Where to find 10-20 Titan Parts?
this thread has 68 replies and has been viewed 17698 times
Old 11-22-2013, 02:48:56 PM
Roger Byrne's Avatar
Roger Byrne Roger Byrne is offline
Default Re: Where to find 10-20 Titan Parts?
Congrats on getting a Titan! Yes parts can be found. If you could post a photo of what carb you have, then we would know for sure which of the water units you need. There are two versions that could have been used on your 1919 Titan.
Preserving Mechanical History for Future Generations since 1965
Old 11-22-2013, 07:09:51 PM
2030rumely 2030rumely is offline
Originally Posted by 2030rumely View Post
I have just purchased a 1919 10 20 and it is missing the complete water injection system. I have checked with some of the companies listed on this site but have had no success. What are the odds of finding this system?
Thank you,
Oiler
I just came in and got your message. It is dark outside now so tomorrow I will take a photo of the carb and try and post it. Thank you for the quick reply.
Oiler
Old 11-25-2013, 12:48:54 PM
I checked the photos Gary (2030rumely) sent me and this is the style of carb and water injection unit that is correct for his 10-20 Titan. His carb is complete except for the water injection unit. Maybe someone has the parts he needs and can help him out.
Name:	Titan Carb1.jpg
ID:	180320   Click image for larger version
Name:	Titan Carb2.jpg
ID:	180321   Click image for larger version
Name:	Titan Carb3.jpg
ID:	180322   Click image for larger version
Name:	Post re Carb 3.jpg
The Following User Says Thank You to Roger Byrne For This Post:
  #44
Old 11-25-2013, 10:43:48 PM
Here are a couple of illustrations from the operators manual.
ID:	180362   Click image for larger version
Name:	re Carb 1.jpg
  #45
Old 03-15-2014, 08:43:55 PM
Ramey Ramey is offline
I'm looking for information on the plow that I think sold with my titan and a plow guide. If you would like to see it its featured in a news program called {old and new tractors in the spot light } my titan was running a bit rough mag timing was off I'm in the process of getting it and the plow ready for the 2014 Chilliwack plowing match. Thank you for any information you can provide.
Old 06-19-2014, 07:29:03 AM
mag473 mag473 is offline
I have a set of lugs for a 10-20 Titan for sale. Rochester Mn area
Old 08-31-2014, 01:26:21 PM
Prewar Engines Prewar Engines is offline
Hy 2030rumely ,
I am looking for a 1020 watermixer like is illustrated on the picture mr roger Byrne His post above with the letter B on the mixer .
Maybe you did find one extra in your search to a complete water system ?
It would be great !
Thank you
Old 05-13-2016, 07:07:42 AM
KGarahy KGarahy is offline
I am going to overhaul a Titan 10-20 engine.Can anybody tell me where I can get source cylinder sleeves,valves,valve springs and gaskets.
Can anyone help please.
Old 05-13-2016, 08:18:50 AM
Alastair Geddes. Alastair Geddes. is offline
Gaskets to go are a site sponsor here http://www.enginads.com/bizcards.shtml
Guides can be made from scratch, ditto for valves.
Here is a procedure to do seats here
http://www.smokstak.com/forum/showth...an+valve+seats
Sleeves are just spun cast iron machined to suit, you will need rings as well.
Search the UK for Spun Cast iron 2p grade or maybe the USA ( la sleeve) or Here being Flowcast.com.au i think they export so try locally.
maybe some one will chime in on springs and sources for rings, you need to clean up ring grooves and turn piston so rings will be a custom size not off the shelf size. You need to determine this size once you have done the machine work obviously.
Old 05-13-2016, 10:01:57 AM
Gasengin Gasengin is offline
H and J Machining in Carrington ND has vales, guides and springs.
The Following User Says Thank You to Gasengin For This Post:
  #51
Old 05-13-2016, 10:46:32 AM
MSimons's Avatar
MSimons MSimons is offline
Card Sponsor
www.HandJMachining.com - Henry as previously mentioned, supplies valves guides and springs. He also has sleeves and rings.
