1917 Lauson Tractor 15-25 Project
this thread has 113 replies and has been viewed 20036 times
Old 10-09-2015, 09:34:54 PM
greysteam24hp's Avatar
greysteam24hp greysteam24hp is offline
Images: 100
Default Re: 1917 Lauson tractor 15-25 project
This is photo scan Lauson tractor 8 1/2 x 11 catalog no. 52 in my collection. This was sent to Michigan from Toledo, Ohio Lauson distributor( as shown printed on back). Regular size to large and largest duty special tractors showing every info.
Name:	lausoncatalogpic (449x640).jpg
The Following User Says Thank You to greysteam24hp For This Post:
Old 11-25-2015, 08:48:02 PM
Randy Reysen's Avatar
Randy Reysen Randy Reysen is offline
Photo Re: 1917 Lauson tractor 15-25 project
Marshal and I have begun to tear into this old girl
Gearing looks new! We have a strong suspicion this didn't see the field much, figure it was mainly belt power.
ID:	239665   Click image for larger version
ID:	239666   Click image for larger version
Old 11-26-2015, 11:06:24 AM
Randy We got our honeycomb radiator for the Avery Trackrunner from Brassworks out in California. The core had a tag that it was built in Hants, England. It was a major problem mating it to the brass flanges. It did come out great and looks original. The cost is a major factor but we lucked out because someone ordered it and never picked it up and it happened to be the size we needed.[pure luck] Brassworks have ads in all the major tractor mags. Good luck just have a bank check ready. Ed B
Pic No 1 shows the brass flanges that we had to solder to the Honeycomb core. [cut out on a water jet] Pic No 2 is the top tank I fabricated from 1/4 inch plate. Last Pic is the core ready to bolt together.
ID:	239690   Click image for larger version
ID:	239691   Click image for larger version
The Following 8 Users Say Thank You to Ed Bezanson For This Post:
  #24
Old 11-27-2015, 11:25:39 PM
Just a quick photo update. Bull gear covers off and man are they are a heavy hunk of cast. We will be putting together a trailer load to take to Milwaukee to be dipped in rust remover. Tomorrow we'll be lifting the transmission off, but it stays home so we can wire brush it and flush the insides.
ID:	239838   Click image for larger version
ID:	239839   Click image for larger version
Old 12-01-2015, 10:11:10 AM
So I said we were going to take the transmission off the frame and.....fail. Transmission 1, Reysen men 0. The pulley ended up being in the way of the removal so yesterday afternoon Marshal tapped the gib key and used a slide-hammer to remove the gib key. Thought it was going to be rusted like usual; however, it was oily the entire length of the key. Remarkably easy, I'm sure we will pay for this easy removal later.
Does anyone have a parts manual for an enclosed gear Lauson 15-25? I like photocopies or scans too.
Old 12-02-2015, 10:37:54 PM
Got the transmission off tonight. Last thing will be the front wheels. Then as long as it's going to be 48 degrees in December this Saturday I'm going to steam clean the 90 year old grease off the parts in order to prep them better for the dipping.
ID:	240288   Click image for larger version
ID:	240289   Click image for larger version
ID:	240290   Click image for larger version
The Following 14 Users Say Thank You to Randy Reysen For This Post:
  #27
Old 12-03-2015, 12:05:11 AM
Talking Re: 1917 Lauson tractor 15-25 project
You'd better remember how to put it back together........ .......
The Following 3 Users Say Thank You to Craig A For This Post:
  #28
Old 12-03-2015, 09:36:53 AM
Funny you mention that Craig! I spent way too much time on the Hart-Parr trying to figure out where the heck all the parts and bolts go! This time I have a camera in the shop, permanent marker, and lots of Ziploc bags. Every nut, bolt, or part that can fit in a bag gets labeled. My brain just isn't what it used to be!
Any other, "keep track of stuff", suggestions are appreciated. Marshal said the other night, "we need to get this back together quickly, that way we will have a better chance remembering where things go." I think the idea is to reassemble and paint what we took apart and then work on the engine, radiator, and sheet metal.
Speaking of sheet metal. I took the fenders and dash off about a month ago and brought them into shop class at the high school I work for. The students are taking measurements and programming them into their CNC plasma cutter. Hope to actually bring the tractor in for the fitting of the parts when they finish. I think this would both be good experience for the students and hopefully plant a seed or two for a future collector.
