Moline Universal D
this thread has 20 replies and has been viewed 2529 times
Old 01-27-2019, 11:09:35 PM
Ben Zimmerer Ben Zimmerer is offline
Default Moline Universal D
I have not posted on the stak for several years. We have been working on a 1930 Twin City KT and my 12 year old cousin is restoring a 1940 Minneapolis Moline RT. Yesterday Dad bought our first piece of moline plow co history. It is a 1918 Moline Universal D. The tractor came from a dairy / farm in central Texas. The tractor seems to be in decent shape for being 100 years old. We also got the plow that was apparently bought with the tractor new. The plow was made by the Dallas Plow Co out of Texas. I am going to try to post progress along the way as we will need some advice and help finding parts.
ID:	327317   Click image for larger version
ID:	327318   Click image for larger version
ID:	327319   Click image for larger version
Old 01-27-2019, 11:16:16 PM
Default Re: Moline Universal D
Here are some more pictures.
Also list of parts we are needing includes:
intake exchanger
exhaust cross over pipe
Oil filler/ breather cap
gas tank
battery box
bennet air cleaner
distributer
belt pulley drive and pulley (accessory belt not fan belt)
serial number tag
steering wheel and shaft
correct seat
muffler
ignition key
ID:	327321   Click image for larger version
ID:	327322   Click image for larger version
ID:	327323   Click image for larger version
The Following 11 Users Say Thank You to Ben Zimmerer For This Post:
Old 01-28-2019, 12:45:10 AM
Nice project, Ben. I hope that you can find the parts. Talk with Paul Searl.
That tractor set the standard for going electric at that time. If your generator (governor) is there and can be used or fixed, good. Some folks shy away from these, but amps, volts, flux in webers and generator reaction torque are not that difficult to understand. You will not need to measure magnetic flux, you can feel its effect.
Stay with it.
Ed
The Following 2 Users Say Thank You to Oilpulled For This Post:
Old 01-28-2019, 12:23:50 PM
OrgWayne OrgWayne is offline
Hi Ben , I could be wrong big time , but I think there is one at Brooks Oregon Antique Powerland , Maybe Some Northwestern people will chime in
Nice Find and save
Wayne
The Following 2 Users Say Thank You to OrgWayne For This Post:
Old 01-28-2019, 01:17:56 PM
Hi Ben,
Great to see you back-on-Stak once again.
Check with Loren and Ruth Book in Nevada IA. for possible parts contacts also.
(mm collector club)
Good luck on a nice looking project!
Tony
The Following 2 Users Say Thank You to Tony Thompson For This Post:
Old 01-28-2019, 07:49:40 PM
Rick Trotnic Rick Trotnic is offline
Is this something you can use? My tractor is in storage but I think this is extra. I am going to check and it is possible I have some other parts. Thanks, Rick
ID:	327377   Click image for larger version
ID:	327378   Click image for larger version
ID:	327379   Click image for larger version
The Following 2 Users Say Thank You to Rick Trotnic For This Post:
Old 01-28-2019, 08:06:16 PM
Great find
Old 01-28-2019, 10:17:08 PM
Yes I am needing those parts my email address is bjz2012@hotmail.com
The Following User Says Thank You to Ben Zimmerer For This Post:
Old 01-29-2019, 09:02:24 AM
https://archive.org/details/arkivkop...ek-TEKA0008710
Old 01-31-2019, 01:41:59 PM
Kelly Barnett's Avatar
Kelly Barnett Kelly Barnett is offline
Images: 15
Ben, maybe you know this already or maybe not, but that Holley model "K" carb has quite a few parts that are identical to the Holley "G" carbs used on Ford Model T's. so many of the gaskets, float, and needle and seat can be sourced from that if needed.
The Following 8 Users Say Thank You to Kelly Barnett For This Post:
Old 02-02-2019, 05:03:13 PM
astractors astractors is offline
Hello Ben. If you want a new name tag contact Chris Astell at Vintage brass plates www.vintagebrassplates.co.uk He made 1 for me last year so he already has the pattern artwork and will put the serial numbers on.
