Steam Engines
Side Lever Engine
this thread has 99 replies and has been viewed 6644 times
Old 08-05-2018, 04:07:16 PM
dave stevena dave stevena is offline
Default Re: Side Lever Engine
found out what "E" is
it's an air pump who knows what an air pump does?
Old 08-05-2018, 06:33:03 PM
Jeff Dudgeon Jeff Dudgeon is offline
Hi, the air pump will remove any non condescending gasses that make their way into the condenser. The condenser will operate at a vacuum, so it will draw in air from any little leak it can. The air pump will not have to remove much, as you will find the air leaks and seal them up when it runs.
Jeff
Old 08-06-2018, 01:12:03 PM
going back to post 14 and what the bottom of the bed plate was colored blue, I did a little checking
my guess is the top view square area is a condenser and the space below in the side view of the bed plate is the hot well where the water goes, in the bottom is a little well and what I assume is a pump shaft thus the green circle is a water pump pumping the water back to the boiler.
the yellow line is the size of the well
now to figure out a condenser I look a look in some old text books cira 1860ish
ID:	315773   Click image for larger version
ID:	315774   Click image for larger version
ID:	315775   Click image for larger version
Old 08-06-2018, 01:13:48 PM
and more about a condenser
ID:	315777   Click image for larger version
ID:	315778   Click image for larger version
ID:	315779   Click image for larger version
Old 08-06-2018, 01:16:29 PM
more on condensers
ID:	315781   Click image for larger version
ID:	315782   Click image for larger version
ID:	315783   Click image for larger version
Old 08-06-2018, 01:17:52 PM
the end of a condenser
and moving on to water pumps
Old 08-06-2018, 10:56:59 PM
Peter Short Peter Short is offline
Hi Dave,
Thanks for posting the old drawings, that's a rare treat.
Do you have image "engine 21" , it is missing from those you have posted so far.
For anyone's interest... I think the Edwards Air Pump is not just pumping water from the condenser but air and any non-condensable gases which come through from the engine. The trick is to remove the air and gases from the condenser without breaking the vacuum and this is what the Edwards does, a clever and simple design. Another of its features is that it doesn't have any foot valves, just delivery valves at the top which can be repaired or replaced without stopping the engine or losing vacuum (exactly how, I am not sure...). Quite often the Edwards air pumps were driven off the main engine but I have also seen them driven by their own engine.
Old 08-08-2018, 04:50:14 PM
https://www.shipsofscale.com/sosforu...72/#post-36949
I found a set of drawings labeled with the parts I would replace all the drawings here but I can not edit posts.
I would like to invite anyone interested in viewing all the drawings at the above link. You do not have to join a forum to view the drawings
this is a big task to ID the part and how and where it fits into the engine
The Following User Says Thank You to dave stevena For This Post:
  #29
Old 11-06-2018, 11:42:30 AM
I have been busy with CAD drawing this engine so far I completed the main frame and the condenser. Now the problem is how does this condenser go together. measuring its size I figured it goes in the blue area which also matches up with the bed plate
Name:	final frame.jpg
  #30
Old 11-06-2018, 11:45:04 AM
here is the master condenser drawing and closeup views of various parts.
Name:	condenser drawing 1.jpg
ID:	322243   Click image for larger version
Name:	condenser drawing 2.JPG
ID:	322244   Click image for larger version
Name:	condenser drawing 3.JPG
ID:	322245   Click image for larger version
Name:	condenser drawing 4.JPG
Old 11-06-2018, 11:47:24 AM
and the rest of the closeups
ID:	322247   Click image for larger version
Name:	condenser drawing 5.JPG
ID:	322248   Click image for larger version
Name:	condenser drawing 6.JPG
ID:	322249   Click image for larger version
Name:	condenser drawing 7.JPG
  #32
Old 11-19-2018, 11:20:35 AM
a progress report I finished the CAD drawings for the main frame, the cylinder, the condenser and the air pump
I wonder if these side lever engines had a lever on both sides of the frame or just one.
when the lever is on the top of the frame there is just one.
The Following 2 Users Say Thank You to dave stevena For This Post:
  #33
Old 11-19-2018, 09:46:20 PM
Your drawings look great. I am looking forward to seeing your progress.
Old 11-19-2018, 10:05:11 PM
Dave,
I am sure there would have been two levers, one each side of the cylinder.
The drawings are looking good!
Old 11-20-2018, 11:05:03 AM
thank you for the comments in about 3 maybe 2 weeks I will have a 3D model of the frame so you can walk around it and view it from all angles.
my plan
because I am not a trained a steam engineer I really do not know how this engine goes together so I will create all the parts as 3D models and try fitting them together.
Old 11-20-2018, 12:24:42 PM
details of cylinder the original drawings and the redrawn CAD
ID:	323247   Click image for larger version
ID:	323248   Click image for larger version
ID:	323249   Click image for larger version
  #37
Old 11-20-2018, 12:26:23 PM
more original drawings
ID:	323251   Click image for larger version
ID:	323252   Click image for larger version
ID:	323253   Click image for larger version
  #38
Old 11-20-2018, 12:28:25 PM
final original drawing
Old 11-20-2018, 12:30:14 PM
the original drawings are distorted and ripped so they were redrawn in CAD
Name:	re drawing1.jpg
ID:	323256   Click image for larger version
Name:	re drawing2.JPG
ID:	323257   Click image for larger version
Name:	cylinder assembled.JPG
  #40
Old 12-03-2018, 12:19:23 PM
and now for a sneak peek at the 3D modeling of the frame
ID:	323895   Click image for larger version
ID:	323896   Click image for larger version
ID:	323897   Click image for larger version
ID:	323898   Click image for larger version
The Following 3 Users Say Thank You to dave stevena For This Post:
Sandwich engine magneto lever wan56 Hit & Miss Gas Engine Discussion 11 09-19-2017 07:45:25 AM
Two Otto and Langens Running side by side Jeff in PA Hit & Miss Gas Engine Discussion 0 08-17-2017 08:25:00 PM
Sandwich Engine Trip lever springs needed. ShaneZahn Hit & Miss Gas Engine Discussion 0 08-30-2015 08:34:56 AM
Powell-Lever Engine Gene Fisher Hit & Miss Gas Engine Discussion 2 05-11-2015 09:09:12 PM
Waukesha CU Engine Governor Lever Retainer Butch Rafferty Antique Farm Tractors 9 01-10-2014 10:42:30 PM
