Steam Engines
John Deere plow points wanted
this thread has 10 replies and has been viewed 954 times
Old 07-13-2019, 02:49:04 PM
oilpull2 oilpull2 is offline
Photo John Deere plow points wanted
Hello!!
Looking for points for an 8 furrow john Deere gang plow.
14” also any information such as drawings. Photos attached.
The Following User Says Thank You to oilpull2 For This Post:
Old 07-13-2019, 05:07:43 PM
casertractor casertractor is online now
Default Re: John Deere plow points wanted
Some pictures can be found here
https://www.smokstak.com/forum/showt...re+engine+plow
Old 07-14-2019, 07:19:04 AM
Dan Brown Dan Brown is offline
https://www.ploworx.com/
The Following 4 Users Say Thank You to Dan Brown For This Post:
Old 07-14-2019, 08:21:09 AM
Wow!!! Thank you Dan!
Old 07-14-2019, 09:55:16 AM
LukeSte LukeSte is offline
Images: 1
For breaker bottoms you wont find new ones unless nos.. i am lucky enough to have a local blacksmith shop and we are gonna put some suck back onto original points. Best bet is buying 2 or 3 bottom plows with breakers if you dont have any.
The Following User Says Thank You to LukeSte For This Post:
Old 07-14-2019, 08:12:16 PM
Arrow Re: John Deere plow points wanted
I sold plow/field equipment parts from Weise Industries for several years.
There were still a number of old time, one piece, shares in use and Weise was still making B10, weld-on, tips.
There is a knack to welding them on and if they aren't done right they will TRULY suck...…. .
It's a time consuming process to weld on and do the necessary buildup of the landside portion of the old shares.
At any rate Weise quit making them for stock and was doing only limited annual production for the Amish who MAY still be able to help you out but they would likely come from PA.
The attached PDF is another possibility.
I see they offer(?) weld on tips that compensate for narrowed shares.
Old 07-15-2019, 06:09:58 AM
thanks for the info! I will look them up also
Old 07-15-2019, 11:43:05 PM
Farmall_Doctor's Avatar
Farmall_Doctor Farmall_Doctor is offline
I replaced a set for an older friend a number of years ago. I got them from Canadian Farm Supply. They are south of St Mary's. I had to relocate a couple of holes, but otherwise they fit great!
The Following User Says Thank You to Farmall_Doctor For This Post:
Old 08-13-2019, 06:14:31 PM
http://balsters.ipower.com/
Old 08-14-2019, 10:11:53 AM
naylorbros naylorbros is offline
I believe Balster's has been closed for several years.
The Following User Says Thank You to naylorbros For This Post:
Old 08-15-2019, 12:24:35 AM
snowman snowman is offline
Is it a cast part?
I broke a plow point on a Ferguson 2-bottom plow as no have been thinking of sending the good one to a small local foundry to have a couple new ones cast. I'm not sure what it costs, but some of my steam friends seem to always have something that needs recast by them.
It's an Amish foundry in the Lancaster PA area called Cattail Foundry
The Following 2 Users Say Thank You to snowman For This Post:
Have old John Deere plow, where are all you old plow experts? lowflyer Horse Drawn Equipment 14 04-12-2015 12:57:30 AM
John Deere 2 Way 101 Plow Wanted Johnny D 1837 Antique Farm Tractors 13 02-14-2014 10:50:33 AM
John Deere A, plow A3 2 way plow information needed Johnny D 1837 Antique Farm Tractors 3 05-21-2013 07:39:52 PM
Need help iding john deere breaker points ?? willys Magnetos, Ignition Coils and Spark Plugs 2 07-22-2011 06:56:12 PM
John Deere E Ignitor Points Larry Kastens Antique Engine Archives 2 06-26-2004 10:58:04 AM
