Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm Antiques and Collectibles
Farm Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers and pumps.
Removing and Protecting Against Rust in Water Pumps
this thread has 3 replies and has been viewed 612 times
Old 04-20-2019, 09:09:15 PM
VicF VicF is offline
Default Removing and Protecting Against Rust in Water Pumps
Hi, I recently bought a Flint and Walling Hoosier water pump and noticed some rust and I decided to see how far the rabbit hole went and discovered some serious flaking internal rust. I want to try to preserve this pump while still making it functional. I thought maybe removing the internal rust and then using a rust encapsulator but not sure how that would fair with water. Any tips or ideas on how to go about this?
Old 05-05-2019, 06:01:50 PM
Doug Kimball's Avatar
Default Re: removing and protecting against rust in water pumps
Have had good luck sandblasting internal parts & coating with epoxy.
In Kennebunk, Maine;
Doug Kimball
Old 05-05-2019, 06:21:43 PM
K-Tron K-Tron is offline
Once you sandblast the scale and rust away you can try sealing the cast iron with Glyptal insulating varnish. Once cured in an oven it is pretty much impenetrable. Several big name diesel engine manufacturers like Buda and Murphy used to seal the water jackets of their engines with Glyptal.
Chris
Old 06-24-2019, 11:49:07 PM
Just saw these replies. Eastwood sells it. Is air drying as good as baking it? Thanks
Removing Rust WCraig Hit & Miss Gas Engine Discussion 7 07-01-2017 10:28:51 AM
Protecting original paint and rust retrohead Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 27 02-24-2014 02:30:43 PM
Removing rust and not Paint Scott Hartz Paint Shop 3 12-30-2012 09:46:29 PM
Solution For Removing Rust redneck51031 Paint Shop 3 01-04-2009 07:28:51 PM
Rust removing Chris J Hit & Miss Gas Engine Discussion 21 08-15-2008 09:31:39 PM
