Go Back   SmokStak > SmokStak® General Off Topic Discussion > Trucks, Trailers and Hauling for Shows
WHAT GIVES 14.5x8 trailer tires
this thread has 4 replies and has been viewed 4071 times
Old 10-31-2015, 07:48:54 PM
IronworkerFXR IronworkerFXR is offline
Default WHAT GIVES 14.5x8 trailer tires
ok bought replacement tires for my 6 ton trailer , why are the new ones so small ,, same size load range G what happened to the width and height ?
http://www.smokstak.com/forum/pictur...pictureid=8818http://www.smokstak.com/forum/pictur...pictureid=8818
more confusion,, trailer is a factory made one, why would they use house trailer axles ?
ID:	237973   Click image for larger version
Old 10-31-2015, 10:27:23 PM
Charlie1925 Charlie1925 is offline
Default Re: WHAT GIVES 14.5x8 trailer tires
The small tire is a 7x14.5 ( 8 ply ) The old tire is a 8x14.5 (10 ply ) I would return the new ones, they will not do the job the 8x14.5 will do. I run a three axle 24ft. trailer with the 8x14.5 and get good service from them. Roger Weinhold AKA Charlie 1925 , Good luck on your projects.
---------- Post added at 10:27 PM ---------- Previous post was at 10:24 PM ----------
Check my profile and see what I haul
Old 11-01-2015, 08:26:47 AM
Tony Rye Tony Rye is offline
the small ones may not be D.O.T .house trailer tires are not DOT tires
Old 11-01-2015, 03:55:27 PM
Gasengin Gasengin is offline
Both are house trailer tires. Older ones were 7's and newer ones are 8's. Return them. You want the 8's. Also, if you are buying new tires, you want the type that is called a "lowboy" tire.
Old 11-01-2015, 04:14:30 PM
lowboy tires as you call them are DOT for hwy use and will not get you a ticket . house trailer tires are for use on a house trailer only . house trailer axel wheel and tires can get you a ticket. they make axel tire and wheel that are DOT. and there are a lot of different if you ever see one you will know it.
Trailer Tires, What has been your Experience Keith B. Trucks, Trailers and Hauling for Shows 41 12-05-2015 06:29:36 AM
Trailer with tires in middle schrammman Antique Autos and Trucks 10 07-24-2015 09:49:00 PM
Trailer Tires ronny p 148 Trucks, Trailers and Hauling for Shows 16 06-17-2014 07:46:24 PM
Trailer tires? Forrest A Trucks, Trailers and Hauling for Shows 10 10-27-2005 08:33:31 AM
trailer tires vs. trailer tires Marty Trucks, Trailers and Hauling for Shows 27 01-02-2003 07:05:39 PM
