Long Model A
this thread has 92 replies and has been viewed 17670 times
Old 04-23-2014, 08:15:25 PM
Molinegb Molinegb is offline
Default Long Model A
Located a Long model A tractor recently. Basically looks like a Cockshutt 30 with a Continental motor. I know these were a post war tractor slapped together to fufill shortage. How many were produced? Anybody collect these?
The Following User Says Thank You to Molinegb For This Post:
Old 04-24-2014, 07:18:37 AM
Default Re: Long Model A
Somewhere around here I have a bit of info on the Long, Model A - I'll see if I can find it another day.
They were sold, in Ontario at least, by OTACO out of Orillia. That was formerly Tudhope-Anderson Co. and they used to have branch offices in Western Canada and sold the Emerson-Brantingham line. They also made automobiles in Orillia and assorted farm equipment.
OTACO was better known for the TACO kits to convert your old car, Model A Ford or whatever, to a tractor. They sold thousands of those kits.
They picked up the Long as a "real" tractor in the early 50's and I have seen it painted up as an OTACO tractor. I seem to remember it was a 30 hp tractor with Continental 162 ci motor?
RM.
Old 04-24-2014, 05:14:15 PM
Jebaroni's Avatar
Jebaroni Jebaroni is offline
I worked for Long Agribusiness in Tarboro, NC before they went belly up. I had a chance to do cosmetic restorations on Serial numbers 4 and 20. Number 4 is owned by the Long family and #20 was sold at auction when the company folded. They were available in single-wheel narrow, dual front narrow, and wide front configurations. You are correct that the engine, transmission, wheels, seat, and fuel tank were all sourced components. Not much else to fabricate other than the front end and controls. As best as I could tell, only about 500 tractors were ever built and sold. There are 2 different versions of frame rails (6-bolt early and 4-bolt later on). I have heard that the front cultivator for a John Deere would fit these. The very first tractors were built around November 1948 and the later ones sometime in 1949 and that was the end of it.
G Willikers, I'd love to know of any additional information that you have. I do have a reproduction of the original owner's manual and an advertisement brochure/poster. Here is a picture of me driving serial number 20 at the Sunbelt Expo in Moultrie, GA shortly after I got done with it.
The Following 5 Users Say Thank You to Jebaroni For This Post:
Old 04-25-2014, 12:57:50 PM
Ok guys, I found a bit from a 1950 OTACO salesman's binder.
The A - row crop was priced @$2,085.00 and the AW standard tread was $2,200.00.
OTACO stood for Ontario-Tudhope-Anderson-Co.. They also made a good line of plows, tillage equipment, shit spreaders (yes, that's what we call them here!) and other stuff to go with the tractors.
RM
ID:	193918   Click image for larger version
ID:	193919   Click image for larger version
ID:	193920   Click image for larger version
The Following 3 Users Say Thank You to G Willikers For This Post:
Old 04-25-2014, 12:59:52 PM
And the rest of the OTACO-Long brochure.
Good looking tractors really! I hope this is of some help?
RM
ID:	193922   Click image for larger version
ID:	193923   Click image for larger version
The Following 6 Users Say Thank You to G Willikers For This Post:
Old 04-25-2014, 03:42:24 PM
Jim Gordon Jim Gordon is offline
Hey Rick,in Sask. we try to be a little more politically correct and we call them "mechanical politicians" pun intended.
Back to the thread, at one time I was in love with a long,but never did buy it.
The Following 2 Users Say Thank You to Jim Gordon For This Post:
Old 04-25-2014, 08:54:52 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Around here we simply called them politicians. While some Long machinery was sold here very little is left, mostly newer things. I have a small tractor mounted back hoe that is mostly useless, there were a few late model tractors but they weren't too good. Lots of motor problems. I have seen a few combines but never knew much about them, not sure if they were sold under different names or who actually built them. They probably would have fared better if there had been a good dealer support behind them, the small problems become much bigger when you cannot get any parts or service to help. F.J.W.