The Following 8 Users Say Thank You to Randy Reysen For This Post:
  #29
Old 12-03-2015, 04:29:06 PM
J Ware J Ware is offline
Randy, i hope you do, we need more young people interested in steel wheeled hand start tractors. They also need to learn the old trades to keep them alive. Jim
The Following 3 Users Say Thank You to J Ware For This Post:
  #30
Old 12-03-2015, 11:22:29 PM
Mr. Reysen,
That is an excellent project so thanks for sharing it with us. The Lausons were fine looking tractors.
Did they make the transmissions for them or was that bought in?
Thanx.
RM
Old 12-04-2015, 08:51:53 AM
Kevin A. Behnke Kevin A. Behnke is offline
Fond du Lac machine made Lauson transmissions.
The Following 9 Users Say Thank You to Kevin A. Behnke For This Post:
  #32
Old 12-05-2015, 12:02:22 AM
FWurth's Avatar
FWurth FWurth is online now
One Millionth Post
Images: 4
I was thinking that the transmissions were supplied by Foote Bros?
  #33
Old 12-05-2015, 01:07:40 AM
Foote provided a LOT of transmissions.
I believe the 18-35 Rock Island I had was Foote equipped but they were pretty proud of their product and cast their name quite prominently into their housings.
  #34
Old 12-05-2015, 10:12:44 AM
Kent McMakin Kent McMakin is offline
On the Lauson gear boxes I've been around, I've yet to find any kind of name or ID on them. Just the usual part numbers. Always wondered if Lauson supplied the castings and Fond du lac Machine did the rest. Might help explain the lack of a name. Who knows?
The Following User Says Thank You to Kent McMakin For This Post:
  #35
Old 12-05-2015, 10:56:56 PM
Perhaps the image attached will help. Lauson tractors were built with primarily local Wisconsin parts. Transaxle Fond du lac Machine Co. of Fond du lac WI, clutchs were Twin Disc of Racine WI, Engines Leroi,Wisconsin and Beaver of Milwaukee WI, Radiators came from Racine WI. TACO governor and air cleaner of New Holstein WI. TACO (Tractor Appliance Company) was a separate company owned by John Lauson.
The Following 11 Users Say Thank You to Kevin A. Behnke For This Post:
  #36
Old 12-05-2015, 11:25:57 PM
Were some Lauson tractors tagged for Nichols & Shepard also?
Old 12-05-2015, 11:27:21 PM
That is correct.
The Following User Says Thank You to Kevin A. Behnke For This Post:
  #38
Old 12-05-2015, 11:53:07 PM
Kevin, Thanx for posting that ad. Sure clears up the transmission question.
Old 12-06-2015, 01:59:59 AM
This is a Nichols and Sheppard tagged 20-40 Lauson Threshermans' Special that spent most of it's life in central Wisconsin.
It's still in Wisconsin so it's likely it never left the state........
(Photo courtesy of Aumann Auctions)
The Following 9 Users Say Thank You to Craig A For This Post:
  #40
Old 12-06-2015, 08:26:13 PM
First off a big thank you to Kevin Behnke for the information and sending me photocopies of an original 15-25 advertisement catalog! Next is just a quick post of its progress as of tonight. While the rust is disolving I'll be working on trying to get the radiator redone.
Has anyone seen one of those hybridized radiators with fins on the inside and a veneer of honeycomb on the outside? How do they look? Anybody have shop in Wisconsin they can recommend for a quality veneer or complete refab?
One last thing I have never messed with one of these honeycomb cores before so how do you check to see if the core is good yet? Thanks!
ID:	240568   Click image for larger version
The Following 5 Users Say Thank You to Randy Reysen For This Post:
1917 Bull tractor company letter Barnbikes Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 07-22-2012 02:17:56 PM
Photo Postcard 1917 Bull tractor plowing AND? Randy Reysen Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 12-27-2010 03:16:49 PM
1917 Linn Tractor Production Number One Rene Elliott YouTube Old Iron Videos 0 11-27-2009 08:15:45 PM
1917-1918 Alldays & Onions tractor Dave Preuhs Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 03-31-2007 04:48:36 AM
1917 16-30 Eagle tractor Dave Preuhs Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 12-02-2004 06:10:00 PM
