Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Railroads and Equipment
Railroads and Equipment Vintage Rail Engines, Vintage Railroads and Cars, Equipment and Lore
Union Pacific Big Boy 4014 Update #2 April 2019
this thread has 4 replies and has been viewed 487 times
Old 04-23-2019, 04:28:41 PM
Default Union Pacific Big Boy 4014 Update #2 April 2019
https://www.youtube.com/watch?v=zZ7KtmMO1CU
Encouraging seeing smoke from the stak and the front appears to be complete.
It's getting closer to the day I have been waiting for!
Robert
The Following 2 Users Say Thank You to Railroads For This Post:
Old 04-23-2019, 04:44:35 PM
Default Re: Union Pacific Big Boy 4014 Update #2 April 2019
Is the smoke from burning off crap in the fire box, or are they running a dirty fire? i thought that she was to be oil fired, if so I would think that todays technology would make for a clean fire. If they used original tech, then it would not burn so clean would it? Of course, if it didn't smoke, it would lose some of the charm of being a steam locomotive!
The Following 2 Users Say Thank You to Andrew Mackey For This Post:
Old 04-23-2019, 09:21:22 PM
Greg Mosley Greg Mosley is offline
Greetings Railroads, Look closely at the engine. Possibly a photo shop spoof. The cylinder heads appear to be absent on the loco. Hmmmmm…, Enuf Said.
The Following User Says Thank You to Greg Mosley For This Post:
Old 04-24-2019, 12:21:18 PM
Could be a photoshop. They are against the clock in performing their test runs though. I am thinking the reason UP #844 and a diesel will be on the same consist is because they are not going to perform their usual test runs? They don't want the public to see Bigboy until the official ceremony.
Normally the yard track in front of the Cheyenne depot is used for testing the steam locomotives. Usually followed by a freight train run or two on the mainline.
Lots of smoke from the stak is normal on a oil burner steam locomotive. They are using the same configuration that is used on the challenger and Northern. The setup is basically the same as it was in the 1940's.
Robert
The Following 3 Users Say Thank You to Railroads For This Post:
Old 04-27-2019, 06:01:35 PM
An interesting photo out of Cheyenne. It's Live!!!
http://www.rypn.org/forums/viewtopic...af55a&start=15
Robert
The Following User Says Thank You to Railroads For This Post:
Union Pacific Big Boy 4014 Update | April 2019 Railroads Railroads and Equipment 13 04-18-2019 11:07:38 PM
Union Pacific Big Boy 4014 Update Early Febuary 2019 Railroads Railroads and Equipment 0 03-12-2019 02:18:04 PM
Union Pacific Rr #844 Robert M Steam Stationary Engines, Traction Engines 0 04-29-2006 03:37:38 PM
