Strange Noise Coming from Oliver 77
this thread has 11 replies and has been viewed 660 times
Old 06-15-2019, 08:04:32 PM
VicF VicF is offline
Images: 4
Default Strange Noise Coming from Oliver 77
Hi, Iíve been working on getting my oliver 77 started so i can get it on my trailer to take it to get repaired. I just replaced the plugs and cleaned the carb. This noise has developed around the front of the engine. The noise started then stopped. The engine then died from another issue. We started the engine again. And the noise continued. Attached is a video. The fan belt is loose but i dont think thats it.
https://youtu.be/Gu1XayHvQrM
---------- Post added at 08:04:32 PM ---------- Previous post was at 07:19:19 PM ----------
Its kind of hard to hear in the video.
Old 06-15-2019, 08:39:53 PM
ulgydog56's Avatar
Default Re: Strange noise coming from Oliver 77
possible water pump bearings..?
Old 06-15-2019, 08:52:28 PM
Images: 4
Thats what I was thinking. Just had my doubts.
Old 06-15-2019, 09:44:02 PM
PFT's Avatar
PFT PFT is offline
Images: 31
While you are checking out the front for the noise, check the crank pulley. I don't think this one made noise, but it is something that could cause trouble in the future. We just put a spot of weld on the rivets and it was fine.
The Following User Says Thank You to PFT For This Post:
Old 06-15-2019, 09:55:05 PM
Images: 4
Can you explain what happened?
Old 06-15-2019, 10:11:03 PM
Heins Heins is offline
Why don't you take the fan belt off and run the engine and see if it sounds the same. That would eliminate the water pump and generator.
PFT, is your pulley working on the hub? If it is, you can drill one rivet out at a time, drill a larger hole that would clean the hole up like a 3/8" bolt, and rivet a 3/8" bolt in the holes. I would heat the bolt red hot then rivet it. I have done that with clutch disc and it worked. I don't use the threaded part.
Old 06-16-2019, 10:16:22 PM
PFT's Avatar
PFT PFT is offline
Images: 31
Default Re: Strange Noise Coming from Oliver 77
The pulley just rotated back and forth on the rivets, was not wobbly loose, the rivets were tight in the hub. We gave it zap with the mig on each rivet filling in the slots mostly. Tractor only sees show and parade duty mostly. Picture of it with the original owners, stopped by on the way home from a parade.
PT
ID:	337279   Click image for larger version
Name:	Original owners of Oliver 77 .jpg
Old 06-16-2019, 10:39:25 PM
PFT, I didn't show you my "80" when you stopped by.
Old 06-16-2019, 11:06:54 PM
PFT's Avatar
PFT PFT is offline
Images: 31
That's OK, I left my camera in the car that day and didn't get pics of any of your stuff. I guess I will have to stop by and do that now that I am closer.
A view from our bedroom window.
PT
Old 06-16-2019, 11:54:26 PM
Images: 4
Beautiful Oliver. My Dad bought ours from a farmer across the street. My dad didn’t have the space for the drawbar equipment so he got rid of it. I’m having it picked up soon. Doing a full mechanical tune up on it. New belts, radiator, choke line, exhaust manifold. Don’t have the money for a new paint job tho. I like the original paint anyway. Hoping to convince my Dad to take it to the Rough and Tumble this year.
Old 06-17-2019, 10:55:12 AM
If the water pump and alternator bearings check out good I suspect you have a loose set of timing gears. Take the distributor cap off and rock the crankshaft back and forth. The amount of crankshaft rotation before the distributor rotor begins to move will give you some indication of the slack between the cam and crank gear.
If the timing gears are loose they will be noisier at lower engine RPM. This is caused by the valve spring pressure on the ramps of the cam lobes which tends to rock the cam gear back and forth. As the RPM increases the inertia on the gears also increases which tends to keep the teeth pulling on the load side of the gear which reduces the noise.
I replaced several sets of timing gears on these tractors for this reason back in the day when I did on farm repair work back in the 80's.
The Following User Says Thank You to Mark Schneider For This Post:
Old 06-19-2019, 10:33:51 PM
Images: 4
UPDATE: Tightened fan belt. Noise is gone. May be short lived. Still dying after running for about 3 minutes. Carb doesn't have full seal it appears due to one screw not threading right. Ordered rebuild kit. Just going to replace some parts. Still taking it in for service though.
Oliver 77 & Oliver Super 77 Parts Book / Manual TractorDom Service Manual Scans 4 04-18-2019 10:40:22 PM
Oliver 99 Coming Back From The Dead 99 SD PSD Antique Farm Tractors 22 04-03-2018 12:09:51 PM
Very Strange Auction Coming up in North America Brothers Clemens Live Auctions of Engines, Tractors and Old Iron 8 02-04-2017 06:53:35 PM
Ford 2N Oliver with Oliver E 729 Loader bigGURN Antique Farm Tractors 1 09-07-2012 10:43:37 PM
Help 6 M has a strange noise Joseph Musser Antique Engine Archives 9 09-04-2004 05:33:41 PM
