Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Wood Shop and Projects
Wood Shop and Projects Engine Skids & Carts, Pattern Making, General wood shop projects and tools.
Dating Older Plywood Chests - Actual 3/4" Thickness Ply
this thread has 1 replies and has been viewed 1152 times
Old 11-19-2017, 02:48:42 AM
tabbyapple tabbyapple is offline
Default Dating Older Plywood Chests - Actual 3/4" Thickness Ply
I have three massive 40" x 24" hinged chests each weighing over 45 pounds. The top hinged lid and fixed bottom are made from 3/4" thick plywood with dado edges for the 3/4" thick wood plank sidewalls. Each case has a outer glossy finish, hinges, latch, and metal sliders on the bottom (one with steel ball bearings). Research indicates that these were made by a WWII veteran to store linens. Darkened 1955 newspapers were used as packaging around some items, thus I think they were likely made in the 1945 to 1955 time frame.
I know the actual dimensions of wood products have gradually decreased in size over time but was wondering if there was a general time frame when 3/4" plywood was decreased in thickness. Perhaps they might be made from a special grade of plywood that retained the 3/4" actual thickness verses regular construction plywood.
Old 11-24-2017, 07:34:13 PM
tdmidget tdmidget is offline
Default Re: Dating Older Plywood Chests - Actual 3/4" Thickness Ply
Cabinet grades ( which yours appears to be ) and marine grades are on the nominal size. Construction grades are undersized.
Husky Tool Chests ronny p 148 Machine Shop and Tool Talk 7 09-06-2016 09:23:23 PM
Looking for a 24" Thickness Planer Beez Machine Shop and Tool Talk 1 02-23-2011 11:24:13 AM
Dating a Briggs "P" Tom Schaech Antique Engine Archives 0 06-04-2004 11:34:47 AM
