Ford 841 Diesel Tractor, 1959 / Clutch
this thread has 5 replies and has been viewed 315 times
Old 05-22-2019, 02:35:07 PM
IHmarty IHmarty is offline
Default Ford 841 Diesel Tractor, 1959 / Clutch
Greetings,
The clutch will not allow me to engage the transmision with the engine running. Did the clutch fork break?
How do I fix it?
Thank you.
Old 05-22-2019, 06:29:51 PM
Default Re: Ford 841 Diesel Tractor, 1959 / Clutch
Clutch disc is probably stuck to the flywheel. its pretty common in those tractors. if your really lucky you can block the clutch down and put it in gear and rock the tractor back and forth. if that doesn't work then you move on to more drastic measures like starting it up and plowing with it while holding the clutch down.
Once you get it freed up it will tend to stick again. keep the peddle blocked down when not using it will help.
Old 05-22-2019, 06:39:19 PM
Heins Heins is offline
When you step on the clutch pedal, does it feel like it is pushing the throw out bearing against the clutch or is it easy most of the way. Does it feel like it should?
Old 05-22-2019, 08:03:06 PM
anthony k axsom anthony k axsom is offline
Belt it to a fan!
Old 05-22-2019, 11:52:43 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
We had one that was stuck on a earlier Jubilee. I took the starter off and managed to reach in and slip a small putty knife in and pry the disc loose while the pedal was blocked down. There was a gap between the pressure plate and flywheel where the edge of the disc was exposed.
Old 05-23-2019, 07:56:27 AM
ronm ronm is offline
If you do it that way, wear your football helmet with a mouth guard...or you WILL bite the steering wheel when it breaks loose. They don't coast very far with the plow in the ground...
Smokstak member #442
1959 Porsche Super L308 tractor Jim Sears Antique Farm Tractors 7 02-13-2017 01:36:02 PM
Air Filter Failure, 1959 ford 871 Diesel joebiodiesel Antique Farm Tractors 13 12-16-2016 11:06:09 PM
looking for Ford BB clutch housing, info´s of running a Ford engine on gas GTfan Antique Farm Tractors 0 04-20-2015 09:37:24 AM
Porsche diesel super 1959 Jim Sears Antique Farm Tractors 14 04-28-2014 03:18:14 PM
1959 Onan, 292 Ford Firing Order Bill Wiley Onan Generators 4 07-29-2003 08:30:49 AM
