Marvel Schebler TSX-38 Carburetor
this thread has 10 replies and has been viewed 3170 times
Old 07-15-2013, 02:19:27 PM
Nevr-Enuf-Stuf's Avatar
Nevr-Enuf-Stuf Nevr-Enuf-Stuf is offline
Photo Marvel Schebler TSX-38 Carburetor
I did an internet search for this carb but cant seem to find its application. I found a list of Oliver carbs but it list, in part, TSX-37 and then TSX-48 skipping over the 38. Any ideas?
Patrick
ID:	169633   Click image for larger version
ID:	169634   Click image for larger version
ID:	169635   Click image for larger version
Old 07-16-2013, 12:56:08 PM
Default Re: Marvel Schebler TSX-38 Carburetor
After some heavy searching I finally found at least one reference to this carb being for a Ford power unit, dont know what years or what exact engine though.
Patrick
Old 07-16-2013, 08:24:46 PM
Mike in CA Mike in CA is offline
The Massey Ferguson TO 35 used a carb just like that one.
The Following User Says Thank You to Mike in CA For This Post:
Old 07-17-2013, 12:41:35 AM
Restofire Restofire is offline
I have a copy of the Marvel Schebler salesmans condensed catalog from Feb 1961, All I can come up with is Ford industrial power unit, I scanned the entire catalog and that is the only application for the tsx 38.
The Following User Says Thank You to Restofire For This Post:
Old 07-22-2013, 09:06:41 PM
Firewoodguy's Avatar
Firewoodguy Firewoodguy is offline
I got a tsx-38 under the bench for 20yrs that came from an old ford powered wood chipper. hope that helps. its the only thing left from the chipper. china got the rest
The Following User Says Thank You to Firewoodguy For This Post:
Old 07-23-2013, 06:39:56 PM
Dempster Dempster is offline
Zenith / Marvel Schebler 1-400 catalog only lists it as for Ford industrial power units. 012522 Zenith carb is listed for it's new replacement and that is a universal Zenith carb for most all 4 cylinder older Ford tractor engines 8N, 9N, 600 & 700 series.
Old 01-29-2019, 11:06:54 AM
psloniger1 psloniger1 is offline
Firewood guy, I have a WW II steel wheel 2n Ford that requires a TSX-38. I need one, so do you still have one and would you be interested in selling it.
Thank you
Old 01-30-2019, 01:50:04 PM
mmcdonald mmcdonald is offline
The only difference between the 33 and the 38 is the choke shaft. If you can't find a 38, get a 33 which shouldn't be hard to find and put your choke shaft in it. You'd have the identical carb and not too expensive either.
info@mcdonaldcarb.com
Old 01-30-2019, 04:23:40 PM
Thank you
I sold the carb off the table at a swap meet few years ago, sorry.
Old 01-30-2019, 09:48:50 PM
Greg M Greg M is offline
Looks alot like the carb on my Lincoln SA 200 welding machine (Continental 4 cyl.).
Old 04-27-2019, 08:02:36 PM
VowellArt VowellArt is offline
Interesting carburetor...what's inside it? If you can take some pictures of the insides and send to me, I'd appreciate it.
marvel schebler carburetor vh 12 Help Please digz440 Antique Farm Tractors 0 06-02-2011 12:00:07 AM
Marvel Schebler Carburetor for Wisconsin AKN Jim M. Wisconsin Engines 5 12-09-2010 06:38:16 PM
Marvel Schebler Carburetor woes sparksandslag Welding Shop 4 01-23-2009 12:34:46 AM
Marvel Schebler carburetor - need help Tractasaurus Antique Farm Tractors 2 10-06-2008 10:32:01 PM
Marvel Schebler Carburetor help Joseph Onan Generators 4 01-25-2006 10:43:06 PM
