Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Wood Shop and Projects
Wood Shop and Projects Engine Skids & Carts, Pattern Making, General wood shop projects and tools.
Free Drill bit old
this thread has 11 replies and has been viewed 2543 times
Old 12-25-2016, 08:44:01 PM
Billy J Shafer's Avatar
Default Free Drill bit old
Helping a friend clear out a barn. Found these in a bag. I have no use for them.If anyone can use them. Send me an address on PM
Old 12-25-2016, 09:30:48 PM
Default Re: Free Drill bit old
Make to fit a "yankee" hand brace.
Doc
Old 12-26-2016, 09:31:30 AM
Those two are spoken for. But I still have a barn to go through. About fifty years of storage to look through.
Old 12-26-2016, 02:37:00 PM
Power Power is offline
I have 2 of the hand braces and a bunch of those bits. Haven't used them in over 25 years. I know People have tried cutting off the shank and chucking them in a drill, with poor results.
Old 12-26-2016, 03:09:22 PM
CharlieB CharlieB is offline
Not rare.
Can still buy these auger bits from any number of suppliers, either with the square tang, or with a smooth shank to fit a power drill. They work really well in a good slow speed 1/2" drill motor with the second handle to counteract the torque. I use these on all my timber projects. Much better than paddle bits for deep, accurate holes.
The Following 2 Users Say Thank You to CharlieB For This Post:
Old 12-26-2016, 04:25:12 PM
Vanman Vanman is offline
Yes, I too have used the modern versions of these "ship augers" (that's the name I heard for them?).
A nice, big, SLOW drill motor, and if you can hang on, man will these suckers DRILL!!
Old 12-26-2016, 06:34:53 PM
Originally Posted by akuna View Post
A bit different use by Electricians. Even have a nail cutter version as I recall. Use a 2 handed drill and if they catch, they will screw you into the ground..
Yup, that is what I use.
Everyone buys the big "line Hog" angle drill with the 13 amp motor. I had seen what they can do - actually saw a broken wrist, more than one smashed hand with broken bones!!, people on ladders getting screwed, and getting off balance and falling.
I bought the smaller 5.5 amp Magnum, and used it daily for over 10 years without a problem. Electricians do not normally have to bore big holes. A lot of the holes we drill are overhead, thru floor joists, and holding that line hog over your head is a back killer.
Plumbers drill big holes and need the line hog.
Best I can say is use 2 handles and try to set it up so that when (not if) bit catches, the handle you kept you hand off of hits something solid, giving you time to stop drill. When that is not possible, I used to tell people to wrap a few turns of the plug end of the extension cord around something solid, like a stud, and set it up so drill cord does not have much slack. When bit grabs and drill spins, it unplugs and drill stops.
Old 12-26-2016, 06:58:31 PM
Rex Wellendorf Rex Wellendorf is offline
Hi,
I learned that you need to dull the lead screw slightly to help control hogging when using a augur bit in an elect. drill. My 2˘.
Rex.
Old 12-26-2016, 07:25:04 PM
DustyBar DustyBar is offline
We used a 1" chuck drill on some shear connector ring grove. It took 2 guys to operate. One guy would run it himself but he wore a note on his back to "unplug me after the third time around", clown.
Old 12-26-2016, 07:57:23 PM
Tom Marshall Jr.'s Avatar
Tom Marshall Jr. Tom Marshall Jr. is offline
Images: 1
have you ever seen what my father called a post drill, it was several ft. long, you put your foot in a hoop on the floor , loosened a thumb screw and pushed the drill part up to the floor joist. tighten the thumb screw push the bit against the wood and pull down this strap that turned the bit. it had a ratchet when the strap went back up. a hand drill to drill holes while standing on the floor overhead. it took the bits with the square on the end like the hand brace.
The Following User Says Thank You to Tom Marshall Jr. For This Post:
Old 12-28-2016, 02:26:39 PM
Images: 1
I must be to old. happy hollidays
Old 01-05-2017, 04:06:21 AM
Frank46 Frank46 is offline
Was given one of those old slow drill motors. Lent it to a buddy who was building a gazebo out of some pressure treated wood. Told him to watch out as it will move him around if the bit got stuck. Actually it is setup to run either forward or in reverse. There is a big ring on the main body that you turn for rotation. And yes it is a two handed drill. Lately been using it for drilling holes in tree stumps and soaking in diesel oil to burn out the stump. Stick my generator in the little cart I have for my riding mower so don't have to worry about burning it up due to not enough voltage. Old but still works. Fran
*FREE*FREE*FREE* (well, I'll trade for a cup of coffee) JohnnyC Onan Generators 14 07-02-2015 09:25:33 AM
Drill Doctor-- related to old drill bit post Pete Spaco Machine Shop and Tool Talk 1 03-11-2012 04:47:28 PM
5 row hoe drill Old Kansas Horse Drawn Equipment 1 11-20-2011 01:12:51 AM
Should I Drill it? (I WIN!!) Mike Schweikert Hit & Miss Gas Engine Discussion 4 11-27-2009 11:53:44 PM
Core Drill (pilot drill bit) bruce burgess Machine Shop and Tool Talk 10 12-22-2008 02:22:05 PM
