Rogers-Bateman press shear
this thread has 0 replies and has been viewed 354 times
Old 05-27-2019, 05:45:19 PM
Avery22x36 Avery22x36 is offline
Default Rogers-Bateman press shear
I don't know if anyone else uses these little press shears, I do mostly 1/4 flat iron and they work really well for my needs. I was wondering if anyone ever made a holder for them to use the more common tapper headed punches like Edward sells? Mine use the old straight turret punch kind that are very hard to find unless you have them custom made and that is pretty pricey. Also, the punches like to pull out because its just a set screw in a very shallow ring that holds them so that is kind of a pain also. Its going to be a tight fit but I might try to make a new holder but thought I would ask if anyone had done this first? THanks
Bateman Iron Age,Novo, Ideal, GSM or Air Cooled Motor Muffler Joel Mosley Hit & Miss Gas Engine Discussion 5 08-09-2017 10:27:47 AM
Eska shear pin info Robert Fenton Antique Marine Engines and Outboard Motors 2 03-01-2015 11:04:49 PM
Sharpening shear blades? Avery22x36 Machine Shop and Tool Talk 13 03-16-2014 03:23:24 PM
Bateman Mfg. Co. Iron Age Engine RustySteele Hit & Miss Gas Engine Discussion 6 01-14-2014 12:14:19 AM
Shear pin size problem... BDunshee Antique Marine Engines and Outboard Motors 3 09-09-2013 10:38:12 AM
