Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm Antiques and Collectibles
Farm Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers and pumps.
Fancy Ornate Grate of Some Sort
this thread has 4 replies and has been viewed 463 times
Old 06-24-2019, 12:09:39 PM
Nevr-Enuf-Stuf's Avatar
Nevr-Enuf-Stuf Nevr-Enuf-Stuf is offline
Photo Fancy Ornate Grate of Some Sort
Trying to I.D. this, 15-1/2" diameter, the center is removable, spin the slots to the tabs and it can be removed. 6-3/16" i.d.
Patrick
ID:	337783   Click image for larger version
ID:	337784   Click image for larger version
ID:	337785   Click image for larger version
ID:	337786   Click image for larger version
Old 06-24-2019, 01:04:52 PM
Dutchman Dutchman is offline
Default Re: Fancy Ornate Grate of Some Sort
Went around stove pipes, usually on the second floor to heat the room. Also to keep stove pipe from surrounding wood. Pretty much useless for heat passing through in old midwestern uninsulated farm homes.
Old 06-24-2019, 05:42:29 PM
Ken Karrow Ken Karrow is offline
But very useful for kids when told to upstairs and play while the adults played cards down stairs. We would arrange in a circle with our ears to the grate and listen to what the grown ups said. Anyone else do this?
Old 06-25-2019, 12:16:59 PM
Jebaroni's Avatar
Jebaroni Jebaroni is offline
My first thought was a stove pipe grate as well. If that was true, then what would the center, removable piece be for? You'd never use it if the outer ring fit around a pipe...?
Old 06-25-2019, 11:36:36 PM
ulgydog56's Avatar
the outer ring is to get the heat to the 2nd floor(heat rises) the inner ring is if you run your smoke pipe thru it option (extra heat) it was all gravity heat, nice find not many left, many got scraped when forced air was installed back in the day. 42 years the heat man.....
Tanite Co Troudsburg Pa. Ornate bench grinder George Kulisiewicz Machine Shop and Tool Talk 7 01-25-2015 10:49:33 PM
Grate supports? If so, what to? BCurtis68 Steam Stationary Engines, Traction Engines 1 11-26-2014 09:13:25 PM
Lets see the most ornate makers plates. agusta74 Hit & Miss Gas Engine Discussion 2 08-08-2012 08:19:23 PM
Oh Grate-ologists . . . . Pete LaBelle Steam Stationary Engines, Traction Engines 4 07-15-2012 01:13:58 PM
ornate oiler Eric Schultz Hit & Miss Gas Engine Discussion 5 02-27-2006 07:59:18 PM
