Got FI problems with my Chevy go getter
this thread has 38 replies and has been viewed 4692 times
Old 08-05-2015, 01:45:16 PM
Avery22x36 Avery22x36 is offline
Default Got FI problems with my Chevy go getter
I got an old pickup I use for pulling a trailer around in weeds when I buy goodies, its been real dependable but old enough I never worry about dents and scratches. A month ago it started bucking and having trouble pulling a trailer, it has a 91 4.3 V6 in it and the parts guy told me to clean the TB so I did and put a new kit in. Started it up and it sounded great, hitting on all 6 but kept on revving up. I put a new throttle pos sensor on it and it still wrapped up, I put a new air sensor in it and did the same also. I unhooked everything on the throttle body but the wires going to the injector tips and it still did it. I am out of ideas, can't find a vacuum leak or anything obvious and it probably runs up to 3k if I let it. I didn't mess with anything else but the throttle body and got a couple hundred bucks in kit and sensors in it and worse now than when I started. Its like the fuel pump just forces the gas right on through? If anyone has an idea I would sure like to know because I am really needing it running. Thanks
Old 08-05-2015, 03:06:59 PM
Default Re: Got FI problems with my Chevy go getter
Vaccum leak (anywhere on throttle body, plenum, intake, brake booster, vaccum accessories like A/C controls or front wheel drive selector.)
throttle body is being held open by misadjusted screw, dirt or damage to throttle body, throttle cable too tight or hanging up
idle air motor is stuck open (most likely IMHO)
Too much fuel just causes it to run rich, not faster. To run too fast it needs AIR.
The Following User Says Thank You to pegasuspinto For This Post:
Old 08-05-2015, 03:36:22 PM
Since the throttle is not moving and the engine is racing up in rpm's, it must be getting air and the Idle air control is the logical place to look for trouble.
You might consider going to a junker and getting an entire another TBI.
Lots of them will give you a 90 day warranty and it will be cheapest. If it does not work, take it back and they will refund you.
The Following User Says Thank You to sdowney717 For This Post:
Old 08-05-2015, 07:42:06 PM
Try to determine if the air is entering through the idle air passage, a port at the back of the throttle body. If so remove the idle air control and see if it's screwed way in, spring compressed, little of the shaft exposed. We have a tester that plugs in and controls the idle motor, you may be able to rent one at the auto parts, ours is a Thexton. If you can slow the motor down with this you can eliminate vacuum leaks and the idle motor, trouble is then likely in the computer or wires. Check the grounds at the thermostat housing.
Old 08-06-2015, 09:13:02 AM
Thanks everyone, I put a new Idle Air control on it and not luck, I am going back through the vacume and grounds. I am kind of discouraged right now, thanks
Old 08-06-2015, 10:44:56 PM
Was the idle motor pintle screwed in or was it extended? Did the idle increase as it ran? Did you check to see if the air was going in through the idle by pass port between the injectors in the back?
Old 08-07-2015, 02:02:00 AM
Sounds like a stuck injector to me. See if it runs with injector wire removed. Next thought is maybe a shorted drive transistor in the ECU. But an OBD reader ought to tell the problem.
Doc
Old 08-07-2015, 04:06:22 AM
Power Power is offline
Stop throwing parts at it!
Try this - cost is only time.
When you are sure there are no air leaks, and everything is properly installed, reset the computer. It is still working from old sensor values, and is confused.
To do this, disconnect the battery. Step on the brake pedal for a minute, or turn on the lights with the battery disconnected. Wait a good 15 minutes and reconnect battery.
Start it. Now computer has to relearn everything. If it is functioning, it should quickly regulate idle. It will run different for about 50 miles or an hour as it relearns.
Old 08-07-2015, 04:00:23 PM
Well, it set over night with everything hooked up and the doors open so if there was any juice hid anyplace with the battery unhooked I assumed the dome light would have drained it?
---------- Post added at 02:52 PM ---------- Previous post was at 02:49 PM ----------
Doc
I pulled both sets of wires off and it would not run at all, I pulled only one set off and it would almost idle? I got a couple readers but not that go back this far, I would have to load it on a trailer and haul it an hour to find one, I live in the country.
---------- Post added at 03:00 PM ---------- Previous post was at 02:52 PM ----------
I didn't know a lot about it but it looked like the new one I bought and had about as much travel when you pushed against it. The Carquest guy said I shouldn't have to mess with it if I just replaced it so I did. I am from the carb era, I am not that sharp at this, thanks
Old 08-07-2015, 04:25:50 PM
David M. Lyon's Avatar
The pintle of the idle control should be wiggled out of the solenoid enough so that it bottoms out against the seat when installed. Then the computer will automatically adjust the pintle out the proper number of steps to maintain the correct idle speed. If you pushed it in, the computer is lost because it uses the bottomed-out position as the base to know how many steps out to open the pintle. They were famous for getting out-of-whack back on the 90's models and had to be removed, bottomed-out, and then reinstalled.
