Composite Head Gaskets
this thread has 3 replies and has been viewed 368 times
Old 07-10-2019, 09:54:11 PM
Alltractorman Alltractorman is offline
EMAIL NOT WORKING
Default Composite Head Gaskets
I know it's not recommended but what can I put on composite head gaskets to make it seal better? Thanks
Old 07-10-2019, 10:18:42 PM
Default Re: Composite head gaskets
Spray copper coat.Napa sells it under another name but similar stuff.
I use a light coat on some stuff to hold it in place moreso than to seal.
Old 07-10-2019, 10:34:18 PM
Roger Byrne's Avatar
Roger Byrne Roger Byrne is offline
You must putting your Titan back together. I agree with the previous poster and I use a light coating of a "Coopercoat" type spray sealer. It's worked on trucks/engines/tractors that I've worked on with composite head gaskets. I don't know if the sealer is needed, but at least it's never caused me a problem using it.
Preserving Mechanical History for Future Generations since 1965
Old 07-10-2019, 10:46:39 PM
EMAIL NOT WORKING
Yup...the head and block have afew imperfections and just wanted to be sure it seals.
Copper composite head gasket source Tom Gosciminski Hit & Miss Gas Engine Discussion 2 05-09-2019 05:48:46 AM
Head Gaskets? Axle Jack Smokstak Down Under 30 04-01-2018 05:09:21 AM
Head Gasket - Reuse COPPER or install new Composite (asbestos-like?) DerekC Hit & Miss Gas Engine Discussion 19 01-14-2008 08:46:33 AM
Head Gaskets Byron Roberts Hit & Miss Gas Engine Discussion 6 03-11-2005 07:36:46 AM
Head Gaskets Tom Jamboretz Antique Engine Archives 6 12-01-2001 10:21:43 PM
