Where to find 10-20 Titan Parts?
this thread has 68 replies and has been viewed 17922 times
Old 07-08-2019, 12:58:25 PM
Alltractorman Alltractorman is offline
EMAIL NOT WORKING
Default Re: Where to find 10-20 Titan Parts?
Sorry...my bad. I just seen it was leaking into my crankcase n thought that's what they had. Tore it apart n realized it was a gasket they had. Can't I just use permatex for a gasket on that side of the block?
Old 07-08-2019, 02:34:56 PM
Roger Byrne's Avatar
Roger Byrne Roger Byrne is offline
Maybe a coat of a good sealant will do the job. I've always made a gasket AND then put a heavy coated of Permatex(or equal) on the block side . . . never had one leak that way. I figure that the gasket will help with any irregularities in the surfaces of those old castings. Kinda like wearing both a belt and suspenders, it can't hurt.
Side note: You may want to re-torque the block nuts after the engine has run for a couple hours, they tend to loosen up a bit.
Preserving Mechanical History for Future Generations since 1965
Old 07-08-2019, 02:36:39 PM
casertractor casertractor is online now
www.olsonsgaskets.com
Old 07-08-2019, 02:45:59 PM
Olson's makes good composite head gaskets but as far as I know, they don't make the one for the block to crankcase connection. It can just be made out of a good grade of medium/heavy gasket paper.
The Following 2 Users Say Thank You to Roger Byrne For This Post:
  #65
Old 07-09-2019, 10:45:11 AM
RoFoCo RoFoCo is offline
Hi
I recently fully rebuilt the engine on my Titan. I purchased a roll of heavy-duty gasket paper from my local motor factors, and custom made a gasket to fit between the block and the crankcase.
I simply sealed the gasket on both sides with a generous smear of normal clear silicone and did up the nuts nice and tight. I've used silicone sealer on other applications (e.g. Fordson radiators) and never had any problems.
Hope this helps, Roger
The Following 2 Users Say Thank You to RoFoCo For This Post:
  #66
Old 07-09-2019, 11:18:47 AM
Russ Hamm's Avatar
My red hi-temp silicone is sometimes visible when im done, I catch some hell about that from fellow collectors because ultimately the purists insist that two mating surfaces should be corrected to only need factory type gasketing to seal.
I say life is short, to each his own.
Old 07-09-2019, 12:13:06 PM
My liberal use of PTFE tape will be sure to get the purists' blood boiling then! I reckon our forefathers would have given their eye teeth for modern sealing materials and treatments; how they ever got asbestos string to seal pipe unions I'll never know!
The Following User Says Thank You to RoFoCo For This Post:
  #68
Old 07-09-2019, 02:27:49 PM
The '19 Titan I had was losing water between the block and case too.
I rolled the engine over until the pistons were at the top of the stroke, got the cylinder block slung from a hoist, unbolted the block and slid it back enough to get at the gasket.
I made a new gasket of 1/32" vegetable fiber gasket paper, and split the gasket at the top so i could "wind" it into position without having to remove the rods.
I gooped the joints and that was that.
Sure saved a lot of time.......
The Following 4 Users Say Thank You to Craig A For This Post:
  #69
Old 07-09-2019, 03:54:44 PM
Russ Hamm's Avatar
We have also used string in the way similar to what Craig mentions, wrapping it around the bolts as it goes. My 18-32 Case block seal to the cast frame was done that way some time ago.
Barn fresh Titan find Gary Bahre Hit & Miss Gas Engine Discussion 7 01-06-2012 10:40:25 PM
Need 10-20 Titan Parts Warren Wolf Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 10-15-2011 04:51:44 PM
10-20 Titan Parts John Kloosterman Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 04-16-2010 08:17:12 AM
Need some help with having some Titan Jr Parts made. mrkimball Hit & Miss Gas Engine Discussion 1 06-01-2009 01:01:21 AM
Auction Find (1hp Titan...Famous?) Angela Frase Hit & Miss Gas Engine Discussion 0 09-21-2008 03:04:12 PM
