1938 Sears Economy 220.25 Restoration
this thread has 131 replies and has been viewed 26716 times
Old 07-25-2016, 10:14:16 PM
Default Re: 1938 Sears Economy 220.25 Restoration
You are right about that! I don't know that I would trust those with a full load of hay!
Old 07-26-2016, 10:16:00 PM
As usual your fabrication skills are top notch. Cant wait to see the progress on this project. We just had someone donate a home built tractor to the Zagray Farm quite similar to the Economy. It was hand built from plans from Popular Mechanics Mag. It has a Model A engine and Ford truck extra trans and differential. We have started some work but we are busy building a new engine shed so it will have to wait till cooler weather. I will be posting pics when we get going again and may need some help. Thanks Ed B
The Following User Says Thank You to Ed Bezanson For This Post:
  #23
Old 07-30-2016, 05:50:21 AM
JFred,
Always interesting to see what you do with your basketcase projects. After I've seen so many younger people want an "easy" tractor restoration, it's great to see someone taking on such challenging projects. Best of luck with it!
Mike M
The Following 2 Users Say Thank You to Mike McKnight For This Post:
  #24
Old 07-30-2016, 07:29:32 PM
JFred's Avatar
JFred JFred is offline
Originally Posted by Mike McKnight View Post
JFred,
Mike M
Thanks for the encouragement Mike! Personally I enjoy the challenge of saving one that probably wasn't worth saving or maybe I should say probably wouldn't have been saved.
I managed to get the steering wheel and shaft assembly finished this week. Sears Economy tractors used from what I was told by SE guru Dave Elmore a 1937 Chevrolet steering wheel. My original steering wheel was all bent and all the covering was falling off, plus to get the old shaft out it required heat and we all know what heat will do to rubber/plastic! Anyway Dave had bought up several 37 Chevy wheels in the past so he sold me one. The only difference other than the color (will be painted black eventually), is in the internal hub. To make it identical to an original Sears Economy steering wheel I had to bore the hub out to 7/8" ID and lengthen the hub 1/2" and then drill a 1/4" cross hole through the extended portion of the hub. On a Chevy it was on splines where it is pinned on on a SE.
Picture #1: Shows the new steering wheel with the unmodified Chevy hub.
Picture #2: Shows the 1/2" hub extension beveled and ready to be welded on.
Picture #3: Is of the finished wheel after the weld had been ground down and attached to the new steering shaft. Also in the picture you can see the 2 set screw collars I had to make that belong on the shaft to keep it from sliding back and forth.
ID:	259204   Click image for larger version
ID:	259205   Click image for larger version
The Following 7 Users Say Thank You to JFred For This Post:
  #25
Old 07-30-2016, 09:11:03 PM
Phil Johnson's Avatar
Phil Johnson Phil Johnson is online now
Nice job on the steering wheel and shaft, James. Looks great!
  #26
Old 08-06-2016, 05:15:30 PM
1206SWMO 1206SWMO is offline
As promised heres some pictures of a friends 1939 220-26 serial #1332 thats under restoration....The pictures make it look orange but its red..Its near EL Dorado Springs,MO...
Theres another 220-26 at the Republic,MO show thats a few serial numbers higher than this one.....Theres also a 220-26 at Girard,KS that was restored years ago..It has two transmissions..
The Following 6 Users Say Thank You to 1206SWMO For This Post:
  #27
Old 08-16-2016, 11:04:15 PM
JFred's Avatar
Thanks 1206SWMO! I appreciate the pictures and serial number! If you ever find out for sure what the serial numbers are of the other 2 tractors please let me know. Thanks!
The Following User Says Thank You to JFred For This Post:
  #28
Old 08-17-2016, 09:23:20 PM
JFred's Avatar
One more fabrication job has been completed. I had to fabricate the sheet metal floor pan from an original off of a friends tractor since mine was missing unfortunately. This piece has a slot on the left side that the clutch pedal sticks through as well as an easy access cover to check the water in the battery that would also be mounted directly below this floor pan.
Picture #1: Plasma cutting out the 12 gauge metal for the floor pan.
Picture #2: Shows the floor pan with the battery access panel removed.
Picture #3: Shows the floor pan with removable cover installed.
ID:	260487   Click image for larger version
ID:	260488   Click image for larger version
The Following 4 Users Say Thank You to JFred For This Post:
  #29
Old 08-31-2016, 08:28:09 PM
weebz90 weebz90 is offline
Wow! You are making some great progress! Keep up the great work!
The Following User Says Thank You to weebz90 For This Post:
  #30
Old 09-06-2016, 10:16:33 PM
JFred's Avatar
Thanks Bill! We sure missed you at the national show this year! Your Sears Economy would have made 20!
Old 09-06-2016, 10:41:12 PM
JFred's Avatar
Well back to posting some long overdue progress..... When I got this tractor the front spindle assembly unit that would have came on this tractor originally was missing, however it did come with one from a 1939 SE tractor. The only difference is the vertical stub shaft that is pressed and welded in. Other than that it is identical to what the 1938 models used. All that was required to make it identical in every aspect to how it came out from the factory was to grind off the weld and remove the stub shaft with the hydraulic press.
After sandblasting up the part to remove all the rust and grease, an ugly failed attempt to make some kind of repair in the past was revealed! So that had to be remedied.
Picture #1: Spindle unit before sandblasting.
Picture #2: A close up of someone's failed repair long ago.
