Steam Engines
Eclipse Hand Hole Cover
this thread has 8 replies and has been viewed 477 times
Old 07-03-2019, 09:40:13 PM
Jim Mackessy Jim Mackessy is offline
Default Eclipse Hand Hole Cover
Anybody know where to get a hand hole cover for a 10 HP Eclipse vertical boiler, 3" x 4", curved across short axis, boiler diameter about 38"? Ours cracked and the inspector wants to see a "new" one. A good used one would work. The 4" dimension is running vertical.- Jim Mackessy
The Following User Says Thank You to Jim Mackessy For This Post:
Old 07-04-2019, 07:12:06 AM
steamsatisfies steamsatisfies is offline
Default Re: Eclipse hand hole cover
Jim, I have some at my shop that came off a vertical boiler of similar dimensions. I'll check today when i'm down there and let you know.
The Following 3 Users Say Thank You to steamsatisfies For This Post:
Old 07-04-2019, 09:06:49 AM
This would really help us out right now. Thanks a million, let's hope you have the one I need! - JM
Old 07-04-2019, 10:25:14 AM
BakerMaker's Avatar
BakerMaker BakerMaker is offline
https://www.oswaldsupply.com/handhol...ize_filter=129
Didn't say they would be cheap
One test is worth a thousand expert opinions - Attributed to Wernher Von Braun
The Following 2 Users Say Thank You to BakerMaker For This Post:
Old 07-04-2019, 01:18:54 PM
Nobody ever said this was an "economical" hobby, either. I'm beginning to think the word "boiler" should have "$$$$$" after it every time. I guess we have to settle on being glad we can keep them going at all. - JM
Old 07-04-2019, 02:37:47 PM
Jim, checked out my hand hole covers, and they measure 31/2 x 41/4 sorry yours is "the wrong size" Best of luck!
Old 07-04-2019, 02:54:04 PM
JBoogie's Avatar
JBoogie JBoogie is offline
Default Re: Eclipse Hand Hole Cover
I don't think $105 for a FORGED STEEL handhole plate is a bad deal at all!!
Old 07-04-2019, 03:22:41 PM
Steamsatisfies, thank you very much for checking. We're working on a few other leads, if those don't pan out, we'll have to cough up the $105.00 for an Oswald. It's not that that is overly expensive, especially considering they are available at all, so buying one there is not a bad thing, but the tube job did put a pretty nasty dent in the hobby budget! - JM
Old 07-04-2019, 07:04:08 PM
Jim Conte's Avatar
Jim Conte Jim Conte is offline
Cattail foundry, Intercourse, PA ( 717 ) 768 - 7323. Emmanuel King is Amish.
Leave a message. He will call back.
http://www.boilersaver.com/
Malleable iron chain used on IHC 2 hole hand sheller and 2 and 4 hole power sheller. Tim Colwell Farm Antiques and Collectibles 1 03-05-2017 07:07:38 PM
Hand hole plates HalfKeck Steam Stationary Engines, Traction Engines 1 04-21-2016 12:26:36 AM
Onan CCK Gear cover Plug oil hole? Fudinia Onan Generators 7 07-08-2012 08:06:41 PM
Ignitor M mag hole cover FarmSC Hit & Miss Gas Engine Discussion 3 01-21-2009 11:30:02 AM
hand hole gaskets StmEngn Steam Stationary Engines, Traction Engines 14 07-31-2006 03:31:25 PM
