1986 Ford 250 4.9l
this thread has 5 replies and has been viewed 662 times
Old 11-18-2018, 07:10:59 AM
crank crank is offline
Smile 1986 Ford 250 4.9l
Just picked up F250, It spent most of it's live on a air force base, It has a hydraulic lift on the back that works good. I did some work to her it was back firing, change plugs, tightened the carb, valve cover gasket, air filter and oil change ( rotella 15-40 ). Now she runs smooth, had at least three of these engines before never had a problem with them. (knock on wood ).[ATTACH][/ATTACH]
Old 11-18-2018, 10:15:02 AM
78Loadstar 78Loadstar is online now
Default Re: 1986 ford 250 4.9l
Never seen a 4.9 go bad. Body always went first.
Dennis
Old 11-18-2018, 04:22:07 PM
Put some Locktite on those carb fasteners, else you will be back there about every 3rd oil change. Those are good engines, I have probably put 400K miles on various similar trucks.
Old 12-15-2018, 09:03:58 AM
Tracy T Tracy T is offline
just a few years newer they went with dual exhaust manifolds and multi port fuel injection, talk about waking up a sleeping beast! i am like every one else, never seen one go bad. the rest of the truck will fall apart before the motor goes. on a side note, doors that body style are damn near impossible to source should you need one.
Old 12-15-2018, 11:58:24 AM
Monsonmotors Monsonmotors is offline
Default Re: 1986 Ford 250 4.9l
Iím a veteran of working on these in the shop environment. My main complaint about the 4.9l is its weirdness. Weirdness translates to parts availability problems. I see 10 or more 5.0L/ 5.8l v-8s to one 4.9l 6 cylinder. Also, Iím not a fan of their multiple timing mark scheme. Very confusing.
Iíve done intake manifold gaskets on them so I know they go out.
Otherwise, good engine.
Old 12-15-2018, 09:24:24 PM
My 84 one ton had that motor. you will learn how to tighten the carb up. BTDT many times. lock tight would probably work if you pulled it apart to clean it all up.
Threshing from 1986 in Eastern Iowa rsieck Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 12-29-2014 11:07:52 PM
1986 Ford Brakes Jim Alles Antique Autos and Trucks 8 02-12-2011 06:33:55 PM
Onan 2.5 AJ 1986 and the 12V starter plug ronny p 148 Onan Generators 38 01-13-2011 09:57:02 PM
2.5 Onan AJ 1986 manufactured ronny p 148 Onan Generators 0 02-12-2010 11:50:59 AM
1986 Engine Sale John Merry Antique Gas Engine Discussion 29 06-18-2009 10:30:02 PM
