Steam Engines
Side Lever Engine
this thread has 123 replies and has been viewed 7831 times
Old 06-18-2018, 02:28:59 PM
dave stevena dave stevena is online now
Default Side Lever Engine
hello all
this is a basic drawing of a side level steam engine 1840s used in the first naval steam powered war ship USS MISSISSIPPI
because the drawing is very simple it lacks all the "working" details of how such an engine works.
does anyone know if such an engine survives in a museum or know of any drawings of such an engine?
these were designed in England and became the standard marine engine so there must be working drawings someplace.
cheers
dave
Name:	steam engine.jpg
The Following 3 Users Say Thank You to dave stevena For This Post:
Old 06-19-2018, 12:24:44 AM
Ryan Williams Ryan Williams is offline
Default Re: side lever engine
Maybe I'm blind to something but it seems to me that it's almost identical to a normal walking beam engine, just with the beam located to the sides rather than the top. Looks pretty neat anyways!
Old 06-19-2018, 06:57:41 AM
Jim Mackessy Jim Mackessy is offline
Default Re: Side Lever Engine
That "cathedral" frame looks an awful lot like the Novelty Iron Works engine at HFM. They did build naval engines and built parts of the "Monitor", although the Monitor's engines were built by another. There were a lot of designs like these trying to keep the center of gravity low for use on ships. There is a list of all the engines the Novelty Iron Works built on line, I can't remember where I've seen it. - JM
Old 06-19-2018, 08:26:34 AM
Asquith Asquith is offline
There are a few side lever engines preserved. There's a late-model one in the tug Eppleton Hall, preserved in San Francisco. This has a grasshopper side lever engine, though:-
http://www.tynetugs.co.uk/eppletonhall-engines.html
There are at least two smallish single cylinder examples preserved on land in the UK.
Name:	JD 2011 Napier01.jpg
ID:	312714 1 Click image for larger version
Name:	JD 2011 Napier02.jpg
ID:	312715 2 Click image for larger version
Name:	JD 2011 Napier04.jpg
ID:	312716 3 Click image for larger version
Here are some photos of a beautiful model in Liverpool Maritime Museum. It represents the engine of the paddle steamer Berenice built in 1836 by Robert Napier.
The Following 5 Users Say Thank You to Asquith For This Post:
Old 07-28-2018, 10:40:49 AM
I have about 60 drawings for a steam engine I would like to post. The reason for posting the drawings is to see if there is enough information to build a scale model. This is looking like a jig saw puzzle of pieces and parts so I need to identify the drawings and where the parts go. I have never seen a complete steam engine like this so to figure this out will require someone who knows steam engines, Because there are so many drawings and I can only post 4 at a time this will take a lot of posts for all the drawings.
The drawings are images of the originals so in some cases they may be difficult to read
ID:	315097   Click image for larger version
ID:	315098   Click image for larger version
ID:	315099   Click image for larger version
The Following User Says Thank You to dave stevena For This Post:
Old 07-28-2018, 10:42:19 AM
the next 4 drawings
ID:	315101   Click image for larger version
ID:	315102   Click image for larger version
ID:	315103   Click image for larger version
Old 07-28-2018, 10:43:25 AM
drawings 9 to 12
Old 07-28-2018, 10:45:33 AM
oops 9 to 12
ID:	315105   Click image for larger version
ID:	315106   Click image for larger version
ID:	315107   Click image for larger version
Old 07-28-2018, 10:47:06 AM
drawings 13 to 16
ID:	315109   Click image for larger version
ID:	315110   Click image for larger version
ID:	315111   Click image for larger version
Old 07-28-2018, 10:49:03 AM
drawings 17 to 21
ID:	315113   Click image for larger version
ID:	315114   Click image for larger version
ID:	315115   Click image for larger version
Old 07-28-2018, 10:50:50 AM
drawings 22 to 25
ID:	315117   Click image for larger version
ID:	315118   Click image for larger version
ID:	315119   Click image for larger version
Old 07-28-2018, 10:52:16 AM
drawings 26 to 29
ID:	315121   Click image for larger version
ID:	315122   Click image for larger version
ID:	315123   Click image for larger version
Old 07-28-2018, 10:54:19 AM
there is about 44 more drawings of the engine to go
Old 08-04-2018, 05:22:23 PM
this is the bed plate for the engine I posted in the first post
can anyone tell me what the blue area is and does it go under the entire bed or just down the center
Name:	Bed Plate Plan1.jpg
Old 08-04-2018, 05:25:20 PM
I can see what the red part is and where it bolts to the bed plate
I do not know if the rings are raised above the plate surface or set into the surface
what is the blue part and where does it go
Name:	Bed Plate Plan2.jpg
Old 08-05-2018, 07:24:35 AM
Sandiapaul Sandiapaul is offline
Thanks for posting these drawings. Wonderful details. I think it would make a great model. Do you have any more info on this engine?
Old 08-05-2018, 09:46:28 AM
all I have are the drawings and that what's makes this difficult not knowing what it looks like assembled
the engine was used in the first naval steam frigate Mississippi 1840s
Old 08-05-2018, 03:56:55 PM
best approach to modeling this engine is starting with the basics and learn what the parts are. Once I got that figured out then understand what the parts do then I can figure out how they are built.
so starting with the basic
I need a cylinder and a condenser I don't know what "E" is
Name:	basic side lever1.JPG
Old 08-05-2018, 04:01:06 PM
ok a cylinder is the main steam drive so those rings on the bed plate have to seal the cylinder or you will be blowing steam out under pressure
Name:	a basic cylinder.JPG
ID:	315724   Click image for larger version
Name:	b basic cylinder.JPG
ID:	315725   Click image for larger version
Name:	basic side lever2.JPG
Old 08-05-2018, 04:03:53 PM
looking at the plan for the cylinder the 4 bolts look like a match to the bed plate
Sandwich engine magneto lever wan56 Hit & Miss Gas Engine Discussion 11 09-19-2017 07:45:25 AM
Two Otto and Langens Running side by side Jeff in PA Hit & Miss Gas Engine Discussion 0 08-17-2017 08:25:00 PM
Sandwich Engine Trip lever springs needed. ShaneZahn Hit & Miss Gas Engine Discussion 0 08-30-2015 08:34:56 AM
Powell-Lever Engine Gene Fisher Hit & Miss Gas Engine Discussion 2 05-11-2015 09:09:12 PM
Waukesha CU Engine Governor Lever Retainer Butch Rafferty Antique Farm Tractors 9 01-10-2014 10:42:30 PM
