Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm Antiques and Collectibles
Farm Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers and pumps.
John Deer Gear Reduction for Pulley Shaft?
this thread has 7 replies and has been viewed 493 times
Old 05-26-2019, 01:12:45 AM
Avery22x36 Avery22x36 is offline
Default John Deer Gear Reduction for Pulley Shaft?
OK, I am not really sure what this is but I got two of them, both marked John Deere. It looks like they were for a tumble shaft to speed or slow it down with a gear unit. I don't think I have ever seen one in a book but I assume they went with a power sweep to run a hay press but its just a guess? I got a different one that is made basically like them. The first one I got came from a Convent where a bunch of Nuns were using it with a gas engine to turn a 5 gal White mountian ice cream maker and it seemed to have worked pretty good for that and I have thought about using it in the blacksmith shop for the line drive. If someone knows, please help me out. Thanks
The Following 2 Users Say Thank You to Avery22x36 For This Post:
Old 05-26-2019, 09:12:48 AM
Mike Rock Mike Rock is offline
Default Re: John Deer Gear Reduction for Pulley Shaft?
That three speed option is cool!!
The Following User Says Thank You to Mike Rock For This Post:
Old 05-26-2019, 10:03:40 AM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
I believe that it's the drive unit from a Deere wagon hoist / elevator drive unit. There was a large frame work and cradle that you pulled your wagon front axle on to. Then uncouple from the tractor and the hoist would lift the wagon and the load would be dropped onto the elevator to be elevated to the top of the grainery. The unit also drove the elevator via a pto on the mechanism. They were very popular in the corn belt in the days before the hydraulic wagon hoist. At one time we had one but dad cut it up for steel for another project.
The Following 2 Users Say Thank You to FWurth For This Post:
Old 05-26-2019, 10:07:47 AM
OK, thanks, I got someone I can search off of now. We never had much corn in this country, mostly wheat. Most of the grainaries and elevators I have seen had dumping logs for the wagon to pull on and then they were unlocked so they worked like a teter totter for dumping into the pit.
Old 05-26-2019, 01:50:28 PM
For anyone else interested, I finally found a reference to it on SMJ website, while as FWurth pointed out, its usually shown on the wagon lift, there are also pictures of it directly on elevators and even with a horse power drive. Glad to have them, will be put to good use!
ID:	335602   Click image for larger version
ID:	335603   Click image for larger version
Old 05-26-2019, 03:44:35 PM
FWurth's Avatar
One Millionth Post
Great pictures of it set up. Deere figured it as a portable outfit,but one look shows just how much effort was required to get every thing ready for work! All this at a time when the prosperous farmers were building on farm grain barns with the drive through alley way and the indoor elevating leg for handling ear corn. Many of those barns still stand in the Midwest, but their slowly loosing out to urban sprawl. Saw a nice old farmstead with such a barn, no longer in use the other day, track hoe at the ready to destroy all.
Old 05-26-2019, 04:22:20 PM
I am eventually going to be looking for a small wooden leg for wheat. When I was a kid there were lots of little elevators moved to farms from the RR track when trucks got too big, now they are all gone. I am going to justify this for seed wheat, I am not saying its a smart justification but its one I am going to use.
Old 05-26-2019, 08:04:50 PM
Scott's Avatar
Scott Scott is offline
speed jack
1934 John deer A open fan shaft Travis Antique Farm Tractors 1 03-06-2017 12:04:37 AM
John Deere D 1929 unstyled on steel: Steering shaft worm gear Bob Anderson Antique Farm Tractors 2 06-24-2016 08:32:32 AM
John Deere D 1929 Unstyled on Steel: Steering Shaft Worm Gear Bob Anderson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 06-18-2016 02:46:03 PM
1952 John Deere A Reduction Gear-Case Oil C. Lambert Antique Farm Tractors 1 04-07-2011 10:22:50 PM
gear reduction box David Greenwalt Antique Engine Archives 12 05-21-2001 10:02:41 AM
