New Toy From Craig's List
this thread has 10 replies and has been viewed 2568 times
Old 09-09-2015, 07:13:45 PM
PFT's Avatar
PFT PFT is online now
Images: 31
Default New Toy From Craig's List
Picked this drillpress up recently. Just looked like a neat old unit that might be useful once in awhile. Kept looking at the listing and thinking I should buy it, then a possible use for it has come up, so I went and bought it. Replaced the rotten 2 wire cord with a salvaged 3 wire cord, runs like a champ.
PT
ID:	234101   Click image for larger version
ID:	234102   Click image for larger version
ID:	234103   Click image for larger version
The Following 4 Users Say Thank You to PFT For This Post:
Old 09-09-2015, 07:23:09 PM
PFT's Avatar
Images: 31
Default Re: New Toy From Craig's List
Some more pictures.
If the possible use works out (it's a bit unusual), I will post some pics.
PT
ID:	234105   Click image for larger version
ID:	234106   Click image for larger version
The Following 2 Users Say Thank You to PFT For This Post:
Old 09-09-2015, 07:51:35 PM
OTTO-Sawyer's Avatar
May have to dig mine out of the iron pile one of these years.... or the stand part of it anyway which was already rusted solid when I got it.
I have a couple old 1/2 inch drills that should fit it.
Old 09-09-2015, 08:05:50 PM
Doug Kimball's Avatar
Images: 78
PT,
If you take the drill off the stand be sure to have a tight grip on it! Don't ask how I know.
In Kennebunk, Maine;
Doug Kimball
Old 09-09-2015, 08:19:35 PM
Heins Heins is offline
Is the drill a 1/2" or will it take a larger bit?
Old 09-10-2015, 07:06:55 PM
PFT's Avatar
Images: 31
The tag on the drill says 1/2", I haven't tried anything bigger in it yet. You can be sure the need to know how big will come up sometime in the future. Oh yea, that unusual job coming up will require a larger hole.
Doug, I know why. Been there, done that with other old 1/2" drills similar to that one. Them old ones got some kinda big torque.
PT
Old 10-03-2015, 06:24:58 PM
PFT's Avatar
Images: 31
Finally got to that unusual use for the drill. Needed to drill a 5/8" hole in the mower drawbar on my F12. Put the base/table of the drill under the drawbar with a board and jacked it up against it. Added a c-clamp to help stabilize it and drilled the hole. Took 2 1/2 min to get through the drawbar without a pilot hole. Sure beat pushing a hand held drill hard enough to make a hole.
heins, the chuck won't take much over 1/2", maybe 17/32, but that would probably be a tight fit. The 5/8" drill I used had a 1/2" shank.
PT
ID:	236024   Click image for larger version
ID:	236025   Click image for larger version
ID:	236026   Click image for larger version
Old 10-03-2015, 10:12:14 PM
s100 s100 is offline
Hard to go wrong with an old Black & Decker or Van Dorn tool. They made the best hand held power tools bar none.
Old 10-31-2015, 07:12:32 PM
PFT's Avatar
Images: 31
Was looking through Graigslist yesterday (Syracuse NY area) and there is another drill just like mine. It is missing the strap at the bottom of the motor that helps hold it to the stand. They are asking less for it than I paid, but it is missing that strap and the ad doesn't say if it runs or not.
PT
The Following User Says Thank You to PFT For This Post:
Old 05-12-2019, 08:59:28 PM
PFT's Avatar
Images: 31
Added another B&D drill to the collection today, it is only a little 1/4" drill, but it matches the big one for vintage.
The seller asked what else I needed so I asked what have you got? He dug around and came up with these 2 Armstrong clamps and a J.H.Williams clamp. Was a good day.
PT
ID:	334711   Click image for larger version
ID:	334712   Click image for larger version
ID:	334713   Click image for larger version
Old 05-12-2019, 09:02:16 PM
PFT's Avatar
Images: 31
Another pic of the J.H.Williams clamp.
And yes, I have to fix the cord on the drill.
PT
Onan's on Craig's List Dale Russell Onan Generators 9 08-26-2015 06:37:58 PM
Sandwich on Craig's list Keith Johnson Hit & Miss Gas Engine Discussion 0 07-21-2015 09:21:16 PM
Engine on Craig's List Tom Adkins Hit & Miss Gas Engine Discussion 21 03-03-2010 09:49:35 AM
Rumely on Craig's list Jon Nessel Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 08-07-2009 09:23:13 AM
