Go Back   SmokStak > SmokStak® General Discussion > Smokstak Canada
Smokstak Canada For Canadian Smokstakers to meet, greet and have local discussion.
Smokstak Canada
Winter Project Hot Air Engine
this thread has 6 replies and has been viewed 588 times
Old 01-22-2019, 11:13:45 AM
Mike Unwin Mike Unwin is offline
Default Winter Project Hot Air Engine
Good Day,
About 20 or more years back my brother Steve and I each built home made hot air engines I don,t know who we got the idea from but we each built one .
They are simple to build and cheap the only part I bought was a couple of small roller bearings, tools were basic too just a drill, hand coping saw, small torch to solder.
If anyone is interested in a winter project I can post dimensions and descriptions of parts.
For parts you will need a used shock absorber ,soup tins,pasta tin and brass rod I used old brazing rod .Since I built without plans it was trail and error that,s why the rods were soldered in the middle.So if anyone is interested post on and I will post the info .Not sure if Sterno is still made I think a small kerosene or even butane burner might be cheaper Cheers Mike
Name:	Hot Air Engine 1.jpg
ID:	326897   Click image for larger version
Name:	Hot Air Engine 2.jpg
ID:	326898   Click image for larger version
Name:	Hot Air Engine 3.jpg
ID:	326899   Click image for larger version
Name:	Hot Air Engine 4.jpg
The Following 7 Users Say Thank You to Mike Unwin For This Post:
Old 01-22-2019, 01:16:44 PM
Default Re: Winter Project Hot Air Engine
Neat engine Mike
www.sternoproducts.com
Old 01-22-2019, 08:18:39 PM
Contaucreek's Avatar
Contaucreek Contaucreek is offline
Cool Mike! Sterno is still available. Look towards a party rental place, they use them for the chafing (sp) dishes, like at a buffet. Thumbs up!
The Following 2 Users Say Thank You to Contaucreek For This Post:
Old 01-23-2019, 11:08:52 AM
Thought I would go ahead and list the parts if not this winter but maybe sometime someone will want a engine project that can be carried with one hand made with hand tools and common parts.
So the wood parts
Deck 6 " x 15 " pine or plywood
Flywheel post 6.5 " x 1.5 " x 1.5 " pine or spruce whatever you have
Cylinder post 6.5 " x 2.25 " pine
Walking beam 14 " x 1 " this was over done on my part should have been tapered
Upright post 15 "
Legs on mine were 3" to suit Sterno can next I would use the bottom of a hurricane oil lamp better control of flame and cheaper to run !
---------- Post added at 10:08:52 AM ---------- Previous post was at 09:49:12 AM ----------
About the flywheel I used .5 plywood next one I build will try a sheave from a Duro water pump to make it look more engine like.
Flywheel 8" x .5 plywood with 2 " holes
The Following 2 Users Say Thank You to Mike Unwin For This Post:
Old 01-23-2019, 11:47:41 AM
DustyBar DustyBar is online now
What are the sizes of the pistons and the stroke length for each? How did you make and fit the smaller piston? I assume the large can has water in it to make the seal for that piston.
The Following User Says Thank You to DustyBar For This Post:
Old 01-23-2019, 01:45:14 PM
Folks I just found the plans I thought long lost and this was not my design it came from Darryl Boyd so credit where credit is due .
Sorry about that but at the bottom of the junk drawer there they were so here is the link...........http://boydhouse.com/stirling/
DustyBar maybe take a look there first if not maybe I can help you .Cheers Mike
Old 01-23-2019, 02:41:00 PM
January, 1990, issue of Scientific American, had a simple stirling engine too. I hesitate to post it here since it is copyrighted material. I'll post two pages to give an idea of how it was built. I have not built it.
Thanks, Mike. Lots of good ideas at that web site. Good thing its still around.
ID:	326950   Click image for larger version
The Following 2 Users Say Thank You to DustyBar For This Post:
Engine did not sell, so now its my winter project Eric McKenna Antique Gas Engine Discussion 3 12-12-2011 06:30:02 PM
Winter Project engine kits suppliers? speleausmining Scale Model Engineering 6 09-29-2010 03:03:47 PM
Winter Project Smoke Antique Engine Archives 13 10-10-2004 03:58:35 PM
winter project Randy Peterson Antique Engine Archives 12 10-03-2004 12:08:22 PM