The Following User Says Thank You to MSimons For This Post:
  #52
Old 05-13-2016, 11:52:40 PM
Welcome to STAK.......
How about starting your own thread about your endeavor?....... ........with lots of pics.......
Old 05-29-2016, 06:12:49 PM
John Hall John Hall is offline
Check with Wisconsin Historical Society. I got several prints from them years ago, I think they were on a computer that crashed. Machine shop salvaged my valves, I had to make new guides. I am pretty certain you need to supply part numbers. I found a parts book helpful as there were some year/serial # breaks.
The Following User Says Thank You to John Hall For This Post:
  #54
Old 07-21-2016, 09:08:48 PM
I'm bringing this older thread back to help up-date some of the 10-20 Titan parts information. There have been a couple recent posts dealing with guys wanting information and I thought it would be good to try and link some of the newer stuff to this discussion.
http://www.smokstak.com/forum/showthread.php?t=158863
http://www.smokstak.com/forum/showthread.php?t=159944
It has been mentioned that prints are available for some of the 10-20 Titan parts.
I would like to know if anyone has the information on the following springs: #6814TM Throttle shaft spring and #6826TM Speed control spring.
Maybe someone has already made up these springs and if they have, I would be interesting in buying a set. If not, I'd like to get the prints and I'll have a few sets made up for myself and others that are interested.
Another item would be the #6613TM valve tappet oil hole cover. A print of how it was originally made would be nice so an accurate new piece could be reproduced.
If a drawing of the muffler shield for the earlier Titans is available, that would also help to make a better reproduction. This piece mounted on a couple of the lower head bolts and shielded the muffler that sits under the head.
After looking for a long time, I finally found the stack vent casting used on some Titans. If there is enough interest, I would consider casting up a few for guys that need them.
It was mentioned in one of the above linked threads, that there is a print for the floor boards that were used. I would like a copy of that if it is available.
It's great to see that a few more 10-20 Titans are being restored!!
Name:	Valve tappet cover.jpg
ID:	258694   Click image for larger version
The Following 7 Users Say Thank You to Roger Byrne For This Post:
  #55
Old 06-23-2019, 07:20:34 PM
Alltractorman Alltractorman is offline
EMAIL NOT WORKING
Images: 21
Anyone out there making the water tanks for the 10-20?
The Following User Says Thank You to Alltractorman For This Post:
  #56
Old 06-23-2019, 07:27:25 PM
www.salvagetractors.com
  #57
Old 06-24-2019, 02:28:15 AM
Duey C Duey C is offline
I don't even have "my" Titan yet that I wait for and worry about things.
Beever's? Cool.
The Following User Says Thank You to Duey C For This Post:
  #58
Old 07-01-2019, 10:22:59 AM
Bob in Mi. Bob in Mi. is offline
I will be making some this summer. 989-329-1588
Thanks Bob.
The Following 3 Users Say Thank You to Bob in Mi. For This Post:
  #59
Old 07-06-2019, 10:33:33 PM
EMAIL NOT WORKING
Images: 21
Titan sleeve o-rings. I have leaking sleeves on the btm. Is there a place where I can purchase o-rings or any ideas how to seal them up?
Old 07-07-2019, 12:10:27 PM
What kind of tractor do you have that has O-rings? I've never seen one in a 10-20 Titan block. If you are talking about where the block meets the crankcase, that is just a heavy paper gasket that covers the face of the block.
The Following 2 Users Say Thank You to Roger Byrne For This Post:
Barn fresh Titan find Gary Bahre Antique Gas Engine Discussion 7 01-06-2012 10:40:25 PM
Need 10-20 Titan Parts Warren Wolf Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 10-15-2011 04:51:44 PM
10-20 Titan Parts John Kloosterman Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 04-16-2010 08:17:12 AM
Need some help with having some Titan Jr Parts made. mrkimball Antique Gas Engine Discussion 1 06-01-2009 01:01:21 AM
Auction Find (1hp Titan...Famous?) Angela Frase Antique Gas Engine Discussion 0 09-21-2008 03:04:12 PM
