Go Back   SmokStak > SmokStak® General Discussion > Computer, Camera and ISP Problems
Computer, Camera and ISP Problems Solutions for accessing and using the SmokStak® boards. Posting pictures, preventing viruses and solving internet service provider problems.
Help With Old Photos and Scanned Negative Comparison
this thread has 9 replies and has been viewed 2763 times
Old 01-11-2009, 10:08:00 AM
Keith Johnson's Avatar
Keith Johnson Keith Johnson is offline
Images: 2
Default Help With Old Photos and Scanned Negative Comparison
I need some ideas on how to get some older, pre digital, photos on smokstak. Any and all ideas will be appreciated. About all I know how to do on a computer is turn it on!!
They are color photos taken in the 70s on a cheap camera so the quality is not too good.
Thanks in advance.
Old 01-11-2009, 10:36:38 AM
trudsmtuner trudsmtuner is offline
Thumbs up Re: Help with old photos
First way would be to buy a scanner, there cheap these days and the software is pretty self explanatory. But if you don't have alot of photos to transfer, it's probably not worth it.
The easiest method if your not computer savy, is most walmarts or local pharmacy or anywhere that does pictures, have a scanner in there photo center. They can scan the pictures for you and put them on a cd. Then you can transfer them to your computer. or upload them right off the disk.
Hope this helps, Justin
The Following 2 Users Say Thank You to trudsmtuner For This Post:
Old 01-11-2009, 11:56:50 AM
Images: 2
Default Re: Help with old photos
Sounds like a simple solution. I'll give it a try. I have only about 5 or 6 that I want to put on here so we'll see what happens.
Thanks for the help!
Old 01-11-2009, 01:44:41 PM
Harry's Avatar
Images: 316
This is a photo that I took in 1957 of my mother and paternal grandfather while we were visiting him in Florida. The camera was an old Kodak Duaflex, the type with the viewfinder in the top and it used the old style Kodachrome film.
Attachment #1 is the old washed out photo from the family album. And then, I found the original negative and scanned it. See attachment #2 for the difference!
ID:	46464   Click image for larger version
ID:	46465   Click image for larger version
(See our Terms of Service)
The Following 3 Users Say Thank You to Harry For This Post:
Old 01-11-2009, 04:21:56 PM
shanelc50 shanelc50 is offline
harry, you mean you scanned the negative and got this beautiful pic from it, nothing else? If you would email me what all you did. shanelc50@hotmail.com thank you
Old 01-11-2009, 04:40:43 PM
Harry's Avatar
Images: 316
It's just done with an HP scanner that has a top lamp for negatives and an older PhotoShop program to process the results. Of course there's a learning curve that goes with it so as to know which buttons to push. Practice makes almost perfect.
Click here for a full sized photo instead of the attachments. It can be done, but it won't happen over night.
Old 01-11-2009, 05:39:27 PM
AH YES.......the LEARNING curve.......
For only a few photos check this out....... :
http://answers.yahoo.com/question/in...4151457AAkPJde
Old 01-12-2009, 05:41:58 AM
ListerDiesel's Avatar
We use Epson 1240U scanners, and we have the separate film scanner module, which plugs into the back of the scanner and sits on the top where the lid would normally go.
The software allows you to scan colour negatives and automatically produces a positive image, very useful as we haqve thousands of old family pictures and trip images, plus we used positive slide film for many years before we went digital.
I believe that most of the Epson units around that time had the option of the slide/film scanner.
Peter
Old 01-12-2009, 10:10:15 AM
I just take a digital photo of the picture and load it into the computer and then edit it a bit . It's not great, but it works. Need to try the scanner/slide/negative way if I can ever find the negatives........
Make a new friend today, and a lot on the way through . Paul-"OLDIHC" #227
My YouTube channel : https://www.youtube.com/user/njoldihc
Old 02-02-2009, 02:36:03 PM
Here are a few more notes about photos and the internet:
http://www.smokstak.com/forum/showth...t=33421&page=2
Old scanned manuals by Max Thompson Kpack Onan Generators 50 03-23-2015 01:02:53 PM
Comparison from old to new Kelly Barnett Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 09-10-2012 10:35:19 PM
Horsepower comparison please Tubadon40 Maytag Engines and Collectibles 5 07-09-2012 11:00:07 AM
Scanned manuals SMertz Small Air Cooled Gasoline Engines 3 11-13-2008 05:28:23 PM
