341   Click image for larger version
The Following 4 Users Say Thank You to FredandCy For This Post:
  #27
Old 11-25-2012, 09:49:17 AM
Chris Hudson Chris Hudson is offline
A neighbor of mine has reproduced the ends of the water tanks, they're perfect reproductions. Drop me an inbox message if you're interested.
The Following User Says Thank You to Chris Hudson For This Post:
  #28
Old 11-25-2012, 08:52:18 PM
Joe Prindle's Avatar
Joe Prindle Joe Prindle is offline
I got a pair of the water tank ends from Chris Hudson's neighbor, Don. They are, like everything that Don does, excellent.
I will pm you about the head gasket, got one left, will probably get more made sometime after Christmas.
Regarding the skid rings, we are going to make a few sets after Christmas. We will bend the ring and cut the ends to the right length and then let you drill your own holes. Late Titans use a one piece ring, early ones use five pieces. If we leave the holes out, you can make sure that they will fit your wheels. Price will depend on how much time it takes. Doing more than just one set at a time should make us a lot more efficient. That's the first time I ever used that word in regards to anything that we do........
I wish I could get to it sooner, but am swamped with projects to get done before the end of the year at work.
Joe
The Following User Says Thank You to Joe Prindle For This Post:
  #29
Old 11-26-2012, 09:21:59 AM
Sounds good. Thanks for the info. I'll be in touch.
Old 11-26-2012, 08:16:04 PM
primerk5 primerk5 is offline
Does anyone have pictures of the compression relief valves in the bottom of the cylinders? I need to know what I'm looking for. Ours doesn't have them and Its a lot of fun to get started without them. If anyone knows of a source for them as well that would be great.
I also need to find the lower carburetor for water for the later model titan with ensign carb setup.
Old 11-26-2012, 10:52:53 PM
^ primer, the arrangement of the compression relief valves is the same as the cylinder lever drain cocks on a steam engine.
Old 11-27-2012, 07:02:21 PM
Bruce Flatmoe Bruce Flatmoe is offline
I just picked up a few 10-20 parts from a friend that was getting rid of his last few crumbs. I have a pretty nice fuel tank, a hand starting crank, some angle iron lugs, two Bosch mags on Titan mag bases. If you are interested, please PM me.
Old 11-27-2012, 08:08:29 PM
Most helpful thread here. I do not own a Titan, however, I am thrilled to see all this good information being passed around to help fellow collectors out!
Thanks guys, (Mr. Byrne)
Tony
The Following User Says Thank You to Tony Thompson For This Post:
  #34
Old 11-27-2012, 10:19:50 PM
Card Sponsor
Pics of the comp. releases
Name:	stuff 3-11-12 012.jpg
ID:	150629   Click image for larger version
Name:	stuff 3-11-12 005.jpg
The Following 3 Users Say Thank You to Rob Charles For This Post:
  #35
Old 11-27-2012, 10:23:10 PM
Card Sponsor
more pics of th decomp.'s
Name:	stuff 3-11-12 004.jpg
ID:	150631   Click image for larger version
Name:	stuff 3-11-12 008.jpg
  #36
Old 11-28-2012, 12:00:19 AM
Thanks for the pictures, now ill go see what I can find around here for some steam cylinder relief valves. Didnt realise they are the same.
Old 10-31-2013, 09:00:45 PM
mag473 mag473 is offline
I have 10 20 Titan angle iron Grousers for sale. 15 for each wheel. measure 20" long 2" X 2 1/2" 507 two six nine 6696
Old 11-03-2013, 08:16:28 PM
binxs binxs is offline
Hi I got all my titan panels etc from www.tractorpanels.com. When you get on their site go to price list as they are all on there, The quality of the parts is very good
Old 11-04-2013, 03:17:38 AM
Torben Larsen Torben Larsen is offline
Hi all, great to see this.
Im looking for the casted "watertank" between the water tank and the engineblock where the water is taking into the cab. (I dont know what the name is of this tank)
Can anyone help me?
Regards Torben
Old 11-21-2013, 10:04:33 PM
2030rumely 2030rumely is offline
I have just purchased a 1919 10 20 and it is missing the complete water injection system. I have checked with some of the companies listed on this site but have had no success. What are the odds of finding this system?
Thank you,
Oiler
Barn fresh Titan find Gary Bahre Hit & Miss Gas Engine Discussion 7 01-06-2012 10:40:25 PM
Need 10-20 Titan Parts Warren Wolf Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 10-15-2011 04:51:44 PM
10-20 Titan Parts John Kloosterman Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 04-16-2010 08:17:12 AM
Need some help with having some Titan Jr Parts made. mrkimball Hit & Miss Gas Engine Discussion 1 06-01-2009 01:01:21 AM
Auction Find (1hp Titan...Famous?) Angela Frase Hit & Miss Gas Engine Discussion 0 09-21-2008 03:04:12 PM
