Coil Spring Needed
this thread has 7 replies and has been viewed 1071 times
Old 07-17-2018, 01:53:53 PM
Question Coil Spring Needed
Anyone have the name of a good spring maker? I need one 1/8" diameter round metal, about 11/2" diameter coil . It is a pulley return spring for an engine I am working on. It has 6 or 7 turns, with a long tail at one end and a 3/16 eye at the other end.
Old 07-17-2018, 04:34:09 PM
Nick's Avatar
Nick Nick is offline
Images: 41
Default Re: Coil Spring Needed
W.B. Jones Spring. Excellent workmanship and great service.
The Following 2 Users Say Thank You to Nick For This Post:
Old 05-28-2019, 01:51:54 PM
Marc L Marc L is offline
OmniCoil Spring Works in Brantford Ontario also winds springs. I needed new springs for the rear axel mounts on my 45 Case. The original springs are 3/4 square wire. OmniCoil will wind square wire springs where a lot of other manufacturers will not. I received a lot of good advice and "spring education" from WB Jones. They are very helpful. However, they could not wind square wire springs.
Old 05-28-2019, 02:49:32 PM
kwfiggatt kwfiggatt is offline
Century spring is another mfgr that has a LOT of stuff on their website --> Century Spring
They do custom springs, too...
Kevin
Old 05-31-2019, 01:13:52 PM
Tracy T Tracy T is offline
there is a spring shop practically in your back door, located in king of something PA. its been a few years, I may have their contact info if i can find it. king of persa PA sound right?
Old 05-31-2019, 01:25:57 PM
David Babcock David Babcock is offline
Smile Re: Coil Spring Needed
There are a lot of spring shops. I needed springs years ago when i was working on a 30 hp foos. I got all the springs i needed from the mc master carr catalog. They have a lot of springs and i thought reasonable too. Db.
Old 05-31-2019, 10:08:51 PM
JoeCB JoeCB is offline
Andrew, boy, if it weren't for the 3/16 eye, you could wind that from 1/8" music wire... no problem. Any creative way to anchor the wire end absent the eye ? clamp maybe??
Joe B
Old 06-01-2019, 12:08:41 PM
King of Prussia, Pa, maybe?
spring needed Dennis K. Nash Antique Gas Engine Discussion 8 07-24-2016 09:33:41 AM
Spring needed Gene Fisher Antique Gas Engine Discussion 16 06-12-2015 02:46:14 PM
Joining coil spring belting krawlr Machine Shop and Tool Talk 7 04-12-2010 07:23:03 PM
Pickering Governor Coil Spring source needed David Steam Stationary Engines, Traction Engines 2 12-15-2008 09:02:46 PM
Spring needed Joe Morris Small Air Cooled Gasoline Engines 1 09-12-2008 01:44:37 PM
