Steam Engines
Burning Straw
this thread has 7 replies and has been viewed 1288 times
Old 07-12-2019, 01:20:00 PM
JKelsh325 JKelsh325 is offline
Default Burning Straw
Has anybody on here burned straw during a show or own an engine that is fitted to burn straw? Most manufacturers offered different equipment to help aide with the process (different firebox doors, different firebox design, brick arch etc) After watching this video (https://youtu.be/QOhFwMTkD7M) of a 25 Huber thresh while burning straw I am curious what all problems one would encounter and how different it would be to fire in terms of fuel consumption.
The Following 2 Users Say Thank You to JKelsh325 For This Post:
Old 07-12-2019, 05:58:19 PM
Gary Jones Gary Jones is offline
Default Re: Burning Straw
Hi,
I have fired with straw many times at shows. Send me a PM and we can see what you have for a set up.
Thanks,
Gary
The Following 3 Users Say Thank You to Gary Jones For This Post:
Old 07-12-2019, 08:57:42 PM
It'd be interesting to see that Huber being fired on straw.....I've got a 22 HP Huber and it's about a PITA to fire on either coal or wood!
Bill Stahl fires his 22 HP Gaar-Scott engine on straw while threshing at Rushville, IN.
Mike M
The Following 4 Users Say Thank You to Mike McKnight For This Post:
Old 07-21-2019, 10:33:25 PM
George White's Avatar
George White George White is offline
I helped years ago when I was quite young. It was a 26 Advance tandem compound with a water arch in the firebox. I own the engine currently but the status of the boiler is not good. Rising costs and lack of full funding have prevented me from reboilering as of yet but hope to be able to some day before my clock is up. If I remember it’s not necessarily hard work but rather steady work. Also believe tubes can plug up. Ours had 2 1/2 or 3” flues so that should help.
Nick Werth
The Following User Says Thank You to George White For This Post:
Old 07-22-2019, 07:18:05 AM
https://www.youtube.com/watch?v=ucze6A7Vseo
The Following 2 Users Say Thank You to casertractor For This Post:
Old 07-22-2019, 03:28:52 PM
This might be a silly question but did they burn hay in these engines years ago aswell as the straw? and do you try burning hay in your engines at shows?.Does hay burn good as straw does in these engines?
Old 07-24-2019, 09:31:32 PM
SteamMedic SteamMedic is offline
George do you have any pictures of the water arch? Itís not something Iíve heard of before and canít find anything with a quick google
The Following User Says Thank You to SteamMedic For This Post:
Old 07-28-2019, 09:23:32 PM
Pete Deets Pete Deets is offline
I helped on the Buffalo-Pitts at Rollag the last few years it was there and burning straw is not terribly hard work, just constant. The grate bar arrangement in that firebox looked somewhat like a large leaf rake with the tines turned up and very wide spacing. That straw chute had 2 doors side by side so you'd try to fire one and then the other but you had to keep an eye at the bottom of the door. When you saw the light of the fire at the bottom of the door you knew it was time for another stuff. If you didn't wait for that you stood a good chance of overfiring and snuffing out part if not all of the fire. We would try to take a fork full about the size of a basketball on each firing.
The straw fire is a very quick and short teeter-totter between too much and too little fuel. If you wait a minute too long your fire could be out because it burned everything. If you feed 30 seconds too early you'll easily make the fire too thick and air can't get through it and once again it goes out.
Another item peculiar to straw is the honeycomb clinker. This is a clinker that forms on the tubesheet from the particulates in the combustion gasses and can constrict or block the tubes.
As far as fuel consumption I can only offer a comparison of the heat values of different fuels. While looking for the numbers I found there was a noticeable variation from one site to the next so I'll try to present some median numbers:
For the same number of BTU's
17 1/2 pounds of wood - a pretty good armload
12 pounds of good soft coal - a good scoop full
7.2 pounds of #2 fuel oil - 1 gallon
20 pounds of wheat straw - half a small bale
16 pounds of flax straw - nearly half a small bale
Hopefully this will give you a sense of the scale of the volume of straw that has to be handled to do the same amount of work as with other fuels.
As far as burning hay, I've never heard of it being done but that doesn't mean it didn't happen. I've always thought hay was too valuable as animal fodder to be burned.....................PD
The Following 7 Users Say Thank You to Pete Deets For This Post:
Straw Burners SteamachinesLD Steam Stationary Engines, Traction Engines 1 12-12-2011 10:19:18 PM
Hesston Straw Chopper Saukengines Farm Antiques and Collectibles 0 07-09-2011 09:26:59 PM
Straw Burner markcorson Steam Stationary Engines, Traction Engines 1 04-15-2011 05:26:40 PM
Burning Straw at Sussex Wisconsin DeanMeissner Steam Stationary Engines, Traction Engines 36 08-31-2006 06:25:37 PM
Advance straw burner LundMachineWorks Steam Stationary Engines, Traction Engines 2 08-30-2005 11:18:22 AM