Old 04-26-2014, 06:32:15 AM
Jebaroni's Avatar
The Model A was the only tractor that Long designed and built themselves. All of the later tractors were imported. While I was there from 2003-2005, they were importing from India (FarmTrac), Korea (LandTrac), and Romania (LongTrac). They had in the past built some peanut combines and I believe a rotary cutter and switch plow, but everything else was purchased, repainted, and sold. Loaders and Backhoes were always designed and built in-house to fit the tractors that we were importing at the time. You are correct that lots of the units had engine issues and it's hard to get a good dealer network when the factory doesn't put out good product, or won't support the dealers. I heard at one time that the engine problems were so prevalent, tractors were being sent to dealers that would not crank. They had to push the tractors off the trailer and do engine rebuilds at the dealer. The quarterly dealer newsletter headline read something to the effect of "We're rolling out tractors!..." The old ford tractor that was discontinued when Ford was purchased by New Holland became the Farmtrac after the Indians purchased the rights to continue building the tractor. Seems to me they took a good design and made it worse.
The Following 2 Users Say Thank You to Jebaroni For This Post:
Old 04-26-2014, 10:08:33 AM
ronm ronm is offline
I remember seeing one of those Romanian Longs, I think one of the salesmen at the JD store traded for it...wasn't real impressed...
I have no idea how it found its way to Western Colorado, there was no dealer anywhere close that I knew of.
Old 04-26-2014, 06:15:35 PM
RM
these tractors have a Cockshutt and Massey Harris Look to them especially the MH 30/33 and Cockshutt 30.Must have used parts from both tractors.John
Old 04-26-2014, 08:32:35 PM
JFred's Avatar
JFred JFred is offline
Jebaroni- Thanks for the great info! I really like these tractors and hope to get my hands on one someday. Do you have any thoughts on the story behind the connection with the literature G Willikers posted???
The Following User Says Thank You to JFred For This Post:
Old 04-26-2014, 10:36:12 PM
In the above posts, when I said "they" made a line of plows, tillage equipment, animal-intestinal-expulsion-distributers, etc., I meant OTACO made them. Tudhope went way back and made a lot of machinery. They made a very nice automobile in the 19-teens. I expect they simply picked up the Long tractor to have a full sized tractor in their catalogue as they were still making car-tractor conversion kits into the 50s. The company was still around into modern times making auto parts (seats maybe?) for the bigger companies.
As for Long stuff, I recall seeing one or two Long tractors here at shows but have not seen one lately. It couldn't have been a big seller for OTACO judging by the scarcity around here? I don't recall seeing any other Long equipment.
RM
Old 04-26-2014, 11:03:32 PM
RM
Did Tudhope not go into the Trucking/Haulage buss in later years?.or is this a differnt company?.John
Old 04-27-2014, 12:05:29 AM
FWurth's Avatar
One Millionth Post
Images: 4
The later Long tractors that were in this area were the Romanian ones. They seemed to have a good lay out as to general purpose work. Once the engines were put right they did alright and easy on fuel.
Old 04-27-2014, 06:37:48 AM
Not sure about Tudhope haulage and have wondered the same thing? It is not that common a name so perhaps a family connection.
Old 04-27-2014, 08:46:25 AM
Tractor is for sale. How would you put a value on it? It falls int a rare category but there aren't many Long collectors out there.
Old 04-27-2014, 11:20:41 AM
Phil Johnson's Avatar
Gary, I have a listing in a value guide by Dean & Swenson that's a few years old. The price ranges from $1800 for one that is not much more than a parts tractor to $9000 for a top quality restoration. I don't know how accurate this info is today.
The Following 2 Users Say Thank You to Phil Johnson For This Post:
Old 04-27-2014, 01:49:22 PM
Thanks for rough idea on value, Phil. The Long really falls into category of oddball or orphan. One would wonder what percentage ended up in Canada. This Long is like most here it is a wide front.
Old 04-27-2014, 03:14:40 PM
Just looked it up and the Long model A was tested at Nebraska - test # 410, May, 1949. The data will be in some of Mr. Wendel's books.
Old 04-27-2014, 11:02:39 PM
Ford model A with OTACO Tractor conversion(Autotrac).John
help w/bearing backlash for Long tiller model 1537 Dalesimms Garden Tractors and Mowers 0 01-26-2012 08:20:06 PM
Maytag model 92 long base engine bartushock Magnetos, Ignition Coils and Spark Plugs 2 07-04-2008 04:00:58 PM
How long Simon, Scotland UK. Antique Engine Archives 2 09-19-2004 05:26:12 AM
