Steam Engines
Wanted! John Deere plow points
this thread has 2 replies and has been viewed 290 times
Old 07-13-2019, 06:12:04 PM
oilpull2 oilpull2 is offline
Default Wanted! John Deere plow points
Hello!! Looking for reproduction points or good points for a 14” John Deere 8 bottom gang plow.
Old 07-13-2019, 06:24:09 PM
steamsatisfies steamsatisfies is offline
Default Re: Wanted! John Deere plow points
For what it's worth, same shears on 14" JD pull plows for tractor use.
Old 07-13-2019, 09:13:45 PM
Glenn Gieszler Glenn Gieszler is offline
I completely disagree with the shares being the same as modern plows, I have spent a considerable amount of time doing research on early gang plow design. The main difference being the early plows were developed for low speed, low draft requirements that being said the weight of the plow was not the medium used to make the plow “suck” into the ground, where as the modern plow uses the full weight of the entire plow frame to push the shares into the ground regardless whether it is a pull type or mounted with 3 point or integrated
John Deere plow points wanted oilpull2 Steam Stationary Engines, Traction Engines 10 08-15-2019 12:24:35 AM
Have old John Deere plow, where are all you old plow experts? lowflyer Horse Drawn Equipment 14 04-12-2015 12:57:30 AM
John Deere 2 Way 101 Plow Wanted Johnny D 1837 Antique Farm Tractors 13 02-14-2014 10:50:33 AM
John Deere A, plow A3 2 way plow information needed Johnny D 1837 Antique Farm Tractors 3 05-21-2013 07:39:52 PM
John Deere E Ignitor Points Larry Kastens Antique Engine Archives 2 06-26-2004 10:58:04 AM
