Tillotson Carb
this thread has 5 replies and has been viewed 529 times
Old 06-13-2019, 07:06:51 AM
sparkie sparkie is offline
Default Tillotson Carb
Hi guys,
Anyone know what this Tillotsen carb is off?
I was told it might have been from a Caterpillar, but not sure which model, or if that's correct or not?
The carb is stamped with the number B4, or maybe that's an R4; it's a bit hard to read.
The carb is all brass.
It is 35mm bore inside where the mounting flange is.
The flange has two 3/8" mounting holes that are 2-11/16" apart on centers.
Thanks,
Dave.
ID:	337060   Click image for larger version
ID:	337061   Click image for larger version
ID:	337062   Click image for larger version
ID:	337063   Click image for larger version
Old 06-13-2019, 01:06:57 PM
Russ Hamm's Avatar
Russ Hamm Russ Hamm is online now
Images: 1
Default Re: Tillotson Carb
I see some Cletrac applications so far, but no Caterpillar.
Old 06-13-2019, 08:11:08 PM
OK Russ,
Thanks for that info.
Do you have any info on what model(s) or years of Cletrac it might have been off?
Thanks,
Dave.
Old 06-13-2019, 08:25:15 PM
The little model F Cletrac had a tillotsen.
Old 06-13-2019, 10:34:09 PM
Intex Intex is offline
Little f cletrac was a down draft I believe.
Old 06-14-2019, 05:27:45 PM
Russ Hamm's Avatar
Images: 1
9-16 Cletrac isn't it, 12-20 doesn't look like it either. I would say two hits and a miss, I looked quite a while and didn't find a match.
Tillotson Carb sparkie Dozers and Crawlers 0 06-13-2019 06:58:59 AM
Tillotson Carb help oyster bay man Carburetors, Mixers, Fuel Pumps and fuel delivery 14 07-21-2014 04:41:33 AM
Tillotson carb dbundy Small Air Cooled Gasoline Engines 5 02-20-2012 12:25:04 PM
Tillotson carb ID KeithW Small Air Cooled Gasoline Engines 1 11-04-2005 04:01:42 PM
Tillotson MS-94B carb Tom Holmdahl Generators & Electric Motors General Discussion 0 09-15-2003 09:56:58 PM
