What Lathe Tooling Do I Need
this thread has 45 replies and has been viewed 2231 times
Old 05-02-2019, 09:04:57 PM
Default Re: What Lathe tooling do I need
Came across this vid on parting a couple days ago, have not tried it myself, and only possible with a non-threaded spindle. Seems to work, intend to try it myself.
https://www.youtube.com/watch?v=-RZRq0olsxM
The Following 3 Users Say Thank You to dalmatiangirl61 For This Post:
Old 05-03-2019, 01:19:50 AM
cobbadog cobbadog is offline
What a simple solution. I too will be putting this into action here as I do have this problem.
Something to help me out a bit more is that when I set the cutting tool height I set it to the live centre in the tail stock and the cutting edge level with the tip. Is this correct or the reason for my issues?
Thanks for posting this Dal
As for the cut off tool, when in use it does go straight in and so far has not touched the sides so I must have it set sqaure to the job and the tool holder sitting nice and flat. I will try your idea as well in moving the tool back in close to the post and move it out only when required. My 4 post tool holder has 4 tools sitting in place so I can simply loosen the pivot lever on top that locks it all in place and swing around the next tool when needed.
I should start another thread on using a boring bar as I am having slight issues here too, but I don't do much boring. So in time I will put something up with pics so you can set me straight.
Old 05-03-2019, 08:16:13 AM
The chucks on my South Bend are screw on. I'd probably launch it across the room trying this method.
Cob, I'll assume you use the old scale between the tool and work method to set tool height.
ID:	334030   Click image for larger version
  #24
Old 05-03-2019, 02:35:58 PM
Yes using a center in tailstock to set parting tool height is the right way, to set squareness to workpiece I move cutter over and set square to face of chuck.
Oldstuff
Yes threaded chuck on my old Atlas makes upside down cutter a useless suggestion for the new owner.
Replaced the Atlas with a YAM last year, got it cheap because it had zero tooling, not even a chuck. Did not think finding a chuck for it would be such a big deal, I was wrong. After a year of searching ebay, and passing on some beat-up old ones, finally got a NOS 8" 4 jaw A1-5 mount chuck this past week at a reasonable cost. Search continues for a 3 jaw.
  #25
Old 05-03-2019, 03:20:15 PM
^ Yowch.. I'm seeing $700-800 for a 3 jaw A1-5.
Maybe this then use any 3 jaw? Available in several diameters.
https://www.smalltools.com/bison-sem...-for-8-chucks/
  #26
Old 05-03-2019, 06:33:57 PM
Yep, that's the problem! I've considered going the adapter plate route, and may have to at least till I find the right one. Whereas most adapter plates you mount to chuck, and it stays with chuck, with A1-5 you have to mount adapter to spindle, then chuck to adapter, and remove in reverse sequence, it just makes it a PIA!
I need a deal on a 3 jaw like I got on the 4 jaw
https://www.ebay.com/itm/KITAGAWA-8-...rdt=true&rt=nc
Old 05-03-2019, 08:35:18 PM
Steve Kreiner's Avatar
Steve Kreiner Steve Kreiner is offline
Steve what was the question you asked?
Old 05-03-2019, 09:51:34 PM
D:
Whoa... Kitagawa, first rate stuff!
In general, you possibly have buyers remorse as it's such a pain in the ass. $$
  #29
Old 05-04-2019, 02:23:51 AM
Cob, I'll assume you use the old scale between the tool and work method to set tool height.[/QUOTE]
Being an absolute novice with a lathe I'm sorry but I don't understand the what you are asking about "using the old scale" when I set up.
The way I have been doing it is to wind the saddle towards the tailstock which has a 'live centre' in it and I set the tool height to be in line with the very point of the live centre.
Then to set it square to my job I have the lathe switched off and I then wind the saddle towards the chuck and with the cross slide out towards me i keep winding until the parting off tool is sitting level against the chuck. If you are watching what you are doing if you go too far forward the cutting tip moves away from the chuck and if not far enough in the tool holder is not against the chuck.
Thank you for any and all bits of information offered.