Picture #3: After completely grinding out all the old braze and stick weld, I filled the entire cavity with new weld up to the surface.
Picture # 4: The finished spindle unit after metal finishing the weld. Ready to be installed.
ID:	262201   Click image for larger version
ID:	262202   Click image for larger version
ID:	262203   Click image for larger version
  #32
Old 09-23-2016, 10:37:16 PM
JFred's Avatar
I now have the front steering shaft tower finished, however it will take a couple posts in order to show it all with pictures. This part had seen better days, but was very much repairable. The main issue that needed addressing was the steering stop. In picture #2 you can see that originally there was a steering stop that was casted in the top of the part, but more than likely the steering wheel got away from the operator at some point and it busted it clean off. So it appears that a cobbed up repair was made by welding on a round rod 180 degrees from the original stop .
Picture #1: Shows the steering tower before any work started.
Picture #2: After sandblasting has been done to reveal the damages and to prepare for repair.
Picture # 3: After the tower has had the homemade steering stop removed and metal finished down
Picture #4: Shows the new stop that I made to look like the original before attaching.
ID:	263647   Click image for larger version
ID:	263648   Click image for larger version
ID:	263649   Click image for larger version
  #33
Old 09-25-2016, 09:56:14 PM
JFred's Avatar
Here are the second round of pictures for the steering shaft tower repair. As I mentioned in the previous post the original steering stop was broken off and missing. I got the measurements off of an original stop from a friends tractor. I duplicated it, but needed a way to attach it now. So I drilled and threaded a hole in the new stop and then drilled a hole to install a countersunk bolt into from underneath. After it was installed and tightened I welded over the head and ground the weld off so that you cannot tell anything was ever done. After that was finished I brazed around the stop where it transitions to the casting to help give it the appearance that it is a casted part and not an added on steel piece, plus it helps with a little extra structural strength.
Picture #1: Shows the countersunk bolt attaching the stop from underneath.
Picture #2: Shows what it looks like after the bolt had been welded over and ground down to hide the repair.
Picture # 3: A close up of the new steering stop.
Picture #4: Shows the finished steering tower.
ID:	263889   Click image for larger version
ID:	263890   Click image for larger version
ID:	263891   Click image for larger version
The Following 5 Users Say Thank You to JFred For This Post:
  #34
Old 09-25-2016, 10:42:44 PM
Charlie1925 Charlie1925 is offline
JFred; Looks like your coming along just fine on your tractor. What has to be done to the engine and the drive train? There is another Sears tractor man in Wisconsin that has several of those tractors, He is just above Lake Winnebago, If you want to get in tough with him let me know and I well send him a land line. Have fun on the rest of your project. Roger Weinhold AKA Charlie 1925
Old 09-28-2016, 10:11:25 AM
Heres the 1939 Sears Economy at the Republic,MO show....Its serial #1376....It has 13x38 Wards Power-trac tires on it....A friend is going to try and get the serial # for the 1939 model thats in SE Kansas..
The Following 2 Users Say Thank You to 1206SWMO For This Post:
  #36
Old 09-30-2016, 10:54:24 PM
JFred's Avatar
Hi Charlie1925- The engine that came with it is supposed to be an excellent runner but we will find out...haha! However the drivetrain is going to have to be gone completely through since it has been sitting out in the elements. I'm sure you are referring to John Baum from Appleton? If so, he has 16 of them and brought them all to our National Graham-Bradley and Sears Sold Farm Tractors Show in Penfield, IL this year. He is a very faithful club member! Thanks!
---------- Post added at 10:54:24 PM ---------- Previous post was at 10:51:53 PM ----------
1206SWMO- Thanks a bunch for the serial number and look forward to hearing about the other one! I will pass it along to the gentleman who keeps the registry up to date and see if he already knew of that tractor.
  #37
Old 10-05-2016, 11:58:44 AM
I assume that this is the guy from Wisconsin with (16) tractors...I took these pictures at the 2013 Half Century Of Progress Show...
The Following 5 Users Say Thank You to 1206SWMO For This Post:
  #38
Old 10-05-2016, 02:27:21 PM
oldjdinterest oldjdinterest is offline
Amazing! Such a big load behind that Chevy van !
Not possible here in Holland.
The Following User Says Thank You to oldjdinterest For This Post:
  #39
Old 10-10-2016, 03:32:54 PM
JFred; Yes to John Baum in Wis. I have met him at several shows from N .Carolina to way down in Fla. He seems to realy know Sears tractors . Roger Weinhold AKA Charlie 1925
The Following User Says Thank You to Charlie1925 For This Post:
  #40
Old 10-13-2016, 10:05:39 PM
JFred's Avatar
John has now upgraded to a Ford F-650 and moved the van body with the sleeping quarters in it to the new rig. He hauls them on three 40' tri-axle trailers and one smaller trailer!
Steel Wheel Restoration (1938 Allis Chalmers WF) K.Novak Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 19 09-18-2015 12:52:31 AM
1938-42 Sears Handiman WT DR Blue Garden Tractors and Mowers 2 09-09-2015 11:45:58 PM
Economy Engines 1938 Sears Catalog Plntdctr Hit & Miss Gas Engine Discussion 1 10-11-2013 08:54:19 PM
Sears 500/ Briggs B restoration started thetractorfreak Small Air Cooled Gasoline Engines 0 11-14-2011 10:44:35 PM
Corrrect Color for 1938 Sears Model Y Stevie Small Air Cooled Gasoline Engines 2 06-28-2010 12:14:40 AM
