Avery Motor Cultivator Help
this thread has 18 replies and has been viewed 3508 times
Old 05-03-2015, 11:22:17 PM
Russ Hamm's Avatar
Images: 1
Default Avery Motor Cultivator Help
Can anyone date this tractor by the radiator? I'm sure lost on them but by the pictures iv'e seen so far i'm guessing early.
Name:	tractor pics 042.jpg
Old 05-04-2015, 08:20:49 AM
gleaner gleaner is offline
Default Re: Avery motor cultivator help
Yoder was cobbling that motor cultivator up from anything he could find. The radiator, engine, front wheel, all are wrong. It started out as a late gear driven 6 cylinder motor cultivator.
The Following User Says Thank You to gleaner For This Post:
Old 05-04-2015, 09:16:18 AM
Russ Hamm's Avatar
Images: 1
Final drive gears were originally enclosed , also the diff.
By the looks of the front frame casting and all that, it was one of these at one time.
Old 05-04-2015, 10:09:35 AM
Joe P Joe P is offline
My thought is some of it is the remains of a very late road razor even later then the catalog pic you posted.
The Following User Says Thank You to Joe P For This Post:
Old 05-04-2015, 03:36:20 PM
Russ Hamm's Avatar
Images: 1
Probably 80% cobbled up, 90% wrong, but saved from scrap and being forever gone. All i was curious about was the radiator, doesn't appear on the internet as much as the top tank with fins and no through bolts on the sides.
Old 05-04-2015, 10:03:19 PM
Dan thomas Dan thomas is offline
I looked at one of those about 10-12 years ago, no motor .to dumb to buy it .should see if it is still there.
The Following User Says Thank You to Dan thomas For This Post:
Old 05-22-2015, 11:35:46 AM
Russ Hamm's Avatar
Images: 1
Iv'e looked at as many pictures i could find on the internet and still haven't found many with this radiator, it doesn't have friction drive so i assume it is later in production.
Hadn't found any Avery collectors organizations either, other than BF A.
Old 05-22-2015, 02:52:47 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Don't know that there are enough Avery guys out there to get any sizeable group together for much more than a early morning coffee shop session.
The Following 2 Users Say Thank You to FWurth For This Post:
Old 05-22-2015, 11:33:55 PM
Mike T Mike T is offline
Looking at full line catalog, that radiator looks like the one on late road razor, approx. 1926.
The Following User Says Thank You to Mike T For This Post:
Old 05-23-2015, 06:23:08 PM
Russ Hamm's Avatar
Images: 1
Can you tell what engine might be in it? All i have seen are Avery engines, this one has a replacement ( we think) Waukesha flathead in it dated 1926.
Old 05-23-2015, 11:05:06 PM
It's out of a Rumely Do All I believe. Joe P
Old 05-24-2015, 10:56:00 AM
Russ Hamm's Avatar
Images: 1
But i forgot, Avery was out of buisness by 1924 i think.
Old 05-25-2015, 12:29:30 AM
Sprint8f Sprint8f is offline
Avery reorganized a couple of times and operated to the late 30's or early 40's.
Matt
Old 05-25-2015, 09:17:26 PM
SteamfanMN SteamfanMN is offline
The flywheel cover (And I'm just guessing wildly) Reminds me of a F135 Continental I dug one up at a junkyard dated about 1923 or so
Old 11-19-2016, 03:13:27 PM
Russ Hamm's Avatar
Images: 1
A bump for Ed on his rdiator date question. I noticed tractor dom had an avery catalogue download on this site for 1923 but i can't seem to look at them, you may search for it and see what the radiators look like there.
Otherwise, they are sure hard to date, i would say 1924 and probably be close.
Old 12-14-2016, 12:09:05 AM
Russ Hamm's Avatar
Images: 1
Default Re: Avery Motor Cultivator Help
This evening i was looking up some information in the 'red tractor book' for 1926 and FINALLY found a picture of a unit with this radiator. This power road maintainer would have a different frame and front bolster than what is left of mine, which i think would make it a road razor.
But the interesting part is the engine note. It says the road maintainer for 1926 had a Waukesha 3 1/2x 4 1/2 four cylinder, which is what mine has in it dated 1926! I assumed this engine was wrong and should be an Avery engine.
ID:	270223   Click image for larger version
Name:	tractor pics 043.jpg
The Following 3 Users Say Thank You to Russ Hamm For This Post:
Old 12-14-2016, 12:10:58 AM
Russ Hamm's Avatar
Images: 1
one more picture from the front
Old 12-14-2016, 12:13:29 AM
Russ Hamm's Avatar
Images: 1
ooops, for some reason that didn't work, try this.
Name:	tractor pics 045.jpg
The Following 4 Users Say Thank You to Russ Hamm For This Post:
Old 07-09-2019, 03:57:21 PM
Russ Hamm's Avatar
Images: 1
Can anyone post a clear picture of an Avery motor cultivator ID tag? I think they are on the frame right rear. Also some dimensions, possibly?
International Motor Cultivator J Lowe Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 37 03-01-2015 12:33:37 AM
Unkown Tractor or motor cultivator Woodz Antique Farm Tractors 1 08-09-2013 01:17:55 PM
1918 Toro Motor Cultivator Help runningmad Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 01-14-2012 12:13:39 AM
1920 Toro Motor Cultivator Help runningmad Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 10-12-2010 01:22:04 AM
IHC Motor Cultivator Craig A Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 12-20-2004 06:53:15 AM
