Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm Antiques and Collectibles
Farm Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers and pumps.
Restoring this Gas Tank
this thread has 12 replies and has been viewed 696 times
Old 06-29-2019, 06:14:45 PM
ronny p 148 ronny p 148 is offline
Default Restoring this Gas Tank
Would like to get dent or I should say crushed area back to normal !
Old 06-29-2019, 06:20:00 PM
Default Re: Restoring this gas tank
Forgot picture !
Old 06-29-2019, 07:01:18 PM
Jebaroni's Avatar
Jebaroni Jebaroni is offline
If you had a form that could help it keep its shape around the outsides, you could probably use compressed air to "inflate" it until it filled up the form. Might be a bit tricky, though. Another method could involve making an L-shaped bar that could be inserted through the filler neck and used to reach over to the dented area and pull it out almost like a gentle slide hammer. Just thinking out loud.
Old 06-29-2019, 07:25:52 PM
Doug Wilson Doug Wilson is offline
Ive heard of filling tank with water and popping it in the freezer to return to origional shape. Keep a sharp eye on it , however.
Old 06-29-2019, 07:32:54 PM
Jake Jacobs Jake Jacobs is offline
Compressed air is like a giant spring. Difficult to control. Fill it with water and hook your pressure washer to it. Should be able to pump the dent out. Better yet would some sort of hand pump.
The Following User Says Thank You to Jake Jacobs For This Post:
Old 06-29-2019, 08:04:45 PM
How do you seal where gas cap goes ! I would buy replacement if I could recreate faded paint !
Old 06-30-2019, 01:35:04 AM
mihit mihit is offline
Default Re: Restoring this Gas Tank
Any gas left in it?
...Chuck in a match
Old 06-30-2019, 09:55:38 AM
Hey I may try it !! ��
Old 06-30-2019, 11:03:05 AM
Power Power is offline
Don't use compressed air. Anything goes wrong, you got a bomb. Always use a liquid- water. First, I would see how much I could pull out with a L shaped bar through filler.
Old 06-30-2019, 02:51:13 PM
OTTO-Sawyer's Avatar
I had a Huge Dent in the bottom of one of my 1969 Firebird gas tanks that I popped out by cutting a few holes in the top of the tank and poking cut off broom handles and other assorted 'tools' in through the holes to slowly hammer the dent out with, then soldered patches over the holes which were hidden under the trunk floor never to be seen again.
If you don't mind a couple patches on the bottom of your tank where most people would never notice, that would be another option for you. Might want to try an L-shaped hook stuck through the filler neck first though before going that route. Clamp it (the L-hook) hanging down under a vice, slip the tank over it and slowly work the dent out by tapping down around it like working a dent out of a fender with a hammer and dolly.
Old 06-30-2019, 11:36:49 PM
Mike Rock Mike Rock is offline
https://www.ganoksin.com/article/orn...-and-repousse/
https://www.ottofrei.com/Snarling-Irons
Another unique tool, the snarling iron, is often used for raising designs on hollow pieces which have a small neck opening and the inside of the vessel can not be accessed with regular chasing tools. The snarling iron has a long arm bent at a 90 degree angle at the working end, which is slightly domed and polished.
This will work inside the tank with proper bends. O did a bad dent in a BSA Gold Star tank once and a 3" dent was just gone.......
The Following User Says Thank You to Mike Rock For This Post:
Old 07-01-2019, 03:41:07 PM
Russ Hamm's Avatar
Images: 1
I almost uncrimped the ends of a 10-20 IH gas tank with air, being very careful. Didn't remove the dent completely either. Different repairs for different dents I think, those snarling irons are interesting. Some I can get out close, then putty and paint.
The Following 2 Users Say Thank You to Russ Hamm For This Post:
Old 07-01-2019, 06:12:01 PM
Check out some of the paintless dent repair guys on you tube. they can work magic within reason.
Restoring Help On JD's 3 and 6HP also RV 2,4 and 6HP Jim Nickeson Hit & Miss Gas Engine Discussion 1 08-26-2012 10:32:27 PM
Help Restoring lennemann23 Onan Generators 1 03-27-2011 06:52:21 PM
Restoring a Johnson TD-20 HammerHead Antique Marine Engines and Outboard Motors 2 01-22-2011 11:54:46 PM
Restoring a Massey 135 cassidy Antique Farm Tractors 2 11-19-2008 04:42:01 PM
Are we restoring too much?? Tanner Remillard Antique Engine Archives 25 05-08-2003 12:44:17 PM