I am rebuilding one here in the UK now and also need a Holley K carb if anyone can help.
ID:	327780   Click image for larger version
The Following 4 Users Say Thank You to astractors For This Post:
Old 02-10-2019, 06:09:22 PM
Paul Searl's Avatar
Paul Searl Paul Searl is offline
Ben,
As part of the build up towards the Moline Plow Co Universal Tractor Reunion in Sept at Geneso IL, Loren Book in Ames IA has been doing a lot of work in putting together sources of parts and repairers. He has actually found someone able to rebuild the electronics and some other parts. He has also been putting together a serial list with corresponding casting numbers. There was talk of doing repro tags, but I am not sure he ever moved forward with it. He does have some spare parts, but a lot of the things you are missing are hard to find although there are some out there. Lorens contact info is on the MolinePlowCo.com page (also in my sig).
The Following 4 Users Say Thank You to Paul Searl For This Post:
Old 02-15-2019, 09:46:19 PM
Well Dad and I got the universal pushed into the shop today. We started disassembling the engine. So far we have found a bent push rod, a broken push rod cap, and a broken rocker arm. The other push rods a pretty rotten also. Does anyone have any of these parts? Maybe know where we can get new push rods made.
---------- Post added at 09:46:19 PM ---------- Previous post was at 09:43:44 PM ----------
I will try to get some pictures posted tonight.
The Following 2 Users Say Thank You to Ben Zimmerer For This Post:
Old 02-16-2019, 10:25:27 AM
Here are some pictures
ID:	328778   Click image for larger version
ID:	328779   Click image for larger version
ID:	328780   Click image for larger version
The Following 8 Users Say Thank You to Ben Zimmerer For This Post:
Old 02-16-2019, 10:26:40 AM
Here are some more
ID:	328782   Click image for larger version
ID:	328783   Click image for larger version
ID:	328784   Click image for larger version
The Following 10 Users Say Thank You to Ben Zimmerer For This Post:
Old 02-16-2019, 02:45:42 PM
David Parfitt's Avatar
David Parfitt David Parfitt is offline
Just out of interest, where did you find the chassis number marked on your tractor, as I see that part of the original plate is missing?
The Following 2 Users Say Thank You to David Parfitt For This Post:
Old 02-17-2019, 09:50:47 PM
The chassis serial number is also stamped on the top of the transmission housing. The serial number of our tractor is 16021. The transmission is cast 8-16-18. So the tractor is a 1918. The engine has a 9 25 cast on the inside. So the engine appears to have been replaced. I was reading an article that was saying that these units had a lubrication problem.
ID:	328884   Click image for larger version
ID:	328885   Click image for larger version
ID:	328886   Click image for larger version
The Following 5 Users Say Thank You to Ben Zimmerer For This Post:
Old 02-17-2019, 09:55:16 PM
We go the engine pulled out today and we got it partially disassembled. The previous owner had to pay a bee keeper to get the swarm of honey bees out. He cleaned most of the honey comb out but there is still some left.
ID:	328888   Click image for larger version
ID:	328889   Click image for larger version
ID:	328890   Click image for larger version
The Following 7 Users Say Thank You to Ben Zimmerer For This Post:
Old 02-17-2019, 09:58:17 PM
more pictures
ID:	328895   Click image for larger version
ID:	328896   Click image for larger version
ID:	328897   Click image for larger version
Old 02-18-2019, 09:47:12 AM
Russ Hamm's Avatar
Images: 1
Thanks for all the pictures, it is interesting to see how these were built, some of us without first hand experience. And it makes for future reference for many others.
The Following 3 Users Say Thank You to Russ Hamm For This Post:
Moline Universal Tractor,Moline Illinois casertractor Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 27 Yesterday 10:47:38 PM
Moline Universal Gene Fisher Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 09-03-2015 09:32:34 AM
Moline Universal D help ChadBergmann Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 27 04-13-2014 05:48:18 PM
Moline Universal D What year is it? Oilpullman Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 12-20-2012 11:36:51 AM
Moline Model C Universal Randy Kvill Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 02-20-2008 03:59:43 PM
