Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm Antiques and Collectibles
Farm Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers and pumps.
A Thing (Fuel tank for a gasoline-heated iron.)
this thread has 10 replies and has been viewed 833 times
Old 05-10-2019, 08:19:52 PM
Default A Thing (Fuel tank for a gasoline-heated iron.)
A neighbour gave me this thing today.
Not sure what kind of a mcflavianvonsplinterdorfnersputzmachenhimmelpharb type of device this is?
There is a needle valve and packing gland in the top(?).
The fitting on the other end appears to have been made with that bend in the stem.
There is a threaded section leading out of the lower fitting which is also threaded internally.
On the other end, which looks like a plain spout, there is also an internal threaded section with an internal seat for a needle valve.
On the base of this lower fitting is a stud with a nut to secure it to something.
Any guesses?
ID:	334538   Click image for larger version
ID:	334539   Click image for larger version
ID:	334540   Click image for larger version
Old 05-10-2019, 08:33:46 PM
Default Re: A Thing
Any guesses?
The Following 3 Users Say Thank You to Kirk Taylor For This Post:
Old 05-10-2019, 08:48:05 PM
Default Re: A Thing
Thanks Kirk. Never knew there was such a thing. Those irons look like they could be real weapons.
Old 05-11-2019, 06:13:49 AM
Glenn Ayers Glenn Ayers is offline
Default Re: A Thing
Boy ! That should "Burn the Greenies Asses!"
I want a gasoline powered toothbrush too!
"I'll have the Red Pill, thank you."
The Following 4 Users Say Thank You to Glenn Ayers For This Post:
Old 05-11-2019, 08:20:38 AM
Preston Wells's Avatar
Preston Wells Preston Wells is offline
Images: 37
Default Re: A Thing
Something like this.
"There is more to life than what we see"
www.youtube.com/user/theoldengine1
Preston
FL
The Following 2 Users Say Thank You to Preston Wells For This Post:
Old 05-11-2019, 10:19:04 AM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Default Re: A Thing
Damn! you guys are good, never would of guessed that.
Old 05-12-2019, 08:07:41 AM
Wayne Riedlinger Wayne Riedlinger is offline
Default Re: A Thing
When I first looked at the picture I thought the same thing, it sure looks like the fuel tank off a clothes iron. My mother used to have one when I was a wee ladd.
The Following User Says Thank You to Wayne Riedlinger For This Post:
Old 05-21-2019, 10:48:53 AM
Andy Williams Andy Williams is offline
Default Re: A Thing (Fuel tank for a gasoline-heated iron.)
just confirming that's what it is looks like a coleman. looks like they might have been dangerous. using common sense probably ok. they also made some that you put hot coals in.
Old 05-21-2019, 02:17:14 PM
gleaner gleaner is offline
Coleman irons and lights were a common thing on our farm. Those irons and lights use "white gas". Same as you use in your camping cook stoves. Compared to a kerosene lamp the Coleman gas light was "night and day" difference. Just had to pump the air pressure to the tank once in a while.
Old 05-22-2019, 12:11:46 AM
Oldtech Oldtech is offline
Yes, they could be a fire hazard, especially if dropped while using. The tank could break off spraying burning fuel around the house. Mama had to be careful.
Old 05-23-2019, 08:42:10 AM
my mom said that they had one when she was a kid, it got stopped up or something and they took the tank off and used it on top of the wood stove like the old cast iron sad iron. they also had one of the coleman g.i. pocket stoves. they didn't get electricity until about 1960
How To Clean Out Cast Iron Fuel Tank? Jim Alexander Hit & Miss Gas Engine Discussion 20 06-05-2017 08:07:40 PM
B&S Model Y-cast iron fuel tank base bigGURN Small Air Cooled Gasoline Engines 5 09-23-2012 09:53:42 PM
Cast Iron Fuel Tank - What to do... Steve Barr Hit & Miss Gas Engine Discussion 10 04-17-2009 06:54:32 PM
Our old iron not the only thing being scrapped Keith Smigle Hit & Miss Gas Engine Discussion 9 03-17-2005 12:13:05 AM