The Following User Says Thank You to David M. Lyon For This Post:
Old 08-07-2015, 08:45:33 PM
Dan A S Dan A S is offline
Hello those have a problem of carbon collecting in the EGR solenoid valve holding open making a vacuum leak and high idle f they stick open ll do whats happening noticeable at idle when it should be closed engine before reinstalling to blow out loose carbon they make a gasket with a screen to prevent future problems if it does it again
The Following User Says Thank You to Dan A S For This Post:
Old 08-09-2015, 10:28:39 AM
I am still working on it, Pintle seems to be in spec, the thing I don't get is when you start it and the butterfly is completely closed and stays so with the cable off, why is the tips putting out a huge amount of fuel? I am starting to wonder if it is a computer problem because it almost has to be electric to blow all that fuel through don't it? I am seriously thinking of making an adapter plate for a carb right now.
Old 08-09-2015, 01:15:08 PM
Kevinp86 Kevinp86 is offline
Under the dash board there is an obd1 connector with nothing plugged into it. there are 2 rows of terminals. on the top row on the right is terminal "a". terminal "b" is the second one in from the right. terminal diagram labeling is like this from left to right.
top row,"F", "E", "blank","C","B","A"
bottom row "G","H", "blank","blank","blank","blank"
take a small piece of wire and jump terminal "A" and "B". i found an unfolded paper clip works well. with the terminals jumped, turn the key to the on position.(DO NOT START ENGINE) with the key on, the service engine light will start flashing codes. count the flashes. it will repeat each code 3 times before moving on to the next code. your first and last code will be a code 12. that is just the test code. it lets you know you did it right. you will see 1 flash with a short pause then 2 flashes. after you see that 3 times, your next code will be your trouble codes. when you see code "12" again, there are no more. Once you have the code number you can look it up to see what it is. I can look them up for you monday once im back at work.
I would really be leaning towards a large vacuum leak or something you have done when rebuilding the throttle body considering this problem didn't exist until than maybe pull it back apart and double check everything you did and pay close attention to your gaskets making sure there right. Hope this helps! Kevin.
The Following User Says Thank You to Kevinp86 For This Post:
Old 08-09-2015, 02:59:06 PM
A piece of carbon holding the EGR valve open slightly would cause that problem. I have also found where a backfire broke out a chunk of the EGR gasket and caused that. The computer is going to maintain a 14.7:1 fuel to air ratio. if it's getting a bunch of air it's going to dump in a bunch of fuel to maintain the correct stoichiometry.
Old 08-09-2015, 03:18:37 PM
More fuel make it run rough and start to make black smoke out the pipe, NOT faster. HAS to be getting more air to burn that fuel, then it runs faster.
Having him flash the engine codes won't do much if there isn't a check engine light on. is it on? lol
Probably 95% of all computers in these cars are replaced have NO problem. That is the most reliable part of the whole system, honestly.
Old 08-09-2015, 05:33:16 PM
OK, this is what I did, I took the unit back off, made sure everything was right on it. I plugged the brake booster vacume line, I plugged all other lines on the TBI so the only air it could get was through the idle air motor and it is just barely under 1 1/8 out, both the new and old one. My assumption is that for some reason it is not getting the signal to close? It sounds good, reminds me of a big out engine when you stomp it and hear the air rushing in. I made a circle around the driveway, a fast one, I wouldn't do it if it had an auto, its that fast. Its frustrating because everything else is working good but the idle, I guess I will try to figure out the codes next. Thanks
Old 08-10-2015, 12:11:55 PM
I am about to go find a code reader, however, I unscrewed the air motor and had the key turned on while in my hand, it just kind of jumped and did not extend or retract it any noticable amount. With the TBI off and screwed in looking at the bottom, it lacks 3/16 of sealing so without moving out its not going to, I think that is my problem, now just why isn't it moving, or the other one moving, can't have two bad ones? I wouldn't think so anyway?
Old 08-10-2015, 01:43:08 PM
I got a code reader called "Auto X-Ray", I had to use a special cable to hook up, give the Vin number and all the usual and it ran a scan and said it was operating normal. Hmm. Now What?
Old 08-10-2015, 03:11:43 PM
Doug Tallman Doug Tallman is offline
With A and b jumpered in the ALDL and the key on, you should get a bright-dim test light on 2 terminals of the IAC connector and the other two should be on-off. That is the test for the computer to be able to control it.
The Following User Says Thank You to Doug Tallman For This Post:
Old 08-15-2015, 11:41:17 AM
All the terminals are dim all the time, no matter if it is jumped or not? Thanks
Detroit 4-53/81 Chevy motormanjeff Antique Autos and Trucks 39 06-13-2016 01:19:50 AM
41 Chevy Pickup Tom Sampson Antique Autos and Trucks 25 05-18-2014 10:57:18 PM
Attn: To ALL chevy guys, Chevy parts N.O.S. & Repro parts Sky Antique Autos and Trucks 4 08-31-2007 11:47:33 PM
