Vise Grip Tool?
this thread has 1 replies and has been viewed 560 times
Old 07-08-2019, 09:59:25 PM
J ohn J ohn is offline
Default Vise Grip Tool?
What is / was the purpose of this modified or mfg'd Vise Grip?
ID:	338802   Click image for larger version
The Following User Says Thank You to J ohn For This Post:
Old 07-09-2019, 12:06:39 AM
Ken Karrow Ken Karrow is offline
Default Re: Vise Grip Tool ?
To pierce a refrigerant line for evacuation of refrigerant. Fast and easy to install but since it leaves a hole when removed it is normally used on a system of component that is not going to be reused. Normal application is by someone who is removing refrigerant from multiple units for junk or metal salvage. With six tools like this and three pumping systems I have recovered refrigerant from over 100 systems in less than seven hours.
---------- Post added at 09:06:39 PM ---------- Previous post was at 08:55:21 PM ----------
Tool is used to evacuate refrigerant charge from a refrigeration unit. Normally used on a system or component that is not going to be reused. Normally used by someone that is preparing a number of units for recycling and needs to recover the refrigerant before the units are recycled. I have recovered the refrigerant from over 100 units (refrigerators and air conditioners) in less than seven hours during six of these and three pumping setups. They are fast and easy to install and remove and this counts since I was paid by the piece.
The Following 3 Users Say Thank You to Ken Karrow For This Post:
Sieve Grip Help Kevin Watson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 08-11-2014 04:25:23 AM
Samson Sieve-grip RIP William Engelmann Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 02-10-2009 07:42:29 AM
Samson 6-12 Sieve Grip Tanner Remillard Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 02-03-2006 10:18:09 PM
Samson Sieve grip Brian Manning Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 03-04-2005 12:07:07 AM
