18-32 Case New Project
this thread has 20 replies and has been viewed 4906 times
Old 09-25-2014, 10:29:42 PM
Camerons's Avatar
Camerons Camerons is offline
Default 18-32 Case New Project
Earlier this summer while on our family vacation we stopped in to see a good friend of mine and see some of his collection. While there I noticed a couple nice looking tractors outside in his "bone yard". After doing some thinking I called him up and asked if any of the tractors outside where for sale, he said yes. I asked him about a couple crossmotor cases that he had. He told me that he had an 18-32 that was pretty much complete that he had overhauled but lost interest when something bigger came along. He pushed it outside and that is where it sat for about 2 years. We agreed on a price and the beginning of September my brother and I hopped in the pickup and made a 700 mile round trip to pick up the Case. Here it is. Most of the hard stuff is there like the manifold and air washer. I will need some fender brackets and misc parts and pieces. The tractor is loose and I actually put some gas in it and had it running for a few minutes last weekend.
ID:	206956   Click image for larger version
ID:	206957   Click image for larger version
ID:	206958   Click image for larger version
Old 09-25-2014, 10:32:14 PM
Camerons's Avatar
Default Re: 18-32 Case new project
Here are some pictures of the "projects" that got pushed in front of the Case, I would have probably done that same thing....
ID:	206960   Click image for larger version
ID:	206961   Click image for larger version
ID:	206962   Click image for larger version
Old 09-25-2014, 10:49:15 PM
Tim Colwell's Avatar
Tim Colwell Tim Colwell is offline
Looks like a great project! Are those 2 Rumelys? And what's the story on the Minnie?
Tim
Old 09-25-2014, 10:51:40 PM
Jason W Jason W is offline
It's not often you see Doug cut loose of a project. Got yourself a nice winter project there.
The Following User Says Thank You to Jason W For This Post:
Old 09-25-2014, 10:59:04 PM
99 SD PSD 99 SD PSD is offline
Heck yeah!! It would've been worth a 1000 mile round trip! Looks like it was meant to follow you home. Good Luck, Keep us posted Please.
The Following User Says Thank You to 99 SD PSD For This Post:
Old 09-26-2014, 03:39:55 PM
Camerons's Avatar
Tim
Yes, they are both "E" Rumelys. If you are talking about the tractor in the background of picture 1 thats an Avery that he's gathering parts for.
Old 09-27-2014, 01:55:44 AM
Wow, 2 Es! and upon closer inspection definitely an avery Thanks for the info and keep us updated!
Tim
The Following User Says Thank You to Tim Colwell For This Post:
Old 09-27-2014, 12:16:28 PM
Camerons's Avatar
I am missing all of the rear lugs, if anybody has any extras laying around send me a pm.....thanks!
Old 10-17-2014, 10:05:58 PM
Camerons's Avatar
I have been slowly trying to get the gas tank and hood mounted on the 18-32 Case. Could anyone with a late k18-32 take some pictures of the gas tank mounting bracket. The hood I received with this tractor has the starting tank mounted to it with 2 straps. Some of the later K's have 2 brackets that come out from underneath the main tank and the starting tanks sits on the brackets. I am not positive what I need so any pictures would help. The serial number tag is missing from the fender on mine but 69586 is stamped on the frame, also mine has the bigger steering wheel. Thanks for your help.
The Following User Says Thank You to Camerons For This Post:
Old 10-17-2014, 10:28:30 PM
The E engine in post 2 appears to have an early governor cover with squared edge on the back. Serial numbers of them?
Old 10-18-2014, 09:58:43 AM
Camerons's Avatar
The Rumely's belong to a friend who is 350+ miles away. I know he said one is early and one is late. As far as serial numbers and any other details I will see what I can come up with.
