John Deere LUC Power Unit Dating
this thread has 7 replies and has been viewed 509 times
Old 06-06-2019, 08:03:26 PM
Travis's Avatar
Travis Travis is offline
Default John Deere LUC Power Unit Dating
Hello there everyone. I resently picked up a Lu stationary engine for a nice $75.00 each. I'm currently trying to date these motors.
The first one's serial number is Luc C-8965 and the other with the shroud is LUC C-11112)
Just trying to find a little information on the two. Thanks!
ID:	336571   Click image for larger version
ID:	336572   Click image for larger version
ID:	336573   Click image for larger version
Old 06-06-2019, 08:05:32 PM
Travis's Avatar
Default Re: John Deere LUC power unit dating
Here is my last one.
Old 06-06-2019, 10:08:45 PM
ulgydog56's Avatar
that engine was used in luc units, L,
La tractors and a-12 combines, if that is a Hercules motor used on earlier models it wood be built from 1937 to approx. 1941. if it a J.d. engine they (decided to make there own) it was built from 1941 to 1946. J.d motors looked the same except it had a one peace clutch housing and bigger displacement, your mag looks different than mine, its a 43 to 45.....
The Following User Says Thank You to ulgydog56 For This Post:
Old 06-07-2019, 09:36:25 AM
Travis's Avatar
Is it harder to find the Hercules model?
Old 06-07-2019, 01:19:45 PM
Travis's Avatar
Default Re: John Deere LUC Power Unit Dating
Sorry, I read the first seriel number wrong. The number is (3965). It also has rhe one piece casting on the clutch housing.
Old 06-07-2019, 02:23:15 PM
If the engine and bell housing are a single casting it's a JD built engine.
Old 06-07-2019, 08:58:58 PM
Travis's Avatar
I noticed that the one engine (photo up above) has a extra arm running back to the clutch and my other does not. What is the difference? Could someone also put a link showing the back of the Hercules casting please.
Thanks!
Old 06-07-2019, 11:16:45 PM
ulgydog56's Avatar
I see you have right hand reduction gears on yours, they also made left hand and no reduction setups....
John Deere Power unit Bob Ronning Generators & Electric Motors General Discussion 15 11-13-2016 07:15:39 PM
John Deere W power unit help MNDeereMan Hit & Miss Gas Engine Discussion 3 09-03-2016 12:37:14 AM
John Deere W Power Unit dcwaller66 Hit & Miss Gas Engine Discussion 1 09-17-2015 09:57:27 PM
John Deere power unit Brickman Multi-Cylinder Stationary Gasoline Engines and Power Units 9 11-04-2013 11:26:23 PM
John Deere W Power Unit MSimons Hit & Miss Gas Engine Discussion 1 04-26-2010 09:32:22 PM
