Hercules JXC / JXLD
this thread has 4 replies and has been viewed 438 times
Old 04-15-2019, 12:59:12 PM
ruumar ruumar is offline
Default Hercules JXC / JXLD
Hello.
I have HEI distributor taken apart and a original distributor from delco remy and fixed them to each other and now the HEI is in a hercules engine.
Never had a engine before that runs that nice.
The best is that i can turn the distributor much more then the delco, because then it hits the waterpump.
But what ik would like to now if anybody knows the timing degrees for those engine's.
Now i also have a vacuum canister, so can go for carb or manifold vacuum or not at all.
Kind Reegards
Ruud
Listen to the idle with the ori distributor, did run this, because i whanted to know the timing, so i could look if the hei had the same and it did.
And now idle with the hei.
Also vacuum is nice and steady, never had that also before.
Did my best on the englisch, but stil a dutch guy he
The Following User Says Thank You to ruumar For This Post:
Old 04-18-2019, 01:25:31 PM
Tom Marshall Jr.'s Avatar
Tom Marshall Jr. Tom Marshall Jr. is offline
Images: 1
Default Re: Hercules JXC / JXLD
old motor book says DC 1-6 , mark on flywheel . both are same. all advance would come from inside hei and set timing with line unhooked . then hook up vacuum line after timing is set.
Old 04-20-2019, 10:42:22 AM
Thank you, last question, should i go for ported or manifold vacuum ?
Old 04-20-2019, 12:26:14 PM
Images: 1
usually ported most times at the carb.
Old 04-21-2019, 01:55:29 AM
Consolidated Diesel Electric Genset, Hercules JXLD Kato Powered - Insight appreciated J.T. Lowell Multi-Cylinder Stationary Gasoline Engines and Power Units 40 01-23-2017 06:57:12 PM
Hercules engine and Hercules water pump.. Fred Van Hook Hit & Miss Gas Engine Discussion 0 06-30-2014 05:43:00 PM
Hercules QXD-3 dkamp Multi-Cylinder Stationary Gasoline Engines and Power Units 14 12-15-2012 08:45:23 PM
Anybody know who this guy is? - Consec genset w. JXLD... dkamp Generators & Electric Motors General Discussion 2 07-11-2012 06:38:33 AM
Hercules JK Frances Antique Engine Archives 0 07-02-2004 04:05:51 PM
