Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Wood Shop and Projects
Wood Shop and Projects Engine Skids & Carts, Pattern Making, General wood shop projects and tools.
Plans to build an all Wooden Wood Lathe pre-1820
this thread has 6 replies and has been viewed 1728 times
Old 07-05-2017, 02:41:07 AM
Cornpone Cornpone is offline
Default Plans to build an all Wooden Wood Lathe pre-1820
Hey all. Saw my uncle for the first time since he retired and moved to Florida. He said that he pretty much has broken all of his modern wood turning lathe components and can't sleep at night dreaming about a treadle wood turning lathe. He says that if he makes one he can impress his new friends.
What he says he needs are; some original plans or drawings pre 1820 (ish) of a wood turning lathe. He turns bowls and for some reason wants to make the lathe authentic. Prob is a crowd pleaser. His e-mail is: Oldflyboy@gmail.com
Old 07-05-2017, 03:12:38 AM
Default Re: Plans to build an all Wooden Wood Lathe pre-1820
Try google books. Can set search period. Think option is under "other".
Doc
1819 alright? (Description only, sorry no illistrations.) https://books.google.co.in/books?id=...design&f=false
But 1800 wood lathe returned these images: https://www.google.com/search?num=10...UG-dypSCefpgM:
Old 07-05-2017, 09:48:26 PM
CharlieB CharlieB is offline
You might like to email Uncle this link........
http://www.woodworkers-online.com/20...n-treadle.html
The Following User Says Thank You to CharlieB For This Post:
Old 07-05-2017, 09:51:51 PM
JoeCB JoeCB is offline
I'm sure that building and using a "man" powered wood lathe, treadle or spring pole will be fun project. However I'm pretty confident in saying that he will not be turning any bowls. This opinion is based on experience that we have at our Early Skills Village with a "great wheel" lathe. Wood lathe, rope drive from a hand cranked 4 foot diameter heavy wood wheel. Even with a young energetic "cranker" power is only sufficient for 2 - 3 inch spindles, file handles etc. I suppose that one could consider the power input equivalent to perhaps a 1/8 HP motor, and then only for short durations.
Joe B
The Following User Says Thank You to JoeCB For This Post:
Old 07-05-2017, 10:19:51 PM
s100 s100 is offline
I sort of recall a set of plans in Fine Woodworking magazine back some time in the 80's for a nice wooden treadle lathe. I always wanted to build one but somehow that particular issue of the magazine went missing (which is why I can't tell you any more, beyond the fact that it was a nice looking lathe)
Here's a link to the article, which was published in March 1979:
http://www.finewoodworking.com/2010/04/26/treadle-lathe.
You can see a picture of the lathe and a shrunk down page of the article. It says to read the article you need to sign up for a 14 day free trial, which sounds fair enough, if you r dad likes what he sees.
The Following User Says Thank You to s100 For This Post:
Old 07-06-2017, 12:18:40 AM
I have a friend who goes around the USA demonstrating bowl turning with a Spring Pole Lathe. He built it himself. It's almost all wood, except for the spindle and tailstock screw. The "secret", if there is one, is in the shape of the tools.
http://www.rogerabrahamson.com/index.html
I watched him often when we were demonstrating across from each other in the Blacksmith shop at the Minnesota State Fair. (He doing the woodturning and me the blacksmithing). He also turns chair spindles, but likes the bowls best.
You could probably contact him and ask for plans.
Pete Stanaitis
The Following User Says Thank You to Pete Spaco For This Post:
Old 07-06-2017, 04:25:22 AM
Lonnie Grissom Lonnie Grissom is offline
get him a copy of old ways of working wood by Alex w. Bealer. You should be able to get one on line or your local book stor can order you a copy. It has a plans for spring pole and treadle laths.
The Following User Says Thank You to Lonnie Grissom For This Post:
Wooden & Little Pump Cart Build Jim Alexander Hit & Miss Gas Engine Discussion 1 01-01-2016 09:30:12 PM
Someone To Build PM Research Engine & Wood Shop Kits ArmyMedic79 Scale Model Engineering 2 10-02-2015 09:14:05 PM
Need Build plans for Case Water Wagon any scale. Ted C Steam Stationary Engines, Traction Engines 0 10-19-2010 10:01:49 AM
What have I got here, Wood or metal lathe? Randy Hart Machine Shop and Tool Talk 7 09-25-2009 10:37:54 PM
