Saved by the Bell
this thread has 11 replies and has been viewed 1081 times
Old 05-16-2019, 10:38:11 PM
Default Saved by the Bell
Actually, it's saved the bell. The city is building a new fire station, they have the bell from one of the original fire stations, the bell is marked 1888, the yoke is patent 1866. The pins on the yoke were rusted about half away. They look like they were cast into the yoke. I welded them up and put them in my big lathe, don't use it often but it's handy when needed. The yoke cleared by about a 1/16", it's a 21" Summit.
Old 05-16-2019, 11:41:49 PM
Bob Shannon Bob Shannon is offline
Default Re: saved by the bell
Nice job!
The Following User Says Thank You to Bob Shannon For This Post:
Old 05-16-2019, 11:52:08 PM
I have been around a purty large lathe and have a small one myself. That looks like it woulda been Scary having that much iron, with unknown defects in casting, spinning round and round. I would assume you had it turning rather slow?
The Following User Says Thank You to uglyblue66 For This Post:
Old 05-17-2019, 12:50:08 AM
Dwayne Fuller's Avatar
Dwayne Fuller Dwayne Fuller is offline
Wow, good save JB. Good use for the big lathe.
The Following User Says Thank You to Dwayne Fuller For This Post:
Old 05-17-2019, 05:15:03 AM
Originally Posted by uglyblue66 View Post
I have been around a purty large lathe and have a small 1 myself. That looks like it woulda been Scary having that much iron, with unknown defects in casting, spinning round and round. I would assume you had it turning rather slow?
Yep, it wasn't spinning very fast, I have one side finished, going to flip it and do the other side.
Old 05-17-2019, 08:58:38 AM
Steve Kunz's Avatar
Default Re: Saved by the Bell
Nice job! We had a Big old lathe in the shop at the plant where I used to work, I think it was about a 24" swing. It did not get used much either, maybe once a year on a large project. When the plant closed they could not give it away. It would have a major job to get it out. I think it was put in and the building built around it!
Steve Kunz
The Following 2 Users Say Thank You to Steve Kunz For This Post:
Old 05-17-2019, 06:34:13 PM
In the first photo, you can see how the pivots looked when the bell arrived, the second shows them repaired. The slow turning made it difficult to get a nice finish, a file and emery cloth made it look respectable. I polished up one spot on the bell to show the fireman how it should look. I have to make the support frame and the arm for the pull rope. I'll probably make patterns and have Cattail cast them, can add the department name, date, and put my name on the back.
ID:	335002   Click image for larger version
The Following 4 Users Say Thank You to J.B. Castagnos For This Post:
Old 05-20-2019, 09:49:28 AM
miro miro is offline
Nice work JB - I like the "old school" approach - file and emery cloth - works more often than most folks know.
miro
The Following 3 Users Say Thank You to miro For This Post:
Old 05-22-2019, 06:29:59 PM
One of the fireman came in today and started cleaning up the bell, it looks good.
Name:	bell polished.JPG
Old 05-22-2019, 08:04:26 PM
Todd Hodges's Avatar
Todd Hodges Todd Hodges is online now
Looks like heís breaking a sweat turn the fan on thatís in front of him
Old 05-23-2019, 07:24:15 PM
DavidRaines DavidRaines is offline
Nice job JB. Iím sure they appreciate your efforts.
The Following User Says Thank You to DavidRaines For This Post:
Old 05-26-2019, 08:08:37 PM
dkamp dkamp is offline
eMail NOT Working
Fine Work, JB!!! Save history...
C.S.Bell No 4 Mill bigGURN Farm Antiques and Collectibles 7 06-15-2012 08:15:27 PM
Large Bell Dan Burkart Steam Stationary Engines, Traction Engines 0 05-23-2012 08:56:16 PM
C.S. Bell B-50 Mill Plntdctr Farm Antiques and Collectibles 0 10-14-2009 04:43:28 PM
Brass Bell Kevin Kusel Farm Antiques and Collectibles 8 08-28-2009 01:24:07 AM
