1931 Hupmobile Coupe
this thread has 11 replies and has been viewed 2433 times
Old 12-13-2017, 04:57:28 PM
Marcel P's Avatar
Marcel P Marcel P is offline
Default 1931 Hupmobile Coupe
Hello
A good friend has this Hupmobile Coupe. It is very nicely restored but stood in a museum for many years. Over the coming weeks I will see if I can start the engine. I haven't inspected it yet and am sure I will have some questions! The serial # on the engine is S44272. Here are some pictures, any information is welcome.
Regards
Marcel
ID:	298334   Click image for larger version
ID:	298335   Click image for larger version
ID:	298336   Click image for larger version
The Following 11 Users Say Thank You to Marcel P For This Post:
Old 12-14-2017, 02:16:00 PM
Default Re: 1931 Hupmobile Coupe
Interesting...
"Stood in.museum for many years..." (after restoration, I assume)...
But pic looks like private garage/shop building...
If so, how did car get from museum to garage/shop?? transported?? driven??
If driven, how long ago?? How long, in other words, has engine been dormant??
The internet, and these forums, are full of directions/suggestions re' starting/running dormant engines, many time-sensitive: generally, the longer the engine sat, the more detailed/careful you need to be to avoid possibly damaging gummed-up/corroded internals and/or externals, like dist, fan bearings, water pump,,,
I assume your friend has or will join the Hupp Club, whose members should know of any 1931 idiosyncrasies...
My apologies, of course, if your being unclear is due to being unfamiliar with some of the finer nuances of English, often called a difficult language...we all too often have trouble with it ourselves...
The Following User Says Thank You to Bud Tierney For This Post:
Old 12-14-2017, 05:53:02 PM
Marcel P's Avatar
I am almost sure it was restored in the USA, and at the end of the nineties came to Holland and was in a museum there until a few weeks ago. So I thinks it did not run the last 20 years. It is in my garage at the moment, we got it here in a closed truck. Before even attempting to start I will carefully check the engine.
Regards
Marcel
ID:	298318   Click image for larger version
The Following User Says Thank You to Marcel P For This Post:
Old 05-01-2018, 01:15:41 PM
Marcel P's Avatar
Well it started yesterday! After having replaced the fuel pump and with a temporary tank it fired up right away and runs sweet. There was a bad contact in the starter but easy to sort out.
Marcel
ID:	309627   Click image for larger version
ID:	309628   Click image for larger version
Old 05-01-2018, 02:54:17 PM
Very nice!!
Old 05-07-2018, 01:46:17 AM
Matt Montague Matt Montague is offline
Here is picture of our 1931 model C. right after i pulled it from the museum/barn it was in.
The Following 5 Users Say Thank You to Matt Montague For This Post:
Old 05-07-2018, 10:28:02 PM
Dwayne Fuller's Avatar
Dwayne Fuller Dwayne Fuller is offline
So nice to see these cars come out of a museam so they can be driven and enjoyed. Way too many old cars are sitting idle, collecting dust.
The Following User Says Thank You to Dwayne Fuller For This Post:
Old 04-20-2019, 12:39:06 PM
Marcel P's Avatar
We drove the Hupp some 600 miles over 3 days two weeks ago, what a nice car to drive! Almost no troubles except a flat tyre and the dynamo that gave up on the second day. Luckily the weather was good so no lights needed, the battery lasted long enough. I still have to look for the dynamo problem, but as it is driven by the distribution chain it will not be an easy fix I'm afraid. I am therefor looking to fit a 6V alternator above the dynamo and use a longer fan belt. Has anyone done this before, any hints or tips out there? I could not find the right oil filter, so made up two adapter washers for an easy to find filter.
All the best
Marcel
ID:	333076   Click image for larger version
ID:	333077   Click image for larger version
ID:	333078   Click image for larger version
The Following 7 Users Say Thank You to Marcel P For This Post:
Old 04-20-2019, 02:03:06 PM
Vanman Vanman is offline
The generator should be very easy to fix. Those systems are super simple. A loose wire, a dirty contact, a sticky brush. There is no reason to not repair. And much easier than cobbling together something that doesn't belong. I HATE seeing modern stuff under the hood of antiques!
The Following 5 Users Say Thank You to Vanman For This Post:
Old 04-22-2019, 12:12:37 PM
Marcel P's Avatar
I will try to repair the dynamo, but even if an alternator will be added this will be done in a 100% reversible way. Will keep you all posted.
Thanks, Marcel
The Following 3 Users Say Thank You to Marcel P For This Post:
Old 04-22-2019, 04:32:01 PM
OTTO-Sawyer's Avatar
I don't know if a 31 Hup has an "Open" or "Closed" Driveshaft, but if it's "Open" you could mount an alternator underneath and run it off a pulley added to the driveshaft.
It wouldn't do anything when standing still, but would charge normally when driving in high gear where the driveshaft matches the engine speed.
The Following 3 Users Say Thank You to OTTO-Sawyer For This Post:
Old 04-22-2019, 05:28:47 PM
casertractor casertractor is online now
http://clubs.hemmings.com/hupmobile/
The Following 2 Users Say Thank You to casertractor For This Post:
1940 Packard 110 coupe oldsoldster Antique Autos and Trucks 6 07-01-2017 09:53:02 AM
Paging Bud Tierny... 1932 Hupmobile Engine Craig A Antique Autos and Trucks 20 06-03-2014 07:53:26 PM
1937 Chevy Coupe CLips221 Antique Autos and Trucks 7 08-29-2013 08:56:07 PM
1930-31 model A coupe Robert M Antique Autos and Trucks 6 06-13-2013 07:11:28 PM
