Wanted: Mid 1920's Rear Bumperettes
this thread has 15 replies and has been viewed 807 times
Old 04-25-2019, 05:39:45 PM
oldsoldster oldsoldster is offline
Default Wanted: Mid 1920's Rear Bumperettes
I recently added an accessory front bumper to my 1925 Buick coupe. Now I'm trying to find a set of rear bumperettes to match. The 1925 US built Buick was not fitted with factory bumpers,so there were numerous aftermarket suppliers for these.
The dimensions are: overall width about 61 inches, bumperette width about 16 inches each, bars are 2 inches wide and flat faced.
The brackets are likely vehicle specific.I think I can get those made.The bumperettes have a reverse curve at the ends.The photo shows exactly what I'm after. Condition - restorable.
Jim
Name:	1925 Buick rear bumperettes.jpg
The Following User Says Thank You to oldsoldster For This Post:
Old 04-26-2019, 07:30:45 AM
DaveHC DaveHC is offline
Default Re: Wanted: Mid 1920's Rear bumperettes
Looks like Model A bumpers are close to what you might need .
The Following User Says Thank You to DaveHC For This Post:
Old 04-26-2019, 11:13:41 AM
www.buickfarm.com
Old 04-26-2019, 03:43:09 PM
Similar but no reverse curve at the ends. I attached a photo of the front one that i'm trying to match.
Jim
Old 04-26-2019, 03:51:54 PM
Originally Posted by casertractor View Post
No luck there.What makes it complicated is that there is no Buick part number for these.They weren't supplied by GM but by the aftermarket. I found a front,complete with correct 1925 Buick Standard only mounting brackets.The photo shows the matching rears on someone's blue coupe.Sooner or later I'll find a pair.
Jim
Old 04-26-2019, 04:31:59 PM
Jim
The Barrie automotive flea market is coming up in June and you could try their also
www.thebafm.com
Old 04-26-2019, 11:28:44 PM
Oldtech Oldtech is offline
What about 26-7 rear bumpers. They are similar i think.
Old 04-27-2019, 07:21:18 AM
The ones I have seen don't have the reverse curve at the ends.
Old 04-27-2019, 03:04:28 PM
These aren't as fancy but better than straight bumpers.
https://www.speedwaymotors.com/Speed...umper,274.html
These are the rear bumperettes for a '32 Chevy.
Old 04-28-2019, 06:19:27 PM
I was going to swipe your photos and ask at aaca on your behalf...…...but I see you beat me to it...….
Old 04-28-2019, 08:36:01 PM
I've got feelers out all over - even Model T Haven !
The Following 2 Users Say Thank You to oldsoldster For This Post:
Old 04-28-2019, 08:54:35 PM
Probably a stoopid question (but maybe more stoopid if I didn't ask)……...have you been keeping an eye on ebay?
I follow a seller who seems to have an unending inventory of early Chevy stuff.
Old 04-29-2019, 06:29:23 AM
Yes.That's where I found the front one.There is a front and rear one on there now for a mid-twenties Buick.They match each other but not mine.Lord knows how many aftermarket bumper suppliers there were back then.
Old 05-14-2019, 10:20:50 PM
Any luck in finding a set?
Old 05-16-2019, 07:18:05 AM
Not yet.
Old 05-23-2019, 11:23:08 AM
Phil Johnson's Avatar
Default Re: Wanted: Mid 1920's Rear Bumperettes
Is there a good spring shop in your area?? When I restored my '29 Stutz. the bumpers were missing, so I made drawings with accurate measurements from an original set and took them to my local spring shop and they made them up for me and I then had them chrome plated.
The bumper bars are made from spring steel same as leaf springs.
Might be hard to find a good spring shop these days!!!
Only one left in this area.
The Following 2 Users Say Thank You to Phil Johnson For This Post:
Case 448 - Rear PTO??, Rear Implement Lift?? RogerBurl Garden Tractors and Mowers 3 05-12-2014 08:06:25 AM
George White Rear Axle Wanted Rob Repko Steam Stationary Engines, Traction Engines 1 12-29-2013 12:40:18 PM
pre 1920 fairmont info wanted BobM Hit & Miss Gas Engine Discussion 2 08-23-2010 02:40:36 PM
WANTED: Worm drive rear axle for Model TT truck Doodlebug Lew Antique Autos and Trucks 27 06-22-2010 09:38:10 PM
WANTED: Worm drive rear axle Edisonian Antique Autos and Trucks 2 05-22-2010 10:43:44 AM
