Go Back   SmokStak > SmokStak® General Discussion > Antique Motorcycles
Antique Motorcycles All about finding and fixing old motorcycle engines and vintage bikes.
Antique Motorcycles
My new garage find. BMW
this thread has 11 replies and has been viewed 2018 times
Old 10-31-2017, 09:23:39 PM
Firewoodguy's Avatar
Firewoodguy Firewoodguy is offline
Default My new garage find. BMW
My brother and I came about this cycle over the summer thru word of mouth. Was told to come take a look at it and I finally made the time this evening to check it out and couldn't pass it by. Been covered up in a local garage since 1981. It's a 1 owner 1956 BMW R50 with orig owners manual! Gonna need tires and a freshin up from what I see. Tank is clean and got good compression. A good start! Never owned a bmw, but hear they are a comfortable ride. 😎🏍.
The Following 10 Users Say Thank You to Firewoodguy For This Post:
Old 11-01-2017, 12:21:54 AM
JimDoyle JimDoyle is offline
Default Re: My new garage find. BMW
Nice find!!!!!!!......
Cheers
JIm
The Following User Says Thank You to JimDoyle For This Post:
Old 11-01-2017, 05:28:03 AM
Deerlope Deerlope is offline
Images: 1
A nice find indeed!!!!!!!!!!!!!!!!!
The Following User Says Thank You to Deerlope For This Post:
Old 11-01-2017, 05:49:46 AM
Target Driller Target Driller is offline
Thumbs up Re: My new garage find. BMW
A classic!
The Following User Says Thank You to Target Driller For This Post:
Old 11-01-2017, 11:11:32 AM
OrgWayne OrgWayne is online now
Say what is next to the bike , just snoopy !
Wayne
Old 11-01-2017, 01:03:26 PM
Wayne
Hi Wayne, that's a sears lawn tractor I believe from mid to late 1960's.
The Following User Says Thank You to Firewoodguy For This Post:
Old 11-01-2017, 02:28:00 PM
BobSaunders BobSaunders is offline
Nice find, I owned a R 60 600CC. They also made a R 69's which was slightly faster. Almost bought a new one. Nice ridding and it has the Earl's leading link front forks, which I found you had to make it go around corners. Not just lean in.
around 1966 they came out with telescopic front forks. If you check the rear springs their should be a handle to change the softness. Also the drive shaft housing at the rear wheel had I think a plug on top to put lube in for the bearing. My Goldwing had a grease nipple.
---------- Post added at 02:28:00 PM ---------- Previous post was at 02:18:39 PM ----------
I cannot see in the picture but mine had a slider for the air intake for winter starting. To start it hold down the "tickle button" on top of the Bosch carburetors until gas runs out and stand facing it and step down the start lever.
I got to where if I stalled it in traffic dragging Broadway I could stand over it and kick start it. I bought a used solo seat for mine witch made the ride even smoother. I won't talk about the day a nurse asked me to take her for a ride with her tight nurses uniform on. well maybe later.
The Following User Says Thank You to BobSaunders For This Post:
Old 11-01-2017, 11:24:09 PM
Motormowers's Avatar
Ive rode a 58 like that. Great bikes but handle funky with the Earls fork. And shifting is tricky. Dont baby it just shove it right in or you'll go right past the next gear and be between gears. Its a learning curve. Oh and they clunk into gear when shifting thats normal. As far as the tickler valves on the carbs dont even bother. Those carbs will be leaking and flooding on their own sitting there and will give the engine plenty of fuel for starting LOL
Remove the all rotten apples out of your basket of life and toss them in the trash where they belong.
The Following User Says Thank You to Motormowers For This Post:
Old 11-02-2017, 12:14:27 PM
gootsch gootsch is offline
They are great bikes. They do shift like old Mack trucks, you have to wait for them. I could reach over the seat and push the starting lever with my hand and start it. The electric system is only 6v and 60 watts so the headlight is not very bright for night riding in the country. I wish that I had never sold mine. Look inside the headlight, the wiring may be getting crispy. I loved the Earls fork. Not a quick bike but very smooth and fast. Heavy flywheel like a John Deere 2 cylinder tractor. Yours is about 25 horse power. Put hardened exhaust valves and rotators in or you will be doing the valves every 3,000 miles or so. The Bing carbs are very simple and trouble free. It has drum brakes and is not like stopping a modern disc brake equipt bike. There is lots of support out there for these old Beemers. Read the owners manual as there are some things in there that will surprise you. Make sure that you get the tool kit, it is extensive and has all the tools to do a valve job except the valve spring compressor.
The Following User Says Thank You to gootsch For This Post:
Old 11-09-2017, 08:36:23 PM
We were lucky to find an original seat and got it mounted and running with some tinkering. Here is a video. https://www.youtube.com/watch?v=qI9c_ATHLbU
The Following 4 Users Say Thank You to Firewoodguy For This Post:
Old 12-04-2017, 01:27:18 PM
Countryslim Countryslim is offline
SweeT!... Never owned a Beemer but I've had friends that rode them a lot. I've owned several Triumphs from 1950 up to 1970, also had a Norton and a 69 650 BSA lightning and a 250 BSA, a Starfire I think, blue and white fiberglass gas tank... Just love them old scoots. I still have a box of Triumph bolts, nuts and small parts.
---------- Post added at 11:27:18 AM ---------- Previous post was at 11:20:33 AM ----------
I sold a 64 model Sears Roper to a friend. It had the 10 Hp Tecumseh, high and low range gearbox. He has restored it and loves it. I have two Cub Cadets with the ten hp Tecumseh, one is a 68 model Hydrostatic Drive with the Generator starter system, runs good and the other is a 72 or so and it got burnt last year lightly when a storage building next to it burned. That garden tractor in the Pic does look like a Sears or a Montgomery Wards, can't tell.
Old 12-04-2017, 01:47:36 PM
Looks good! a guy here in town has one with a side car - carries his dog all over the town, in it!
Quincy Engine GARAGE FIND! Firewoodguy Antique Gas Engine Discussion 18 09-13-2017 08:32:52 PM
Garage find Clayton Wisconsin Engines 12 02-22-2016 07:49:48 PM
Garage Sale, new find today! Greg-N-CA Antique Gas Engine Discussion 8 06-29-2015 10:46:50 AM
Garage Find Briggs and Pump Bob Geyer Garden Tractors and Mowers 1 03-14-2011 08:23:59 PM
Todays Garage Sale Find Jon Rozevink Steam Stationary Engines, Traction Engines 7 05-03-2010 04:03:37 PM