Cheers Cobba
Old 05-04-2019, 04:38:12 AM
Take a small measuring scale and hold it straight vertically against the work. Run the tool into it and it'll show you where the tool is hitting the work. When the tool is centered, the scale will be held vertically. In my #1 pic post 23, the tool is a bit high as the scale tilts inward.
The Following 2 Users Say Thank You to I like oldstuff For This Post:
  #31
Old 05-04-2019, 11:26:17 PM
OTTO-Sawyer's Avatar
Maybe a Visual Will Help You Understand it Better. . .
Plus This Guy Took it a Step Further by Double-Checking with a Square.
Or Get Yourself One of the gauges. . .
Or Make Yourself a Simple Gauge Block. . .
Depending on your lathe size and configuration, a home made block can be made that will fit in-line with the tooling (cut off, turning tools, boring bar, etc.) and be able to set them directly to the gauge eliminating the need for an indicator. There are More videos showing different ways of making them, I just chose this one because it was relatively short. . .
"Make It Your Own" or copy one of their designs.
The Following 2 Users Say Thank You to OTTO-Sawyer For This Post:
  #32
Old 05-05-2019, 01:04:14 AM
Thanks Guys for the tips. I was never smart enough to use the metal rule as an indicator but it is a simple way of getting to the right height.
With my lathe I have to use shims to raise the height so I have a number of different ones in the drawer to make the adjustment.
  #33
Old 05-06-2019, 03:17:38 PM
You notice seller did not say what it fit, I could tell it was A something, did have buyers reservations, but it showed up today, just got finished measuring it, pretty sure it fits A1-5 spindle. Nice chuck, looks unused, and its lathe tooling I need!
Old 05-06-2019, 05:15:52 PM
^Clean and fit it up and of course pics of machine pron are required.
Old 05-06-2019, 05:32:14 PM
Couple pics from last year, previous owner was repainting it, then lost interest in the project, said it had been gracing his garage for 10 years and mocking him, he just wanted it gone. It looked like 10 years of dust, pics below are after a half hour wipe down. Even came with a turret tailstock! Can't fit the chuck just yet, lathe is in Nv, and I'm not
ID:	334269   Click image for larger version
ID:	334270   Click image for larger version
  #36
Old 05-06-2019, 08:27:42 PM
Hefty looking machine and you'll love the turret! You have a nice production tool there.
And it's a 2 stroke judging by the expansion pipes next to the turret.
By it's size I'll assume it's 3 phase. Are you going the converter route or do you have 3ph in the building.
Old 05-07-2019, 03:23:38 PM
For now I'm using a rotary converter for most of my machines, the building in Nv has 3ph available, need to save up to bring it in, and power co wants a 5k deposit
The Yam/Yang lathes are a Taiwanese copy of a Mori Seiki, from the reviews from real users, they are nice machines, hopefully I'll get it up and running this year.
  #38
Old 05-07-2019, 03:29:01 PM
For $5k you can run the converter for a hella long time.
Old 05-10-2019, 11:57:28 AM
Alphonse's Avatar
Alphonse Alphonse is offline
Thumbs up Re: What Lathe tooling do I need
I just posted a video on a 4 way tool post I made for my Logan 10" lathe, and some other shop made tooling. You can take a look see...
https://www.youtube.com/watch?v=dMCp_o1E-V8
The Following User Says Thank You to Alphonse For This Post:
  #40
Old 05-10-2019, 06:52:44 PM
tdmidget tdmidget is offline
Apparently Cobbadog is ahead of everyone else here as he knows the difference between a rule and a scale.
The Following User Says Thank You to tdmidget For This Post:
Help needed to identify Puller J and B Tooling Firewoodguy Machine Shop and Tool Talk 2 12-08-2018 06:06:57 PM
Smith Drum Gap Bed Engine Lathe with Tooling Charley K Machine Shop and Tool Talk 9 02-25-2018 07:54:59 PM
lathe tooling KyleBlankenship Machine Shop and Tool Talk 17 01-09-2014 03:16:37 PM
Need Atlas Lathe Tooling and Parts Access larry bee Machine Shop and Tool Talk 8 05-24-2011 06:39:36 AM
Bridgeport tooling. Greg Shipley Machine Shop and Tool Talk 14 05-16-2008 11:00:20 PM
