Hurth V10a Vertical Mill
this thread has 12 replies and has been viewed 595 times
Old 06-26-2019, 06:46:11 AM
Rumely6a Rumely6a is offline
Default Hurth V10a Vertical Mill
anyone know anything about these? I purchased one with some issues - this takes a No40 chuck and has power lift and table
bed is locked / seized in left /right movement. anyone with a manual out there?
thanks
Old 06-26-2019, 01:45:31 PM
Default Re: Hurth V10a vertical mill
Some pics would help. Make sure table is unlocked, if unlocked, loosen gib and try again. Never heard of No.40, you sure that is not CAT 40 or NMTB 40?
Old 06-26-2019, 09:59:49 PM
Default Re: Hurth V10a Vertical Mill
Operators,
Maint,
Electrical Diagrams,
German Text, but I have found it not too hard to understand for a few other machines---:
https://store.lathes.co.uk/print/mh880l
45 British pounds.
Pete Stanaitis
Old 06-28-2019, 07:25:53 AM
as I don't really know much about tooling I can't say
all are stamped with "40" and some are from different manufacturers
one number I have "40FC-E75" there are about 20 chucks from fractional to 1 inch diameter
thanks for the response
---------- Post added at 05:25:53 AM ---------- Previous post was at 05:12:54 AM ----------
Pete - I will give the german version a try - thanks
Old 06-28-2019, 07:33:31 AM
some photos
ID:	338020   Click image for larger version
ID:	338021   Click image for larger version
Old 06-28-2019, 07:55:59 AM
photo - not my machine but looks identical
Name:	Screen Shot 2019-06-28 at 5.45.14 AM.jpg
Old 06-28-2019, 01:44:35 PM
Looks like a pretty stout machine. Did you get the table moving yet? If loosening gibs does not help you might try removing gib screws and use a thin rod to tap small end of gib to get it loose. Cannot see enough of that tool holder to tell what it is, how about a few more pics showing the whole piece from a few different angles. And see if you can get your pics larger.
Old 06-28-2019, 09:32:53 PM
thanks for the questions and advice dal-61
long story short - unfortunately I have limited time in that shop to work on the mill as I am doing some engine work (reassembly of a 6mz waukesha engine next priority - see rumely 6 restoration thread) and my overall time here is also limited
when I can I plan to spend a day or two specifically on that machine first removing all the pile of chips and give it generally a cleanup than start loosening / disassembly
the good news the power vertical all seems to work (mostly) including the various speed settings for the spindle although the flat belt wants to jump off at high speed
more photos at that time after cleanup
The Following User Says Thank You to Rumely6a For This Post:
Old 06-29-2019, 10:55:58 AM
Maybe too simple a thought, but---
is it possible that the machine was just shut down with the power feeds engaged?
Pete Stanaitis
The Following User Says Thank You to Pete Spaco For This Post:
Old 06-29-2019, 06:08:00 PM
anything is possible
I could move the table to the left not right I moved it about 6 inches then everything locked up can't change gears for speed acts like an old tractor in two gears at one time
Old 07-02-2019, 10:10:38 AM
as I did not know for sure what the "gib screws" were -I found the following useful and instructive
try knowledge.axminister.co.uk and look at the "How To" tab - How to Set up and Adjust Your Mill. I think that is what you are suggesting Dal-61?
Old 07-02-2019, 03:10:35 PM
Kind of, it depends on what type of gibs your machine has. My guess would be that you have tapered gibs (not what is shown on that site), watch this video https://www.youtube.com/watch?v=-Mmnar89XKA
The fact your table moved, then got stuck, leads me to believe your tapered gibs have bound the table, but I could be wrong.
Old 07-02-2019, 07:55:27 PM
great video - I have taken notes- can't wait to get back at the machine and start - thanks again Dal-61
Vertical boring mill? Reed Engine Machine Shop and Tool Talk 12 06-18-2014 02:20:58 PM
Need info on Nordyke & Marmon Vertical Mill royboy Hit & Miss Gas Engine Discussion 7 03-10-2013 09:21:51 PM
Vertical mill advice Jim Thistle Scale Model Engineering 9 11-01-2008 09:46:51 PM
Should I buy this Sharp vertical mill? Gilbert_Bates Hit & Miss Gas Engine Discussion 5 02-04-2008 07:13:11 PM
Vertical boring Mill services ? Paul Gray Antique Engine Archives 0 12-09-2002 06:23:44 PM
