eBay Auctions
Go Back   SmokStak > SmokStak® General Discussion > eBay© Auction Discussion
eBay© Auction Discussion All eBay™ discussion; engines, frauds, fancies, weird stuff and more.
Minneapolis in Germany
this thread has 10 replies and has been viewed 4812 times
Old 01-06-2016, 05:42:19 AM
prop prop is offline
Default Minneapolis in Germany
Minneapolis steam traction engine for sale in Germany:
http://www.ebay.de/itm/Minneapolis-D...IAAOSwX~dWiTZ0
see also (very simple website): http://dampffahrten.de/
Ulm, Germany
Old 01-06-2016, 09:35:09 PM
Default Re: Minneapolis in Germany
An early 22HP lap seam with a solid crank disc that is unfortunately missing the cylinder lagging segment that has the engine number on it. It's a long ways from home! Probably around the 1910 vintage?
I used to run this same model at the White Pine Logging and Threshing Show over by McGrath MN. It was outfitted with a Pickering governor and worked well on the sawmill.
Old 01-09-2016, 08:11:28 AM
windymiller78 windymiller78 is offline
what pressure should this be running at 6 bar 80psi seems low, i looked atimporting a minneapolis to the uk before and that was running at 140 psi?
Old 01-09-2016, 11:17:51 AM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
They haven't given much info on the condition of the engine and boiler. That is the determining factor in what pressure it is now allowed. Not sure of the exchange rate for Euros but the asking price seems plenty high especially if it needs extensive work to get the allowed pressure back up to what it should be. Originally the allowable pressure should be around the 140 psi. mark.
Old 01-09-2016, 11:37:11 AM
The 1908 22HP I ran in McGrath was set at 100 lbs which at that time was all the State of MN would allow on any lap seam boiler. Later Minneapolis engines had the slotted crank discs and were outfitted with heavier boilers.
Old 01-12-2016, 05:44:58 AM
Exchange rate Euro-Dollar is 1-1,09 so asking price is USD 90470 (which is quite steep in my opinion)
The Following User Says Thank You to prop For This Post:
Old 05-11-2017, 01:48:57 PM
JMathews JMathews is offline
that was dad's old minne
Old 05-11-2017, 03:23:48 PM
gleaner gleaner is offline
Is that the engine Don Brooks had?
Old 05-11-2017, 03:57:41 PM
no. dad's came from Ben Markley.
Old 05-14-2017, 04:42:01 PM
Reeves13hp's Avatar
Reeves13hp Reeves13hp is offline
Card Sponsor
These aren't very current pictures but this is Don Brooks old engine. It is going thru a very extensive restoration.
New boiler
New bull gears and pinions
Axles turned and sleeved and wheels bored
Being completely rebuilt.
ID:	282197   Click image for larger version
ID:	282198   Click image for larger version
8-1/2x10 Frick
13hp Reeves
50hp Case
22hp Wood Brothers
18hp Advance
20-75 Nichols & Shepard
20hp Corner Bracket Advance
16hp Minneapolis
Old 05-14-2017, 04:43:13 PM
Reeves13hp's Avatar
Card Sponsor
Belongs to Kurt Kocher of Glasco Kansas
8-1/2x10 Frick
13hp Reeves
50hp Case
22hp Wood Brothers
18hp Advance
16hp Minneapolis
Unterwellenborn, Germany Brian Triebner Hit & Miss Gas Engine Discussion 7 05-16-2014 09:01:35 AM
new member from germany doppelnik Smokstak Forums Meet and Greet 6 08-17-2013 05:44:19 AM
Hi, new young guy fom Germany! Enginefreak91 Smokstak Forums Meet and Greet 11 01-18-2012 02:32:23 AM
New member from Germany says Hello Arno M- Germany Smokstak Forums Meet and Greet 1 09-25-2010 08:21:29 PM
Hallo from Germany Arnd Smokstak Forums Meet and Greet 2 05-12-2010 10:36:55 AM
