Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Antique Machine Tools (Pre 1930)
Help needed to identify H R SMITH wrench?
this thread has 7 replies and has been viewed 613 times
Old 12-22-2018, 10:13:45 PM
Firewoodguy's Avatar
Firewoodguy Firewoodguy is offline
Default Help needed to identify H R SMITH wrench?
I helped a friend recently clean up around his barn and came across this buried in the dirt. After little cleaning, I see castings H R SMITH. Any input much appreciated. Thank u
ID:	324966   Click image for larger version
ID:	324967   Click image for larger version
The Following User Says Thank You to Firewoodguy For This Post:
Old 12-22-2018, 10:35:45 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Default Re: Help needed to identify H R SMITH wrench?
I believe it's for straightening bent cylinder/ concave teeth in a threshing machine.
The Following 3 Users Say Thank You to FWurth For This Post:
Old 12-23-2018, 08:05:59 AM
never would have thought that. thank u. i was thinking maybe a lever for old jack stand?
Old 12-23-2018, 10:24:17 AM
FWurth's Avatar
One Millionth Post
Images: 4
Most threshing machines came equipped with one of those wrenches in the tool kit. My KG has one with it, a different mfg though. If some one lost their bundle fork into the feeder, usually a few spike cyl teeth would pay the price. Go to your tool box and retrieve your handy dandy tooth wrench, and your back in business with out too much delay. There was also a long socket like wrench for turning the nut on the shank of the tooth when replacing them. Remember this was in the days before most folks had anything like the modern socket wrenches that we all have today, most any implement came with it's own wrench set to make the repairs needed. The only reason I know so much useless information is that I collect too much useless (today) junk and read a lot. That and the fact that I'm also old as dirt!
Old 12-23-2018, 12:49:19 PM
Heins Heins is offline
FW, I think you are correct. Here is a picture of my dad's from his CASE threshing machine. Hope you have a Merry Christmas!
ID:	324980   Click image for larger version
The Following 2 Users Say Thank You to Heins For This Post:
Old 12-23-2018, 01:50:56 PM
FWurth's Avatar
One Millionth Post
Images: 4
You will note that both tools above have 2 working slots. One to bend the tooth and one to twist the tooth back in alignment as well as hold it straight while tightening the spike.
Old 12-23-2018, 03:12:21 PM
It looks like the CASE tooth has a hex on the bottom that holds it in alignment when you tighten it. Does the hex part of the tooth go into the bar on the cylinder?
Old 12-23-2018, 03:33:47 PM
FWurth's Avatar
One Millionth Post
Images: 4
Yes, those teeth are designed with that feature to prevent them from rotating under use. The running clearance is close and if one were to get turned it would get hit by the other teeth going past and likely break off and take others with it.
Help needed to identify old plow Firewoodguy Horse Drawn Equipment 7 08-29-2017 07:42:24 PM
Identify this wrench - spanner JoeCB Machine Shop and Tool Talk 2 01-08-2014 09:53:36 PM
smith motor wheel parts needed smith motor man Hit & Miss Gas Engine Discussion 0 01-07-2013 07:29:19 PM
Help needed to identify an Air Compressor Andyt001 Unidentified Engines 2 06-22-2012 05:19:53 AM
IHC wrench info needed Jason Weinke Antique Engine Archives 1 09-15-2002 05:20:37 PM