The Following 2 Users Say Thank You to Camerons For This Post:
Old 10-22-2014, 09:41:34 PM
Camerons's Avatar
Default Re: 18-32 Case New Project
After looking at pictures and talking to some fellow collectors I have come to the conclusion that I don't have the correct parts to put the gas tank on my tractor. The early tractors had the starting tank mounted to the side of the hood with 2 straps. The later tractors had 2 L shaped brackets that the starting tank sets in. I need the later style brackets that the gas tank sets on with the starting tank brackets. Would anyone have some brackets for a later 18-32 that they are willing to part with? Here is a picture I borrowed from steel wheels.net to show the style that I am looking for.
http://i68.photobucket.com/albums/i8...nslow07_1a.jpg
Old 02-08-2015, 09:29:28 PM
Camerons's Avatar
Just a quick update. Progress has been real slow on the crossmotor too many other things getting in the way. When I got this tractor the gas tank bracket was missing. After looking at some sales brochures and pictures the 15-27 and the 18-32's up to about 1927 had the starting tank mounted to the side of the hood with a couple of straps. The later 18-32's had 2 L shaped brackets that came out from under the main tank and the starting tank rested on these brackets. I came up empty handed in my search for an original bracket. I talked to a friend of mine from Kansas who had an original and was kind enough to send me his bracket to use as a pattern. Thanks again Joe! Here are a couple pictures before we started assembling the new bracket.
ID:	218050   Click image for larger version
ID:	218051   Click image for larger version
The Following 4 Users Say Thank You to Camerons For This Post:
Old 02-08-2015, 09:34:27 PM
Camerons's Avatar
I also managed to get the fenders back on and thankfully I am only missing one small bracket that can be fabricated. I am going to have to spend some more time straightening the fenders.
ID:	218053   Click image for larger version
ID:	218054   Click image for larger version
The Following 11 Users Say Thank You to Camerons For This Post:
Old 05-07-2015, 11:32:03 AM
Camerons's Avatar
Things are slowly coming together on the Case. I have been working on getting some misc leaks fixed and getting it to start and idle better. I found that the float arm and needle are quite worn on mine making it hard to set the float height. Wondering if anyone has a float arm and needle for a Kingston L-1 carburetor?
Old 06-07-2015, 09:44:20 PM
Camerons's Avatar
Had some free time this afternoon so I took the Case for a drive and shot some video.
https://www.youtube.com/watch?v=wUKh...ature=youtu.be
Old 07-05-2019, 11:42:24 AM
Russ Hamm's Avatar
Images: 1
After a wrestling event with my radiator shroud yesterday I noticed that this tractor has the shroud installed just like I installed mine the first time, with the center inboard on the radiator. Mine pooched out all over so I unbolted it and put the center two bolt tangs over at the top and under at the bottom, it fit a lot better after that. I had pics of before I took it apart but couldn't find my darn camera.
---------- Post added at 10:42:24 AM ---------- Previous post was at 10:38:59 AM ----------
Another kinda humorous note, that is the tank bracket from my tractor, was looking through some 18-32 archives for assembly details and noticed that.
The Following 2 Users Say Thank You to Russ Hamm For This Post:
Old 07-05-2019, 12:37:59 PM
Camerons's Avatar
I can't believe that was 4 years ago already. I sold that tractor in October of 2016 and it now resides in eastern Michigan. A week later I took a road trip and came home with my 12-24 Hart Parr. Joe B helped me out quite a bit with my Case project and he helped my brother with his 12-20 Case project a few years before.
Old 07-05-2019, 12:54:44 PM
I hope you did not restore that one?.It looked good as is
Old 07-06-2019, 10:22:45 AM
Camerons's Avatar
I agree totally! No paint for this one as long as I own it. The story I got from the previous owner is that the tractor has all its original paint except for the gas tank.
22-40 Case Project Craig A Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 31 12-16-2015 08:14:40 PM
New Project:1944 Case D on steel J Ware Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 23 08-15-2013 11:06:01 PM
Case 15-27 crossmotor new project. neilthewheel Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 03-10-2012 11:46:01 PM
Case 12-20 New Project Camerons Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 21 12-28-2011 07:47:52 PM
New project, Case 500 Turbo Antique Farm Tractors 10 11-20-2007 12:07:12 PM
