Who made this big A$$ wrench and what was it intendened for?
this thread has 12 replies and has been viewed 1307 times
Old 07-07-2019, 11:13:53 PM
Card Sponsor
Default Who made this big A$$ wrench and what was it intendened for?
Anyone recognize this wrench. Looks to be made of cast steel. About 3' long ish. opening 4.5" Thanks Rob
ID:	338762   Click image for larger version
The Following User Says Thank You to Rob Charles For This Post:
Old 07-07-2019, 11:31:02 PM
Tracy T Tracy T is offline
Default Re: Who made this big A$$ wrench and what was it intendened for?
the best guess i can come up with, track adjusting wrench. pre grease jack era. I dont Know! speceialized for sure!
The Following User Says Thank You to Tracy T For This Post:
Old 07-07-2019, 11:53:38 PM
Big a$$ wrench for big a$$ bolts, my guess would be oilfield, but would cross to any field with big fasteners.
Old 07-08-2019, 01:12:59 AM
Duey C Duey C is offline
Yup, even into larger stationary steam or gas engines for flywheel hub bolts.
Save it if you can. Ain't worth nothin' but cool factor far as I know.
The Following User Says Thank You to Duey C For This Post:
Old 07-08-2019, 08:18:12 AM
cobbadog cobbadog is offline
Ignition spanner for setting your points in a magneto.
The Following 4 Users Say Thank You to cobbadog For This Post:
Old 07-08-2019, 11:12:45 AM
Corn Corn is offline
some of the early large punch presses had very large wrenches to adjust the rams and also had very large mounting bolts and nuts i still have some of the large wrenches from our old metal forming shop John
The Following 2 Users Say Thank You to Corn For This Post:
Old 07-08-2019, 11:19:02 AM
Steve Kunz's Avatar
I have it's big brother #8287 It has a 5" opening.
See post 22 in this thread.
https://www.smokstak.com/forum/showt...38#post1574938
Steve Kunz
The Following User Says Thank You to Steve Kunz For This Post:
Old 07-08-2019, 01:24:11 PM
Looks like a wrench I used at a refinery to tighten bolts on BIG presure vessles. The big gest one I used was 6" across, to tighten 2" diameter bolts and nuts. The vessle operated at 10,000 PSI, and 400 degrees! There were 208 bolts and it took 2 days to get them all tight
The Following 2 Users Say Thank You to Andrew Mackey For This Post:
Old 07-08-2019, 05:28:10 PM
OrgWayne OrgWayne is offline
Rob , the biggest wrench I ever saw was 24 inches across the flats !! It was the prop nut on the USS Shasta AE-33 Ammo Ship , saw it hanging on the Helo Bay and wondered what the heck it was for, found out at over haul in San Diego
Wayne
The Following 2 Users Say Thank You to OrgWayne For This Post:
Old 07-09-2019, 07:55:40 AM
Card Sponsor
Hey Steve, we ought to see if we can find the set.🤪
Old 07-09-2019, 10:46:27 AM
Steve Kunz's Avatar
That would be cool to have a set of the big wrenches! I wonder how may different one's they made?
Steve Kunz
Old 07-16-2019, 12:06:07 AM
tdmidget tdmidget is offline
Being open end it was not intended to get anything very tight. It would be for something that needed frequent adjustment or removal. That "superman" trade mark ought to ring a bell with someone.
Old 08-10-2019, 03:47:38 AM
Inter Bloke Inter Bloke is offline
I have seen "similar" spanners (but not exactly the same) that were supplied with harvesters to wind over the threshing drum in the event of a large blockage. If the drum got blocked you would lower the concave and work the drum back and forwards with a spanner like that to loosen the packed in straw so it could be removed.
Maybe something off one of your stationary threshers ?
Harley GK-583-F Wrench Verses GK 583 Wrench tabbyapple Antique Motorcycles 0 06-24-2019 07:06:09 AM
Wrench ID Candy T. Farm Antiques and Collectibles 1 01-19-2012 02:00:42 PM
Wrench (?) for what? Craig A Farm Antiques and Collectibles 4 09-20-2010 10:50:27 PM
Home made heavy duty boring bar made. aametalmaster Machine Shop and Tool Talk 9 01-29-2010 08:48:22 AM
IH wrench John Wall Antique Engine Archives 0 04-28-2003 11:41:11 PM
